メインコンテンツにスキップ
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
20回答 すべてを表示
Why can't I flash bios with black screen of death?
Black screen of death...bios trick not working for me. I see many others had this problem. But i never see a fix for the people that arent able to flash bios? The little battery inside is bad maybe? What all can it be? External display does not work either....please someone find a fix for me!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント
To begin with, which instructions did you follow exactly? Did you follow the correct or incorrect rections? I guess it dont matter cuz neither of them worked huh? None the less here is the real instructions......or rections, if you prefer. "............................................................." ok, im lost. Im talking to myself. I may just put this lil puter through a wall and into a waste disposal unit. Ohhhhh my goooood this is good shiz. Im lit out my mind.....still needing help on this guys!!!!!
さんによる
StickitRickit, did anything happen to your Acer? Why do you think that this is a BIOS issue??
さんによる
ummm still around turkey? I dont think anything specifically. I just hoped it was a bios issue. I changed the RAM one day. May have been the wrong RAM. IT was a 5300s 2gb chip. Then a couple weeks go by without noticing any performance increase or decrease. My friend comes over all lit and dumb and pulls the acer off its desk and !FLOP! to the floor it went. It was still on and running fine. It worked for a few more days but I notice the performance is lacking moderately since it fell. I open it up to check the RAM chip is still in place and it was, put it back together and here i am. I may have pulled a lil tiny wire lose that connect momma board to the screen. but i cant imagine its my fault. i opened the thing up sooooo many times learning on it. thanks and sorry it takes me so long. i pay attention if you comment back now
さんによる
Acer suffer from death by update mine was just 13 month old anything over warranty date is a bonus my sister's one lasted 14 months, I've tried every option in the blue screen menu, and the boot order cannot be changed the bios such as it is has M2523 in it and arrow keys don't work these things are junk and the customer service just directs you to their self help forums.
Don't but this cheap self distruct Asian crap!
さんによる
コメントを追加
7件の回答
ベストアンサー
Hi, Here is a link to a service manual for your unit. Good luck.
http://tim.id.au/laptops/acer/aspire%20o...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hope so gonna do it!
さんによる
コメントを追加
最も参考になった回答
Thats easy:
get 3309.fd from e.g.
http://en.kioskea.net/forum/affich-95127...
rename it to ZG5IA.FD and put it on an USB-stick.
Switch your ZG5 off, put the USB-stick into the slot at the left side.
press "FN" + "ESC", keep it pressed;
press "Power ON"
release "FN" + "ESC"
Power LED will blink for 1/2 min. wait until stop blinking.
after that: switch off ZG5, pull out USB-Stick;
Power ON: yuppi!
Gruesse aus D: Axel Paulien
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Tried your method and doesnt work
さんによる
Plug in usb drive and hold fn+esc key on acer aspire one zg5 aoa150 and press the power key and the power light been blinking all the way for 30 mins and does nothing.tried battery plug in or without battery also doesnt work.what is the problem.
さんによる
コメントを追加
acer aspire 7745g not booting plase helfe
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
ACER ASPIRE 5734z not booting.. when i press power button. no light indicator on it! help please.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Got to acer drivers and manual section and find your acer laptop through its model number and download the bios for your laptop. when you open the folder you downloaded there will be a folder named "dos" open it and copy the files "FLASHIT" and the file with either a ".bin " or ".fn" extension, for example "P4LJ0112.bin" to a flash drive formatted in either FAT or FAT32 extension.
*Plug your laptop to a power source
  • plug in the flash drive with the files in it to the laptop
  • Press and hold the FN + ESC keys and press the power on button
  • when the laptop powers on press and hold the FN + ESC keys for 7 seconds and let it go
  • The Power button will start to flash leave it as it, will take about 10-20 minutes
  • If the laptop turns it self off after, remove the flash drive and power it on.
You should have your laptop up and running again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
please help me i have a aspire 5530 and the bios files are only flash32.exe and flash 64.exe . i dont have a .fd file?? please help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
OMFG I was trying everything possible with no success..until I replaced BIOS battery and the computer miraculously turned on!!!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hello from the future. I made an account just to thank you for providing another solution. I plan on trying to swap the CMOS battery later and testing.
さんによる
コメントを追加
回答を追加する
StickitRickit さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 19
過去 30 日: 34
今までの合計 54,943
