メインコンテンツにスキップ
iPhone SE LCD and Digitizer Replacement
必要な工具と部品
  1. iPhone SE LCD and Digitizer Replacement, Removing the Pentalobe screws: 手順 1、 1の画像 1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.9 mm Pentalobe screws from either side of Lightning connector.
  2. iPhone SE LCD and Digitizer Replacement, Taping the display glass: 手順 2、 3の画像 1 iPhone SE LCD and Digitizer Replacement, Taping the display glass: 手順 2、 3の画像 2 iPhone SE LCD and Digitizer Replacement, Taping the display glass: 手順 2、 3の画像 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  3. iPhone SE LCD and Digitizer Replacement, Display separation prevention: 手順 3、 3の画像 1 iPhone SE LCD and Digitizer Replacement, Display separation prevention: 手順 3、 3の画像 2 iPhone SE LCD and Digitizer Replacement, Display separation prevention: 手順 3、 3の画像 3
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
  4. iPhone SE LCD and Digitizer Replacement, Anti-Clamp instructions: 手順 4、 3の画像 1 iPhone SE LCD and Digitizer Replacement, Anti-Clamp instructions: 手順 4、 3の画像 2 iPhone SE LCD and Digitizer Replacement, Anti-Clamp instructions: 手順 4、 3の画像 3
    この手順で使用する道具:
    Anti-Clamp
    $24.95
    購入する
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use the included tape pad to create a grippier surface.
  5. iPhone SE LCD and Digitizer Replacement: 手順 5、 3の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 5、 3の画像 2 iPhone SE LCD and Digitizer Replacement: 手順 5、 3の画像 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. iPhone SE LCD and Digitizer Replacement, Manual Opening Procedure: 手順 6、 1の画像 1
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
  7. iPhone SE LCD and Digitizer Replacement, Start lifting the front panel assembly: 手順 7、 1の画像 1
    • The front panel is attached with clips, and there are several ribbon cables connecting it to the rest of the phone. Your goal here is to release the clips and open the phone only enough to disconnect the cables. Go slowly and carefully to avoid damage.
    • Make sure the suction cup is firmly attached to the front panel assembly near the home button.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
    • With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
    • Take your time and apply firm, constant force. The front panel assembly is a much tighter fit than on most other devices.
  8. iPhone SE LCD and Digitizer Replacement: 手順 8、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 8、 2の画像 2
    • Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them.
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the screen.
  9. iPhone SE LCD and Digitizer Replacement, Removing the Touch ID cable bracket: 手順 9、 3の画像 1 iPhone SE LCD and Digitizer Replacement, Removing the Touch ID cable bracket: 手順 9、 3の画像 2 iPhone SE LCD and Digitizer Replacement, Removing the Touch ID cable bracket: 手順 9、 3の画像 3
    • Open the phone just enough to reveal the metal bracket covering the home button cable.
    • Do not open the phone too far or you risk damaging the home button cable, or the socket it plugs into. Keep the cable loose—if it is stretched taut, that's too far.
    • Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
    • Use the tip of a spudger to push the bracket free and remove it with tweezers.
    • The next two steps apply to reassembly. Skip them and continue to Step 12 until reassembly.
  10. iPhone SE LCD and Digitizer Replacement: 手順 10、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 10、 2の画像 2
    • During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
    • Slide the top of the bracket over the Touch ID cable connector from left to right.
  11. iPhone SE LCD and Digitizer Replacement: 手順 11、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 11、 2の画像 2
    • During reassembly, use the flat end of a spudger to snap the front portion of the Touch ID cable bracket down over the cable connector.
    • If the bracket does not snap down flush, you may need to remove the bracket and slide it over the cable connector again for a better fit.
  12. iPhone SE LCD and Digitizer Replacement, Disconnecting the home button cable connector: 手順 12、 2の画像 1 iPhone SE LCD and Digitizer Replacement, Disconnecting the home button cable connector: 手順 12、 2の画像 2
    • Use the tip of a spudger to pry the home button cable connector up out of its socket.
    • Be sure you're separating the cable connector from its socket, and not prying the entire socket up. The socket is on its own glued-down cable that can be pried up if you aren't careful.
  13. iPhone SE LCD and Digitizer Replacement, Opening up the phone: 手順 13、 3の画像 1 iPhone SE LCD and Digitizer Replacement, Opening up the phone: 手順 13、 3の画像 2 iPhone SE LCD and Digitizer Replacement, Opening up the phone: 手順 13、 3の画像 3
    • Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  14. iPhone SE LCD and Digitizer Replacement: 手順 14、 1の画像 1
    • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
  15. iPhone SE LCD and Digitizer Replacement: 手順 15、 1の画像 1
    • Remove the metal battery connector bracket from the iPhone.
  16. iPhone SE LCD and Digitizer Replacement: 手順 16、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 16、 2の画像 2
    • Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
  17. iPhone SE LCD and Digitizer Replacement: 手順 17、 1の画像 1
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • One 1.7 mm Phillips #000 screw
    • One 1.2 mm Phillips #000 screw
    • One 1.3 mm Phillips #000 screw
    • One more 1.7 mm Phillips #000 screw
    • This 1.7 mm screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing.
    • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 1.3 mm screw or one of the 1.7 mm screws in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
    • Be careful not to over-tighten the screws, and don't force them. If they don't fit easily when you are securing them, they may be the wrong size.
  18. iPhone SE LCD and Digitizer Replacement: 手順 18、 1の画像 1
    • Remove the front panel assembly cable bracket from the logic board.
  19. iPhone SE LCD and Digitizer Replacement: 手順 19、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 19、 2の画像 2
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable.
  20. iPhone SE LCD and Digitizer Replacement: 手順 20、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 20、 2の画像 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the LCD cable connector.
    • When reassembling your phone, the LCD cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
  21. iPhone SE LCD and Digitizer Replacement: 手順 21、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 21、 2の画像 2
    • Finally, disconnect the digitizer cable connector.
  22. iPhone SE LCD and Digitizer Replacement: 手順 22、 1の画像 1
    • Remove the front panel assembly from the rear case.
  23. iPhone SE LCD and Digitizer Replacement, Earpiece Speaker: 手順 23、 1の画像 1
    • Remove the two screws securing the upper component bracket:
    • 4.0 mm Phillips #000
    • 2.3 mm Phillips #000
    • It is imperative that the right screws are inserted into their respective holes. Otherwise it may cause severe damage to the LCD during reassembly.
  24. iPhone SE LCD and Digitizer Replacement: 手順 24、 3の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 24、 3の画像 2 iPhone SE LCD and Digitizer Replacement: 手順 24、 3の画像 3
    • Orient the phone as shown, with the home button on top and the earpiece speaker on bottom.
    • Gently dislodge the clip, near the bottom left corner of the earpiece speaker bracket, outwards from its recess on the front panel assembly.
    • Do not pry with excessive force, as the earpiece speaker bracket is fragile and malleable.
    • With a set of tweezers, shift the bracket to the left to unclip it.
  25. iPhone SE LCD and Digitizer Replacement: 手順 25、 1の画像 1
    • Remove the bracket from the display.
  26. iPhone SE LCD and Digitizer Replacement: 手順 26、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 26、 2の画像 2
    • Remove the earpiece speaker with a set of tweezers.
    • If you use your fingers, be very careful not to touch the gold contacts on the front panel. Finger oil can prevent good contact.
  27. iPhone SE LCD and Digitizer Replacement: 手順 27、 3の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 27、 3の画像 2 iPhone SE LCD and Digitizer Replacement: 手順 27、 3の画像 3
    • To replace the earpiece speaker, it is easiest to install the speaker and bracket together:
    • Place the earpiece speaker bracket over the speaker so that it fits snugly in its housing.
    • Slide the left hook of the bracket into the notch above the top left corner of the front facing camera.
    • Rotate the bracket so it lays flat on the rear case, aligning the two screw holes. Press the bracket into place, ensuring the hook on the right side of the metal bracket latches onto the display.
  28. iPhone SE LCD and Digitizer Replacement, Front Facing Camera and Sensor Cable Assembly: 手順 28、 1の画像 1
    この手順で使用する道具:
    iOpener
    $19.99
    購入する
    • This step requires removing the front facing camera and sensor cable from your front panel assembly.
    • The front facing camera and sensor cable is adhered to the display assembly with mild adhesive.
    • Using an iOpener to soften the adhesive will help safely remove it. Follow our iOpener instructions to use it.
  29. iPhone SE LCD and Digitizer Replacement: 手順 29、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 29、 2の画像 2
    • Using the edge of a set of tweezers or a metal spudger, gently pry the earpiece speaker contact cable up, to separate this portion of the camera and sensor cable from the adhesive below.
    • Only pry directly under the earpiece speaker contacts—there are sensors and microchips that can be damaged by prying elsewhere.
  30. iPhone SE LCD and Digitizer Replacement: 手順 30、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 30、 2の画像 2
    • Use the point of a spudger to lift the ambient light sensor and proximity sensor out of their recess in the display assembly.
    • There is a small, square plastic and metal holder for the proximity sensor. This holder is essential for the proximity sensor to function correctly.
    • If replacing the proximity sensor make sure that the holder remains adhered to the back of the display. If it comes off with the old proximity sensor, remove it from the old sensor and use a tiny bit of adhesive to re-attach it to the back of the display.
  31. iPhone SE LCD and Digitizer Replacement: 手順 31、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 31、 2の画像 2
    • Use the flat end of a spudger to gently peel the front-facing camera portion of the cable away from the display assembly.
  32. iPhone SE LCD and Digitizer Replacement: 手順 32、 3の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 32、 3の画像 2 iPhone SE LCD and Digitizer Replacement: 手順 32、 3の画像 3
    • If you are reattaching the same shield plate to a new display, there is no need to peel the cable assembly off the LCD shield plate. Skip this step.
    • Carefully peel the cable assembly off of the LCD shield plate to remove it from the display.
    • Be careful not to grab the digitizer cable while peeling up the front facing camera and sensor assembly cable.
  33. iPhone SE LCD and Digitizer Replacement, Home Button Assembly: 手順 33、 2の画像 1 iPhone SE LCD and Digitizer Replacement, Home Button Assembly: 手順 33、 2の画像 2
    • Unscrew the single captive Phillips #000 screw securing the home button cable.
    • The captive screw is fastened to the home button cable by a spring contact backing. During reassembly, ensure the contact is in the correct orientation—on the side of the screw nearest the LCD.
    • If your replacement part does not have this captive screw and spring contact, you will need to transfer them to the new cable.
  34. iPhone SE LCD and Digitizer Replacement: 手順 34、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 34、 2の画像 2
    • Fold the home button cable down, out of the way of the home button bracket.
  35. iPhone SE LCD and Digitizer Replacement: 手順 35、 1の画像 1
    • Remove the two 1.4 mm Phillips #000 screws from the home button bracket.
  36. iPhone SE LCD and Digitizer Replacement: 手順 36、 1の画像 1
    • Remove the home button bracket from the display assembly.
  37. iPhone SE LCD and Digitizer Replacement: 手順 37、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 37、 2の画像 2
    • Wedge the the tip of a spudger underneath the home button cable assembly.
    • The home button cable is affixed by mild adhesive.
    • Gently work the spudger underneath the cable to separate the home button cable from the front panel assembly.
    • Do not remove the home button yet, as it is still attached to the front panel assembly.
  38. iPhone SE LCD and Digitizer Replacement: 手順 38、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 38、 2の画像 2
    • If necessary, remove the tape over the home button on the front side of your cracked front panel assembly.
    • Gently push the top left corner of the home button up away from the front panel.
    • Do not push the home button all the way through—you only need to get a corner free, so that you can pry it free with a spudger.
    • This membrane is very thin. If you feel like you're going to tear the button, apply heat and try again.
  39. iPhone SE LCD and Digitizer Replacement: 手順 39、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 39、 2の画像 2
    • Peel the home button the rest of the way off of the display by prying gently with a spudger.
  40. iPhone SE LCD and Digitizer Replacement: 手順 40、 1の画像 1
    • Remove the home button assembly from the front panel.
  41. iPhone SE LCD and Digitizer Replacement, LCD and Digitizer: 手順 41、 1の画像 1
    • Remove the 2.7 mm Phillips #000 screw from the back of the display assembly.
  42. iPhone SE LCD and Digitizer Replacement: 手順 42、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 42、 2の画像 2
    • Remove two 1.2 mm Phillips screws from each side of the LCD frame (four total).
    • To avoid stripping the final screw, it may be helpful to first slightly loosen all four screws before removing any.
  43. iPhone SE LCD and Digitizer Replacement: 手順 43、 2の画像 1 iPhone SE LCD and Digitizer Replacement: 手順 43、 2の画像 2
    • Remove the LCD shield plate from the display assembly.
    • The LCD and digitizer remains.
終わりに
120 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,777 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
7 件のコメント
Endlich eine detaillierte Anleitung mit sehr genauen Angaben und ohne selbstlobendes überflüssiges Geschreibe. Mit dieser Anleitung kann jeder mit dem notwendigen Feingefühl die Reparatur durchführen.
traductor - 返信
Have issues after a couple days. I replaced the screen according to instructions and started up well. Screen started having issues and within a few minutes screen showed likes and faded to black.
Brian Mings - 返信
This will be the screen that you have purchased, or due to a faulty repair…Not due to the guide.
Kyle Webb -
Hi, thanks in advance for your support! I managed to detach the digitizer from the LCD after a small drop, thus I bought a replacement screen from ifixit… unfortunately resulting in a very bad quality aftermarket piece. Dimmed luminosity, changes in temperature(color), and affected by polarized glass, which I wear. I already reclaimed this to Ifixit and I`m waiting for support, but I thought to pick up my broken original display and glue back the digitizer, is that possible, or is this shown in any guide here around??
Thanks again!
Stoni - 返信
STEPS 9-12 need a re-working - Re-assembly instructions should be put just under the disassembly instructions so that when you scroll back up the page, you’re re-assembling in step order ;)
Ashley Lahm - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 102
過去 30 日: 509
今までの合計 132,603
