Lenovo tablet won't turn on
No matter what I do, I can't get my Lenovo tablet to turn on.
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
この質問は役に立ちましたか?
If your device is not turning on, try charging the device first. If this is not the root of your problem then you might need to try other methods of turning the device on. There is a troubleshooting page that addresses this type of problem. The link is : Lenovo TAB 2 A10-70 Troubleshooting
このアンサーは役に立ちましたか?
If something goes wrong. All instructions on tablet. Useless if it won't switch on. Think change it before guarantee runs out. Bought in July only just started using it.
Hi, I had the same problem. I got a technician at my company have a look at it and he realised that most Lenovo tablets don't charge from custom USB ports that you can find in the style of Multi USB hubs or computer/laptop ports. The solution: connect the lenovo directly to a single USB wall outlet. This worked for me. Initially, I thought it was a LCD issue or a motherboard problem but, all it was that wasn't being charged correctly. I was using a multi USB port to charge it and all it did was hold the power, not charge it further. Hope this helps :)
このアンサーは役に立ちましたか?
Ive tried this method but still nothing im finding it rather annoying because nothings happening
My tablet does turn on I can hear the sound but the screen is just to a navy blue paralyzed state I don't know what to do I am leaving New York on Wednesday and I need it to work now or tomorrow please help
not turning on I don't know why
このアンサーは役に立ちましたか?
The problem is apparently that if the tablet totally discharges; then is restarted before the battery has charged, it will not reboot
My solution is to
1) Totally discharge the tablet - I used an elastic back around the tablet tight enough to hold the power button down
2) Charge the tablet - to be safe, I'd suggest an hour
3) Power on and voila
このアンサーは役に立ちましたか?
Look for youtube video on this topic.
You basocally need to:
1 open back cover and disconnect battery flex cable
2. wait a while
4.put back cover and connect original wall charger and *charge to at least 30%
Every thing should work from now!
このアンサーは役に立ちましたか?
May or may not be related but I had a charging issue too with my Lenovo Tab 2 1051F, was about to give up after a couple months that I was unable to resolve. Luckily I landed on a forum that mentioned to be sure to use only the original charger AND cable that was supplied with the tab. I went on a hunt to find them and sure enough it was charging again and all is well. If you don’t know where you put both just buy a replacement.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 24
過去 30 日: 85
今までの合計 64,293
6 件のコメント
I purchased my tablet 1-09-17. nd used it maybe 5 times and i went to turn in aweek ago and it will not come on at all. I cant see the charging light on at all but it was fully charged before it wouldn't come on i have my bank statement witg the purchased fr Wal-Mart because i cant find receipt or box and i need the tablet for school what do u recommend
gwen whitley さんによる
Why do my tablet lenovo S6000 always block on the lenovo logo when switched on?
Need help very quickly….
I must used my tablet for an essential work.
Nemours Wayne さんによる
Have a similar problem. I have a 2017 yoga tab 3 10" was using it and suddenly it shut off. Battery was at 65% no lights, no vibration, no noise, no nothing. It is totally dead. I removed the case and checked every connector. Diconnected the battery blah . Tried every combo of power button tricks in the book. Nothing at all works. Any ideas apart from it's rooted? TIA
rwilliams2994 さんによる
my tab turns on but it won't leave that page for me to go in any thing it's like it freezes
dougpogue62 さんによる
My tablet has the white on orange Lenovo logo on a black screen and says Qualcomm snapdragon at the bottom of the screen plus a circular orange and white logo. I can persuade it to start the booting process and various pictures replace the Lenovo logo and it plays a little tune - normal start up sequence. But then it returns to the state described above. I have tried any amount of pressing power button for several tens of seconds.
rogeranddeborah さんによる
1以上のコメントを表示
