メインコンテンツにスキップ
iPhone 6s Speaker Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. iPhone 6s Speaker Replacement, Speaker: 手順 1、 2の画像 1 iPhone 6s Speaker Replacement, Speaker: 手順 1、 2の画像 2
    • Use the point of a spudger to lift and disconnect the antenna cable from the bottom end of the logic board.
    • To reconnect antenna cables like these to the socket, carefully align the connector to the socket, then use the flat end of a spudger to press down. It should click in place. If not, check for alignment. Do not use excessive force.
  2. iPhone 6s Speaker Replacement: 手順 2、 2の画像 1 iPhone 6s Speaker Replacement: 手順 2、 2の画像 2
    • Use the point of a spudger to lift up and disconnect the Lightning connector ribbon cable from its socket on the logic board.
  3. iPhone 6s Speaker Replacement: 手順 3、 2の画像 1 iPhone 6s Speaker Replacement: 手順 3、 2の画像 2
    • If you are following this guide to replace the Lightning connector, you can choose to keep the antenna cable connected and skip the next two steps. Be very careful not to strain the delicate antenna cable when you move the loudspeaker around.
    • Use the point of a spudger to lift and disconnect the antenna cable from its socket near the top of the logic board.
  4. iPhone 6s Speaker Replacement: 手順 4、 3の画像 1 iPhone 6s Speaker Replacement: 手順 4、 3の画像 2 iPhone 6s Speaker Replacement: 手順 4、 3の画像 3
    • Carefully lift the antenna cable and de-route it from the edge of the phone. Use the point of a spudger to help lift the cable to free it from the retaining clips.
    • If the cable does not have enough room to lift up, loosen this Phillips screw securing the logic board so that the board can give more wiggle room.
    • Be sure to re-tighten this screw during re-installation.
    • During re-installation, be sure to route the antenna cable underneath the logic board corner.
    • During re-installation, you can also re-insert the SIM card tray after re-routing the antenna cable.
    • If you feel any resistance, stop and make sure that the tray isn't snagging the antenna cable.
  5. iPhone 6s Speaker Replacement: 手順 5、 1の画像 1
    • Remove the following Phillips screws securing the speaker to the rear case:
    • Two 2.6 mm screws
    • One 2.3 mm screw
    • One 2.3 mm screw
    • This screw is different from the prior one. Be sure not to mix the two together.
    • One 3.0 mm screw
  6. iPhone 6s Speaker Replacement: 手順 6、 3の画像 1 iPhone 6s Speaker Replacement: 手順 6、 3の画像 2 iPhone 6s Speaker Replacement: 手順 6、 3の画像 3
    • Insert the flat end of a spudger between the long edge of the speaker module and the case wall.
    • Pry gently to loosen the speaker module.
    • Once the module is loose, lift and remove the speaker module from the phone.
終わりに
作成者
2人の作成者と共同で作成されました。
Arthur Shi
メンバー登録日: 01/03/18
252,816 ポイント
526のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 250
