メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル A1237 または A1304 / 1.6、1.8、1.86、または 2.13 GHz Core 2 Duo プロセッサ
HDD to SSD
Hi
I have a MacBook Air rev A.
It has an 80GB HDD.
Is it as simple as buying a 64GB SSD drive from ebay and swapping?
Thanks.
Joseph.
Update
Thanks for the advice.
I think I have found a 64GB SSD Drive for £140.
But is it worth this money, will I see a big difference in performance/battery etc.
Also, to balance out the cost I would want to sell my 80GB drive, is this the same thing that is in iPod Classics?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Dude, dont get the MK1634GAL 160gig as the S.M.A.R.T plays up and reinstaling can be an %@!.
さんによる
コメントを追加
7件の回答
最も参考になった回答
Joseph,
Keep in mind that as mentioned above not just any SSD drive will do.
If you search eBay you will find many SSD drives but note that many are 2.5 inch drives designed to replace the typical laptop hard drive. The Macbook air original hard drives are 1.8 inch drives (ie not as thick)
More importantly the connectors and connection method must be the same in order to perform a simple swap as you desire.
For A1237 the original Air version the connector is a ZIF (Zero Insertion Force) connector and the connection is PATA. For the A1304, the connector is a LIF (Low Insertion Force) and the connection is SATA.
There are not many drives that work. One is Runcore Another is Photofast.
It would be a good idea to review this thread that discusses compatibility of SSD with macbook air.
Hope that helps.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Great info! Thanks!
さんによる
コメントを追加
As long as you get a SSD drive that is compatible with your original machine, it's that easy! No other parts need be swapped.
Apple changed hard drive cables with the second revision (A1304) with connectors that are incompatible with the original version (A1237), so you must be sure the SSD drive you buy has the correct connector. The part number is 661-4581 for the original Apple part. Plugging this number in may or may not help.
Good luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi Ben,
I am planning to get an SSD for my Air A1237. Could u tell me if my battery life will become longer?
Can I use this method to install the SSD in the A1237?
MacBook Air モデル A1237およびA1304のハードドライブ交換
And can I install snow leopard like this?
macOS High Sierraのインストール方法
Thanks
Mac OS Xの画像
ガイド
難易度:
簡単
1 - 3 hours
MacBook Air Models A1237 and A1304 ハードドライブの画像
ガイド
難易度:
中レベル
1 - 2 hours
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Please start your own question, this one is over a year old and Ben has not answered anything for two months.
さんによる
コメントを追加
Here is the iFixIt guide I followed.
This guide was very helpful and accurate for our A1304 Air, I have commented/adjusted the guide to give some extra info which I felt was missing, useful for identifying the correct model/revision and related replacement part.
I fitted a RunCore 128GB SSD to our A1304 (Revision B) Air, it was easy enough and works exactly as we hoped! The A1304 (Revision B) model Air has a LIF connector. RunCore have different SSD products for the different Air revisions, it would be easy to order the wrong part, so be sure you you what modle/revision of Air you're working on!
Read the guide in full for, for all the details.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I don't believe that 80gb is a hard drive, it should be an SSD, so why would you want to replace an 80 gb with only 64gb?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello, i was searching for disks on ebay, i found this one: http://www.ebay.com/itm/Zheino-1-8-ZIF-S...
I just wanted some advice, if this disk would work with my A1237 and if anyone has any past experience,
Thank you!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
While I have not used this exact drive I see no reason why it wouldn't work. It meets the basic requirements 1.8" with a ZIF connector. I would recommend getting a ZIF to USB adapter so you can connect the drive externally to test it and set it up.
さんによる
Same like Dan
さんによる
コメントを追加
hi guys, I buy Toshiba SSD 128GB - can anyone help me!
i have changed my HDD with SSD but the macbook Air A1304 don't recognize that there is a lif hard drive and it is totally empty. I have tried also to put a CD of lion to try to get to Utilities but still i don't see it and can't format it and give partitions.
Please could anyone tell me what i need to format it and make it work.
thanks.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jophster さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 51
今までの合計 63,335
