メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhone 15 Pro Front Camera Assembly Replacement
必要な工具と部品
  1. iPhone 15 Pro Front Camera Assembly Replacement, Prepare your iPhone for disassembly: 手順 1、 2の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Prepare your iPhone for disassembly: 手順 1、 2の画像 2
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
  2. iPhone 15 Pro Front Camera Assembly Replacement, Tape over any cracks: 手順 2、 2の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Tape over any cracks: 手順 2、 2の画像 2
    • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: 手順 3、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: 手順 3、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: 手順 3、 3の画像 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Pro Front Camera Assembly Replacement, Remove the pentalobe screws: 手順 4、 2の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Remove the pentalobe screws: 手順 4、 2の画像 2
    • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
  5. iPhone 15 Pro Front Camera Assembly Replacement, Heat the bottom edge: 手順 5、 1の画像 1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: 手順 6、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: 手順 6、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: 手順 6、 3の画像 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Pro Front Camera Assembly Replacement, Screen information: 手順 7、 1の画像 1
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  8. iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: 手順 8、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: 手順 8、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: 手順 8、 3の画像 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Pro Front Camera Assembly Replacement, Heat the right edge: 手順 9、 1の画像 1
    • Heat the right edge of the screen until it's hot to the touch.
  10. iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: 手順 10、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: 手順 10、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: 手順 10、 3の画像 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  11. iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: 手順 11、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: 手順 11、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: 手順 11、 3の画像 3
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
  12. iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: 手順 12、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: 手順 12、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: 手順 12、 3の画像 3
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  13. iPhone 15 Pro Front Camera Assembly Replacement, Heat the top edge: 手順 13、 1の画像 1
    • Heat the top edge of the screen until it's hot to the touch.
  14. iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: 手順 14、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: 手順 14、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: 手順 14、 3の画像 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
  15. iPhone 15 Pro Front Camera Assembly Replacement, Heat the left edge: 手順 15、 1の画像 1
    • Heat the left edge of the screen until it's hot to the touch.
  16. iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: 手順 16、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: 手順 16、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: 手順 16、 3の画像 3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
  17. iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: 手順 17、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: 手順 17、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: 手順 17、 3の画像 3
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access its cables without straining them.
  18. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the logic board cover: 手順 18、 2の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the logic board cover: 手順 18、 2の画像 2
    • Use a Y000 screwdriver to remove the six screws securing the logic board cover:
    • Four 1.6 mm‑long screws
    • Two 1.3 mm‑long screws
  19. iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: 手順 19、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: 手順 19、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: 手順 19、 3の画像 3
    • Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
    • During reassembly, make sure the top left corner of the cover goes under the ambient light sensor cable.
  20. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: 手順 20、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: 手順 20、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: 手順 20、 3の画像 3
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  21. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the screen: 手順 21、 2の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the screen: 手順 21、 2の画像 2
    • Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
  22. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the ambient light sensor: 手順 22、 2の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the ambient light sensor: 手順 22、 2の画像 2
    • Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
    • Lift the cable to disconnect it.
  23. iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen: 手順 23、 2の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen: 手順 23、 2の画像 2
    • Remove the screen.
    • During reassembly, follow this guide to apply new adhesive and install your screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
  24. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: 手順 24、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: 手順 24、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: 手順 24、 3の画像 3
    • Use the tip of an opening pick to pry up and disconnect the three rear camera press connectors from the top right of the logic board.
    • The third connector is hidden beneath the top one—lift the top cable slightly to reveal the third connector.
  25. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the rear cameras: 手順 25、 2の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the rear cameras: 手順 25、 2の画像 2
    • Use a Phillips #000 screwdriver to remove the three screws securing the rear cameras:
    • One 3.8 mm‑long screw
    • One 3.2 mm‑long screw
    • One 2.8 mm‑long screw
  26. iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: 手順 26、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: 手順 26、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: 手順 26、 3の画像 3
    • Be careful not to touch or smudge the camera lenses during this step.
    • Insert the point of a spudger between the top right corner of the rear cameras and frame.
    • Pry up until you can grab the rear cameras with your fingers.
    • Remove the rear cameras.
  27. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the earpiece speaker: 手順 27、 2の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the earpiece speaker: 手順 27、 2の画像 2
    この手順で使用する道具:
    Standoff Screwdriver for iPhones
    $5.49
    • Use a Phillips #000 screwdriver to remove the 2 mm‑long screw securing the top of the earpiece speaker.
    • Use a standoff screwdriver to remove the remaining screw securing the bottom left corner of the earpiece speaker.
    • If you don't have a standoff screwdriver, you can use a thin flathead one instead. Apply constant, downward pressure to avoid damaging the shallow notches in the screw head.
  28. iPhone 15 Pro Front Camera Assembly Replacement, Remove the earpiece speaker: 手順 28、 2の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Remove the earpiece speaker: 手順 28、 2の画像 2
    • Remove the earpiece speaker.
    • During reassembly, make sure the gasket on the top right corner of the speaker lines up with its recess in the frame.
  29. iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: 手順 29、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: 手順 29、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: 手順 29、 3の画像 3
    • The microphone cable covers the front sensors press connector.
    • Use the tip of an opening pick to disconnect the microphone press connector from the top left corner of the logic board.
    • Lift the cable out of the way so you can access the two press connectors on the logic board's top edge.
  30. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: 手順 30、 3の画像 1 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: 手順 30、 3の画像 2 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: 手順 30、 3の画像 3
    • Use the tip of an opening pick to pry up and disconnect the front sensors and front camera press connectors from the top edge of the logic board.
  31. iPhone 15 Pro Front Camera Assembly Replacement, Remove the front camera assembly: 手順 31、 1の画像 1
    • Remove the front camera assembly.
    • Be careful not to touch or smudge the camera or sensor lenses.
終わりに
To reassemble your iPhone, follow these instructions in reverse order.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Spencer Day
メンバー登録日: 09/14/22
156,409 ポイント
1,033のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,848のガイドは作成済み
1件のガイドコメント
with ios 18, can you use the repair assistant tool to fix faceid? if not is there some sort of device i can use to pair the logic board with the faceid? if not, is my best bet for the front camera and faceid to work again just sending it in to apple for repairs?
Jesse Beckmann - 返信
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 97
過去 30 日: 425
今までの合計 7,803
