メインコンテンツにスキップ
iFixit uses cookies to enhance site functionality, analyze traffic, and personalize ads. By using our site, you agree to our cookie use and Privacy Policy.
The Samsung Galaxy Tab 4 10.1 is the fourth generation of Samsung tablets that has a larger screen, higher camera resolution, and 1.5 GB of RAM.
My tab 4 screen doesn't work
Hey, my tablet screen went black but the tablet works you can hear charging sounds.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
The Samsung Galaxy tab have a issue with there batteries . This may be the problem ,you can resolve the issue by disconnecting the battery and then reconnecting after a minute or so of being unplugged. While you have the tablet open it would not hurt to inspect the display cables to make sure there plugged in properly . This guide will help with the opening and unplugging of the battery , you dont need to remove the battery just unplug it
Samsung Galaxy Tab 4 10.1 Battery Replacement
Hope this helps
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Was it dropped? If it was dropped, the cable that plugs the display into the board could have come out causing the screen to go dark.
If not dropped, it might be possible that the display unit needs to be replaced.
Cheers
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Taric Butter さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 199
