はじめに
Lightningコネクタとヘッドフォンジャックケーブルを交換するにはこのガイドをご利用ください。
ビデオの概要
プラスチックのデプスゲージが iSclack中央に挟まっている場合は外してください。 iPhone 6 Plusのような大型のデバイスには必要ありません。
iSclackのハンドルを閉じ、吸盤カップを開きます。
iPhone下部本体を吸盤カップの間に配置します。
ハンドルを開いてiSclackの両カップを閉じます。吸盤カップをiPhoneの両側にしっかりと取り付けます。
バックガラスもしくはディスプレイの飛散状況が酷い場合は、透明な梱包用テープで表面を覆ってから吸盤カップを装着してください。iSclackには、このような目的で使用するためのテープが2枚入っています。
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
134 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
24 件のコメント
I did this tonight, took about 45 min. I used my iFixit tool kit to all the work.
When putting it back together I had an issue with my screen going all "white lines", turns out it was just a loose connection on the digitizer cable, I lifted it and placed it again and all is good with the world.
I had to replace the assembly because I was getting feedback when making calls with headphones and no voice at all with headphones if the phone was plugged into power. Now I can do both.
Thanks so much iFixit for making this possible.
rianrachel - 返信
After fixing my headset jack successfully, people could not hear me clearly on the mic. I took it apart again today. The clip that holds the mic in place, next to the jack, had been put down too tight to the mic, which kept it from moving enough to pick sound up clearly -- everything was muddied. I only had to pull the case open a little, unscrew the mic assembly to loosen it, wiggle it back a bit, move the mic a little to align it better with the hole, and then tighten it back down. It works beautifully now and everyone says I sound better than ever. A really easy fix, but it could have been avoided if there were instructions on putting everything back together or at least tips for little things like this.
My iphone stuck into headphone,what can i do to fix it?please help me as soon as possible
Hi @Tannaz pourian
If you are stuck on headphone mode first thing you can do is a quick fix if it works for you. You first turn off your iphone and with a gentle hand you can pull out any dirt or particals inside your headphone jack with a pin then clean it with a cotton bud with a little acitone or alcohol ( Don’t use too much of alcohol only little would be fine otherwise it could damage you display if it gets into your phone). Then after completing this process let it dry for a while and turn on your phone. I hope it works for you:) orthewise you have to replace your whole cc flex pannel. Good luck
I recently replaced the headphone jack but when I tried it out after successfully replacing it, the headphones still gave a crackling sound. Less than before but still very noticeable. Anyone have any suggestions to fix this issue?
