メインコンテンツにスキップ
« 全てのストーリーへ戻る
Great Product - Quick Fix
Anthony Capozzolo -
iPhone 6
ストーリー画像
iPhone 6 Battery Replacement
45分
Moderate
問題
My iPhone 6 battery had reached its limit and was going dead in about 2-3 hours worth of use.
修理
The repair went great. It does require a certain amount of technical skill in terms of not being afraid to take apart an electronic device; removing very tiny screws (and you need to put the same screws back in the same place b/c they are not all the same size!); and disconnecting the screen and battery which requires using tweezers to detach a number of delicate cables.
アドバイス
Be careful placing the new battery; you need to leave a very tiny amount of extra room of the long side of the battery that faces the center of the battery because the connector that attaches the battery to the phone has a cable that requires it to lie next to the battery -- if you don't leave any room you will have to move the battery, which is impossible once the adhesive strips stick to the inside of the phone when you place the new battery in the phone.
iPhone 6 Batteryの画像
iPhone 6 Battery
$29.99
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 4
今までの合計 73
