はじめに
このガイドを使用して、iPhone 14 の前面カメラアセンブリを取り外したり交換したりすることができます。
このガイドは A2882 (国際) モデルを使用して作成されています。別のiPhone 14モデルを修理する場合、見た目に多少の違いがあるかもしれませんが、手順は同じはずです。
デバイスを再組み立てする際に、画面を再接着するための交換用接着剤が必要です。デバイスは正常に機能しますが、ほとんどの場合、IP(Ingress Protection)等級が失われます。
この部品にはフロントカメラとFace ID関連の部品が含まれています。これらの部品は一体の部品となっており、センサーはロジックボードとペアリングされています。注意:この部品を交換するとFace IDの機能は使えなくなります。この修理によって破損した自撮りカメラは使えるようになりますが、iOS 17.6以前では、AppleかAppleに認定された技術者のみがFace ID機能を回復できます。iOS 18以降では、Appleの修理アシスタントを使用して新しい純正フロントカメラのキャリブレーションを行うことができます。
必要な工具と部品
油性ペンでオープニングピックの先端から3mmの位置にマークを入れます。
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
iPhoneの画面全体に、透明な梱包用テープを重ね合わせます。
次の手順でうまく吸盤が装着しない場合は、強力なテープ(ガムテープなど)を持ち手に折って、代わりにスクリーンを持ち上げてみてください。
この手順で使用する道具:Clampy - Anti-Clamp$24.95
このガイドに従って、付属のテープでスクリーンを固定してください。
青いハンドルをヒンジ側に引くと、リバースクランのアームを解除します。
iPhoneの左/右側の端に向けてアームをスライドします。
吸盤カップをiPhoneの下端付近に装着します。上部に一つ、下部に1つずつ取り付けます。
吸盤カップ両側をしっかりと締め合わせると、標的の場所にしっかりと装着させることができます。
青いハンドルを手前に引くと、アームがロックされます。
ハンドルを時計回りに360度回転させ、カップが両側をストレッチするまで回し続けます。
吸盤の位置が合っていることを確認してください。装着位置がずれ始めたら、吸盤を少し緩めてアームを装着し直してください。
吸盤ハンドルをスクリーンガラスの端ぎりぎりを避けながら、少し開けた端付近に装着します。
吸盤カップをしっかりと一定の力で引き上げて、ケースとリアガラスの間にわずかな隙間を作ります。
隙間にオープニングピックを差し込みます。
ドライヤーでiPhoneの右端(電源ボタンがある方の端)を90秒、または背面ガラスが少し熱くなって触れない程度まで加熱してください。
リアガラスから吸盤ハンドルを外します。
ゆっくりとiPhoneのディスプレイを右側から(本のページをめくるように)開きます。
作業中、ディスプレイが邪魔にならないよう、ディスプレイを立てかけるための衝立てを準備してください。
スクリーンを立てかけるものが手元にない場合は、吸盤ハンドルを利用するとよいでしょう。
この手順で使用する道具:Magnetic Project Mat$19.95
Y000ドライバーを使って、バッテリーのコネクタカバーを固定している、長さ1.3mmネジを2本外します。
この手順で使用する道具:Tweezers$4.99
スパッジャーの先端で、ソケットからバッテリーケーブルのコネクタをこじ開けて外します。
修理中に誤ってソケットに接触し、デバイスに電源が供給されるのを防ぐため、コネクタをロジックボードから少し離して曲げます。
スパッジャーの鋭利側先端を使って、ソケットから2番目の充電コイルケーブルのコネクタをこじ開けて外します。
ピンセットもしくは指で、フロントカメラアセンブリのケーブルブラケットを摘みます。
可能であれば、新しい接着剤を取り付けて再封印する前に、デバイスの電源を入れ、修理をテストしてください。
新しい交換部品を元の部品と比較します。取り付ける前に、残りの部品を移動したり、新しい部品から粘着性のバックを取り除いたりする必要がある場合があります。
デバイスを再組み立てするには、以下の手順を逆にたどってください。
修理後、交換部品によってはiOS 18以降で利用可能になったAppleの修理アシスタント を使ってキャリブレーション(調整)できる場合があります。デバイスをアップデートし、「設定」→「一般」→「情報」→「部品とサービスの履歴」、「再起動して修理を完了」をタップし、画面の指示に従います。
発生した電子機器廃棄物は、地方自治体の指示に従って適切に処理して下さい。
修理が計画通りに進まなかった?基本的なトラブルシューティングを試してみるか、アンサーコミュニティに助けを求めてみてください。
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
2 件のコメント
I replaced the Front Cameras on my iPhone 14 and now it just freezes my camera app when i try to switch from rear to front and use them. I've tired all the trouble shooting I'm able to. Any ideas on what can fix this. I know the part is good its almost as the phone does not want to register it
Do a forced update on itunes and should get camera working
PLEASE remove back first and disconnect battery before taking cables off!! as per Apple instructions
PC Technology Group - 返信
