メインコンテンツにスキップ
Improved second generation Google-branded tablet with a 7" screen.
20回答 すべてを表示
Doesn't turn on with a good battery
Hello all,
I have a 2nd gen nexus 7 that won't power on. I first thought that maybe it was just a dead battery and bad charging port, so I soldered in a new charging port. No dice. I then took the charged battery out of another working nexus 7 and popped it in. Still not starting.
I of course tried holding the power button down for a long time and to try and boot it into the bootloader/recovery screen. Nothing.
The only other thing I've tried so far is switching the silver ribbon cable from the nexus that works, and that didn't work either.
I can see that the motherboard has been taken out at some point because the seal on the screw was chewed up, however the seal on the daughterboard was fine (could've still been removed and replaced carefully). I don't really know where to take it from here.
I can do SMD soldering if that helps.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
will not power up. Fitted new battery, checked both batteries and charger with test meter , all ok. but will not power up in any way , any ideas?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi,
You said " I of course tried holding the power button down for a long time and to try and boot it into the bootloader/recovery screen. Nothing. "
Is this the procedure you used to get there?
Press and hold Volume Down and then press and hold Power (so that both buttons are being held together) until the tablet turns on. You should see the word “start”
Press Volume Down twice to highlight Recovery Mode.
Press Power to confirm your selection
Hold down the Power button and press and release the Volume Up button once
Press Volume Down twice to highlight Wipe Data / Factory Reset and press Power to confirm
Press Volume Down seven times to highlight Yes - Erase All User Data.
Once again, press Power to confirm
After the reset is finished, reboot your device.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
hollon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 3,875
