My laptop won't power on.
I press my power button, and my computer wont turn on. There's no lights when the battery is plugged in either. Does anyone know whats wrong?
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
この質問は役に立ちましたか?
You can try doing a static discharge . Remove the battery and unplug the laptop so there is no power to it at all . Then hold the power button down for 60 seconds this drains any residual power from the memory and allows a clean boot. Then reconnect the battery and power and boot the computer normally. If this gives no Joy test your power adapter to see if there is an issue there .If the adapters not providing power it wont charge the battery Hope this helps
このアンサーは役に立ちましたか?
Your battery may be defective. However try removing the battery for 60 seconds and see if the problem persists.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 2
過去 30 日: 8
今までの合計 2,459
1件のコメント
Student question
mayer さんによる
