My touch screen doesn't work
I have tried a force reboot but it still doesn't work I need help!!
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
sounds like a bad digitizer consider replacing or invest that money towards a newer iphone
このアンサーは役に立ちましたか?
I have replaced the screen so do you think i need to get another one ?
Is this after a screen replacement the touch didn't work, or did it just stop working the original screen? If it just stopped working, then you will probably need a screen replacement.
このアンサーは役に立ちましたか?
I had replaced the screen because it was cracked
Replace the screen.do not try it yourself if you are beginner.iphone 4 screen replacement need some set of skill to replace.
このアンサーは役に立ちましたか?
I have replaced the screen but it doesn't work
ok,is there any repair shop near yourplace? if yes ask them to bypass their screen a few to make sure that it is really logicboard problem. sometimes parts we bought are defected/malfunction during shipment.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 72
1件のコメント
Hi Taza, you have already posted this question a few minutes ago. I would encourage you to delete one of these to keep the Forum uncluttered.
Minho さんによる
