メインコンテンツにスキップ
The Visual Land Prestige Elite 8Q is an 8-inch Android tablet produced by Visual Land.
My tablet screen is broken and it won't turn on.
It has a cracked screen and when I hold the power button, It doesn't show me a battery or the prestige logo.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Well you need to know if the screen is broken or the device itself is broken. First check and see if the device still turns on. If it makes a sound or vibrates. then your device is still alive.
IF you are positive that the device is ON and the screen dosent show anything then you would probably have to change the LCD.
If you are doing the repair by yourself then try disconnecting the LCD and Reconnected it and see if it works. If not then you need to replace the LCD/Screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joshua Feaster さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 104
