メインコンテンツにスキップ
iPhone 5 Home Button Ribbon Cable Replacement
必要な工具と部品
  1. iPhone 5 Home Button Ribbon Cable Replacement, Taping the display glass: 手順 1、 3の画像 1 iPhone 5 Home Button Ribbon Cable Replacement, Taping the display glass: 手順 1、 3の画像 2 iPhone 5 Home Button Ribbon Cable Replacement, Taping the display glass: 手順 1、 3の画像 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. iPhone 5 Home Button Ribbon Cable Replacement, Remove the Pentalobe screws: 手順 2、 1の画像 1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
  3. iPhone 5 Home Button Ribbon Cable Replacement, How to prevent display separation: 手順 3、 3の画像 1 iPhone 5 Home Button Ribbon Cable Replacement, How to prevent display separation: 手順 3、 3の画像 2 iPhone 5 Home Button Ribbon Cable Replacement, How to prevent display separation: 手順 3、 3の画像 3
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
  4. iPhone 5 Home Button Ribbon Cable Replacement, Anti-Clamp instructions: 手順 4、 3の画像 1 iPhone 5 Home Button Ribbon Cable Replacement, Anti-Clamp instructions: 手順 4、 3の画像 2 iPhone 5 Home Button Ribbon Cable Replacement, Anti-Clamp instructions: 手順 4、 3の画像 3
    この手順で使用する道具:
    Anti-Clamp
    $24.95
    購入する
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 5 Home Button Ribbon Cable Replacement: 手順 5、 3の画像 1 iPhone 5 Home Button Ribbon Cable Replacement: 手順 5、 3の画像 2 iPhone 5 Home Button Ribbon Cable Replacement: 手順 5、 3の画像 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. iPhone 5 Home Button Ribbon Cable Replacement, Manual Opening Procedure: 手順 6、 1の画像 1
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    • If you're opening an iPhone with cracked glass, neatly lay a couple strips of packing tape across the front and squeeze out as many bubbles as you can. This will give the suction cup a surface to grab, and minimize the spread of broken glass.
  7. iPhone 5 Home Button Ribbon Cable Replacement, Start lifting the front panel assembly: 手順 7、 1の画像 1
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The screen is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  8. iPhone 5 Home Button Ribbon Cable Replacement, Detaching the front panel side clips: 手順 8、 1の画像 1
    • Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
  9. iPhone 5 Home Button Ribbon Cable Replacement, Opening up the phone: 手順 9、 3の画像 1 iPhone 5 Home Button Ribbon Cable Replacement, Opening up the phone: 手順 9、 3の画像 2 iPhone 5 Home Button Ribbon Cable Replacement, Opening up the phone: 手順 9、 3の画像 3
    • Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
    • Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  10. iPhone 5 Home Button Ribbon Cable Replacement, Removing the battery connector bracket screws: 手順 10、 1の画像 1
    • Remove the following two screws securing the metal battery connector bracket to the logic board:
    • One 1.8 mm Phillips screw
    • One 1.6 mm Phillips screw
  11. iPhone 5 Home Button Ribbon Cable Replacement, Removing the battery connector bracket: 手順 11、 1の画像 1
    • Remove the metal battery connector bracket from the iPhone.
  12. iPhone 5 Home Button Ribbon Cable Replacement, Disconnecting the battery connector: 手順 12、 1の画像 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
  13. iPhone 5 Home Button Ribbon Cable Replacement, Removing the front panel assembly cable bracket screws: 手順 13、 1の画像 1
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.2 mm Phillips screws
    • This screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing, and make sure it gets back into the right place—a magnetized screw may interfere with the compass.
  14. iPhone 5 Home Button Ribbon Cable Replacement, Removing the front panel assembly cable bracket: 手順 14、 2の画像 1 iPhone 5 Home Button Ribbon Cable Replacement, Removing the front panel assembly cable bracket: 手順 14、 2の画像 2
    • Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
    • During reassembly, clip the left-hand hooks under the logic board and lower the bracket towards the outside of the phone.
  15. iPhone 5 Home Button Ribbon Cable Replacement, Disconnecting the front panel assembly cables: 手順 15、 3の画像 1 iPhone 5 Home Button Ribbon Cable Replacement, Disconnecting the front panel assembly cables: 手順 15、 3の画像 2 iPhone 5 Home Button Ribbon Cable Replacement, Disconnecting the front panel assembly cables: 手順 15、 3の画像 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
    • Front-facing camera and sensor cable
    • LCD cable
    • Digitizer cable
    • When reassembling your phone, the LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
  16. iPhone 5 Home Button Ribbon Cable Replacement, Separating front panel assembly and rear case: 手順 16、 1の画像 1
    • Remove the front panel assembly from the rear case.
  17. iPhone 5 Home Button Ribbon Cable Replacement, Home Button Ribbon Cable: 手順 17、 1の画像 1
    • Remove the two 1.3 mm Phillips #000 screws securing the home button bracket to the display assembly.
    • NOTE: When reinstalling the two 1.3 mm Phillips #000 screws, take care not to over tighten them as they can penetrate the other side of the display.
  18. iPhone 5 Home Button Ribbon Cable Replacement: 手順 18、 2の画像 1 iPhone 5 Home Button Ribbon Cable Replacement: 手順 18、 2の画像 2
    • Use a plastic opening tool to pry the edge of the home button ribbon cable up from the display assembly.
    • Start on the right, at the area of the ribbon cable between the gold contact points, and work to the left.
    • Going left to right may rip your ribbon cable as the contacts are well adhered to the front panel.
    • Prying directly at one gold contact point or the other may break its soldering and pop it off the ribbon cable.
    • If you have trouble sliding the plastic opening tool under the contact points, flip the tool over and gently push against the right side of the contacts to loosen the adhesive, then try again.
終わりに
161 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
Brett Hartt
メンバー登録日: 04/12/10
127,941 ポイント
143のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,299のガイドは作成済み
3 件のコメント
You had mentioned the phone running hot if the battery wasn't disconnected in the correct sequence, how is this resolved? Also, the phone after lcd assembly replacement is unresponsive, I have gotten a dinging sound that repeats but nothing on the screen...iTunes recognizes the phone but I get nothing on the screen, I've tried reassembling several times with no luck, this is not my phone, I've done many repairs on iphones in the past
and never had this problem...please help, it's an iphone 5s
mattadki - 返信
what kind of adhesive is used on the home button cable - the one with two metallic spherical plates that face the inside of the phone?
Ajaz Karim - 返信
one of the screws on the home button is unscrew-able and i had to get my dad to do it and he could not even do it, im replacing the one on my old iphone to my new replacement screen and know one had ever touched it before, any ideas on what i can do?
gabegoulette - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 55
今までの合計 101,714
