メインコンテンツにスキップ
iPad Mini 2 LTE バッテリー交換
必要な工具と部品
  1. iPad Mini 2 LTE バッテリー交換, iOpenerの使用方法: 手順 1、 2の画像 1 iPad Mini 2 LTE バッテリー交換, iOpenerの使用方法: 手順 1、 2の画像 2
    • 電子レンジに付着している汚れがiOpenerに付いてしまうことがあるので、使用前に電子レンジの底をきれいに拭き取ってください。
    • iOpenerを電子レンジ中央に置きます。
    • 回転型の電子レンジ:iOpenerが電子レンジのターンテーブルで回転しているか確認してください。iOpenerが作動中に留まってしまうと、熱しすぎや焦げてしまいます。
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - 返信
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - 返信
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - 返信
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - 返信
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - 返信
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - 返信
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - 返信
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - 返信
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - 返信
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - 返信
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - 返信
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 返信
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - 返信
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    trebor65 - 返信
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - 返信
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - 返信
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - 返信
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - 返信
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - 返信
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - 返信
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - 返信
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - 返信
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - 返信
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - 返信
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - 返信
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - 返信
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - 返信
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - 返信
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - 返信
    Can’t you just use a hair curler instead?
    Aspect22 - 返信
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - 返信
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    Dan Smith - 返信
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    Dan Smith - 返信
    My iOpener got damaged at the first heating (30 s @ 800 W). The bag got a little melted hole where the liquid came out and a little melted area. I used a combination oven (normal heat and microwave) in microwave only mode. It has a metal grill where the iOpener was placed on. I suppose the metal grill concentrates the microwaves at some points and there the bag melted?
    K. Fe - 返信
  2. iPad Mini 2 LTE バッテリー交換: 手順 2、 1の画像 1
    • iOpenerを30秒温めます。
    • お使いの電子レンジの出力ワット数によって、温めるために必要な時間が異なる可能性があります。iOpenerを使う際は、素手ではぎりぎり触れない程度に温めれば十分です。
    • 修理作業中はiOpenerが冷めてしまいますので、使用毎に電子レンジに30秒入れて温めてからご利用ください。
    • 作業中、iOpenerを温めすぎないようにご注意ください。過熱すると、iOpenerが破裂することがあります。100˚Cを超えるまで加熱しないでください。
    • 膨らんでいる状態のiOpenerは絶対に触らないでください。
    • 適切に温められたiOpenerは約10分間、温かい状態を保ちます。
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - 返信
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - 返信
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - 返信
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - 返信
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - 返信
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - 返信
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - 返信
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - 返信
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - 返信
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - 返信
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - 返信
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - 返信
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - 返信
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 返信
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    Dennis - 返信
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - 返信
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - 返信
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - 返信
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - 返信
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - 返信
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - 返信
    I had a rotating plate microwave for my repair, and heating the iOpener 30-40 seconds worked plenty well for me.
    Ciarán - 返信
    I tried 600W microwave for 30 sec and it was nicely warm, did nothing on iPad. Added 10 more sec, bit warmer, another 20 sec and it was finally a bit hot to hot in the hand - but still didn't do anything on iPad. I switched to a hair dryer as I used to work with it before, while being a bit sad about not using this brand new iOpener tool. And I found it short on 12.9 iPad anyway, maybe next time.
    Liibo - 返信
  3. iPad Mini 2 LTE バッテリー交換: 手順 3、 1の画像 1
    • 電子レンジからiOpenerを取り出します。iOpenerの中央は熱くなっているため、両端の平面になっている部分を持ってください。
    • iOpenerは大変熱くなっていることがあります。必要であれば、オーブン用のミトンカバーをご利用ください。
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - 返信
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    breadandbits - 返信
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - 返信
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - 返信
    This thing melts when placed up side down in the microwave…
    Mark - 返信
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - 返信
  4. iPad Mini 2 LTE バッテリー交換, iOpenerを使った他の温熱方法: 手順 4、 2の画像 1 iPad Mini 2 LTE バッテリー交換, iOpenerを使った他の温熱方法: 手順 4、 2の画像 2
    • 電子レンジがない場合は、熱湯の中にiOpener をいれて温める方法もあります。
    • 鍋を十分な量のお湯で満たして、iOpener を完全に沈めます。
    • お湯を沸かして熱くなったら火を止めます
    • iOpenerを熱湯の中に約2−3分間沈めます。iOpener全体が完全に浸かっているか確認してください。
    • トングなどを浸かって、温まったiOpenerをお湯から取り出します。
    • タオルでiOpener全体を拭き取ります。
    • iOpenerが非常に熱い場合は、先端のタブを持って火傷をしないようにご注意ください。
    • iOpenerの準備は整いました。iOpenerを再度温める必要がある場合は、お湯を沸騰させて、火を止めてからiOpenerを2-3分間浸してください。
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - 返信
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - 返信
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Robert Garcia - 返信
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - 返信
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - 返信
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - 返信
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
    add a little basil and oregano on the pan peanuts cashews walnuts and bam it pops right off
    david pride - 返信
    It's more 3 minutes than 2 minutes in hot water, in 2 minutes it's not getting hot enough I think. I used the combo iOpener + hair dryer for about 2 minutes and I could then insert a first opening pick easily. The first opening pick is the trickiest step, then if you go slowly and with patience around the screen with other opening picks, it works well.
    vincent becker - 返信
  5. iPad Mini 2 LTE バッテリー交換, LCDシールドプレート: 手順 5、 3の画像 1 iPad Mini 2 LTE バッテリー交換, LCDシールドプレート: 手順 5、 3の画像 2 iPad Mini 2 LTE バッテリー交換, LCDシールドプレート: 手順 5、 3の画像 3
    • ディスプレイガラスに亀裂が入っている場合、それ以上程度が拡大しないようにガラスの表面をテーピングして、人体への危害を防ぎます。
    • 表面全体が覆われるまで、iPadのディスプレイの上に透明なパッキングテープで装着します。
    • この作業により、ガラスの破片が封じ込められ、ディスプレイをこじ開けたり持ち上げたりするときに構造を保つことができます。
    • 修理ガイドのインストラクションに可能な限り従ってください。 ただし、ガラスが割れている状態であれば、作業中に亀裂のエリカが拡大し続ける可能性があります。この場合、メタル製ツールを使用してガラス全体を除去する必要があります。
    • 目を保護するために安全メガネを着用し、LCDによるダメージに注意してください。
  6. iPad Mini 2 LTE バッテリー交換: 手順 6、 1の画像 1
    • 加熱したiOpenerの両側タブを持ち、ホームボタンアセンブリの左側に置きます。
    • iOpenerを約5分間置いて、ガラスの下の接着剤を柔らかくします。
  7. iPad Mini 2 LTE バッテリー交換: 手順 7、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 7、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 7、 3の画像 3
    • 温めた側の中央部分付近に、吸盤カップを装着します。
    • カップが、スクリーン上で水平にしっかりと取り付けてあるか確認してください。
    • iPadを片手で抑えながら、吸盤カップを引き上げて、リアケースからフロントパネルのガラスをわずかに乖離させます。
    • 開口ピックが挿入できるだけのスペースを作るだけで十分です。それ以上外してしまうと、ガラスが割れてしまうことがあります。
  8. iPad Mini 2 LTE バッテリー交換: 手順 8、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 8、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 8、 3の画像 3
    • 吸盤カップでガラスを持ち上げながら、開口ピックの先端をガラスとiPadの本体の間の隙間にスライドして差し込みます。
    • ディスプレイ側面にある黒いベゼル以上深く、開口ピックを挿入しないでください。 ピックを挿入しすぎるとLCDが損傷する可能性があります。
    • 吸盤に付いているプラスチックの突起を引いて、真空シールを外し、ディスプレイアセンブリから吸盤を取り外します。
  9. iPad Mini 2 LTE バッテリー交換: 手順 9、 1の画像 1
    • iOpenerを再度温めて、デバイス上に置きます。
    • 修理作業中、iOpenerを温める際は、オーバーヒートにご注意ください。常に、前回 iOpenerを温めてから少なくとも10分間はあけてください。
    • iPadの左端を再度温めます。
  10. iPad Mini 2 LTE バッテリー交換: 手順 10、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 10、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 10、 3の画像 3
    • 2番目の開口ピックを、最初のピックの横に差し込み、ピックをiPadの端に沿って下にスライドさせて接着剤を剥がします。
    • ガラス下で、上手くピックがスライドしない場合は、作業を停止して再加熱します。 ピックを強制してスライドすると、ガラスが割れる危険があります。
  11. iPad Mini 2 LTE バッテリー交換: 手順 11、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 11、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 11、 3の画像 3
    • 続けて開口ピックをディスプレイのサイドにスライドして、接着剤を切開します。
    • 開口ピックが接着剤で動かない場合、iPadのサイドに沿ってピックを少しずつ動かしながら、接着剤を剥がします。
  12. iPad Mini 2 LTE バッテリー交換: 手順 12、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 12、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 12、 3の画像 3
    • 挿入した最初のピックを取り、iPad上部コーナーに向けてスライドさせます。
    • フロントガラス越しに開口部のピックの先端が見える場合は、慌てる必要はありませんが、開口ピックを少し外側へ引き出してください。 ほとんどの場合、問題はありませんが、LCD前面に接着剤が付着してクリーニングが困難になる可能性があるため、ご注意ください。
  13. iPad Mini 2 LTE バッテリー交換: 手順 13、 1の画像 1
    • iPadの上部端、フロント向きカメラの上に、温めたiOpener を置きます。
    • iOpenerをオーバーヒートしないようにご注意ください。前回iOpener を温めてから10分以上の間隔をあけてください。
    • フレキシブルなiOpenerをお持ちの場合は、左上コーナーと上部端を同時に温めます。
  14. iPad Mini 2 LTE バッテリー交換: 手順 14、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 14、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 14、 3の画像 3
    • 開口ピックをiPadの上部左角周辺にスライドして、接着剤を剥がします。
  15. iPad Mini 2 LTE バッテリー交換: 手順 15、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 15、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 15、 3の画像 3
    • 開口ピックをiPadの上端に沿ってスライドさせ、カメラに到達する直前で止めます。
    • 3枚目の画像は、iPadの前面カメラとハウジングの位置を示しています。
    • 接着剤がレンズに付着したり、カメラが破損したりする恐れがあります。次の手順では、前面カメラの邪魔にならないようにするための最善の方法を説明します。
  16. iPad Mini 2 LTE バッテリー交換: 手順 16、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 16、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 16、 3の画像 3
    • ピックを少し引き出して、先端部分を上端の前面カメラ部分の上に沿ってゆっくりとスライドさせます。
  17. iPad Mini 2 LTE バッテリー交換: 手順 17、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 17、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 17、 3の画像 3
    • iPadに差し込んだ開口ピックは、前面カメラの少し先に差し込んだままにしておきます。
    • 2本目のピックを取り、カメラの左側、1本目のピックがちょうどあった場所に挿入する。残っている接着剤を完全にカットするために、角までスライドさせます。
    • 2本目のピックは、角の接着剤が冷却して再接着するのを防ぐため、その位置に残しておきます。
  18. iPad Mini 2 LTE バッテリー交換: 手順 18、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 18、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 18、 3の画像 3
    • 先に差し込んだままのピックをiPadに深く差し込み、カメラから角に向かってスライドさせます。
    • 右上にある小さなアンテナケーブルに注意してください。ピックをカメラから遠ざけるだけでなく、逆方向にスライドさせると、アンテナケーブルが切れてしまうことがあります。
  19. iPad Mini 2 LTE バッテリー交換: 手順 19、 1の画像 1
    • フロントパネルの接着剤が再付着しないように、iPadの角に3つのピックを残しておきます。
    • iOpenerを温め直し、iPadの残りの長辺、つまり音量ボタンとロックボタンの間に置きます。
  20. iPad Mini 2 LTE バッテリー交換: 手順 20、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 20、 2の画像 2
    • 右上の開口ピックを角に沿ってスライドさせ、ガラスの上端を完全に乖離します。
    • このピックは、接着剤が再装着しないようにその位置に残しておき、次の手順では新しい開口ピックを使用します。
  21. iPad Mini 2 LTE バッテリー交換: 手順 21、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 21、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 21、 3の画像 3
    • 新しい開口ピックを挿入し、iPad右端の中央までスライドさせて、接着剤から剥がします。
  22. iPad Mini 2 LTE バッテリー交換: 手順 22、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 22、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 22、 3の画像 3
    • そのまま開口ピックをiPadの右端全体を滑らせ、接着剤を剥がします。
  23. iPad Mini 2 LTE バッテリー交換: 手順 23、 1の画像 1
    • オープニングピックをそのままにして、iOpenerを再加熱する。
    • iOpenerを温めすぎないように、10分に1回を目安にしてください。
    • 温めたiOpenerをiPadのホームボタン側に数分間当てて、ガラスの下の接着剤を柔らかくします。
  24. iPad Mini 2 LTE バッテリー交換: 手順 24、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 24、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 24、 3の画像 3
    • 左下に残したピックを左下角までスライドして、接着剤を切開します。
    • 角の部分にピックを置いておきます。それ以上はこじ開けず、ピックをiPadから外さないでください。
    • 下部ベゼル下にはスライドを避けるべきパーツが多く搭載されています。3番目の画像をよく見てください。
    • アンテナ
    • ホームボタンの穴
    • デジタイザケーブル
    • 次の手順では、これらのパーツへの破損を避けるために、どこをこじ開けるか指示してあります。熱を加えたり、指示された場所をこじ開けたりしないでください。
  25. iPad Mini 2 LTE バッテリー交換: 手順 25、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 25、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 25、 3の画像 3
    • 接着剤の再接着を防ぐために、前に残した開口ピックはそのままの位置に残してしておきます。
    • 新しい開口ピックを使って、左側のアンテナ上をゆっくりと切開し、ホームボタンの手前で止めます。
    • ピックは外周からiPadの中心に向かって滑らせてください。外周に向かってピックを戻すと、アンテナが破損する恐れがあります。
    • もし、ピックを下の部分に何度もスライドさせる必要がある場合は、ピックを外して外周部に再度挿入し、内側にスライドさせてください。
    • ピックはそのままにして次に進みます。
  26. iPad Mini 2 LTE バッテリー交換: 手順 26、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 26、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 26、 3の画像 3
    • 最後に差し込んだ開口ピックの先端を、前の手順で残したピックの隣に挿入し、ホームボタンの下までスライドさせます。
    • デジタイザーケーブルを切断しないように、右側から約2cm手前で止めます。
    • ピックを少し深めに挿入し、ホームボタンに向かってスライドしていきます。
    • この場合も、ピックが完全に挿入された状態でiPad中央に向かってスライドしてください。ガラスの下にあるアンテナが破損する恐れがあるためです。
  27. iPad Mini 2 LTE バッテリー交換: 手順 27、 1の画像 1
    • iOpenerを再度温めて、iPadの上部ベゼルに置きます。
  28. iPad Mini 2 LTE バッテリー交換: 手順 28、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 28、 2の画像 2
    • この手順は慎重に行ってください。ゆっくりと時間をかけて、開口ピックで接着剤が温まって柔らかいことを確認してください。固くなっている場合は、中断して再度温めてください。
    • iPad上部、ホームボタンの反対側に、それぞれの角にピックが刺さっているはずです。ピックをひねってガラスを少し持ち上げ、4つのエッジに沿って最後の接着剤を分離します。
    • 接着剤にかなりの抵抗がある場合は、捻る作業を中断します。ピックはそのままにして、再加熱し、問題のある部分にiOpenerをもう一度当て、固着した部分にもう一度ピックを通します。
  29. iPad Mini 2 LTE バッテリー交換: 手順 29、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 29、 2の画像 2
    • ゆっくりとかつ慎重に持ち上げて、下端に沿って接着剤をさらに剥がします。
  30. iPad Mini 2 LTE バッテリー交換: 手順 30、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 30、 2の画像 2
    • 全ての接着剤を剥がしたら、本のページをめくるようにフロントガラスを開口し、ワークスペースに置きます。
    • フロントパネルアセンブリを再利用する場合は、ディスプレイ用接着剤を交換する必要があります。ディスプレイ用接着剤の塗布方法ガイドを参照して、ディスプレイ用接着剤を再塗布し、デバイスを再密封してください。
  31. iPad Mini 2 LTE バッテリー交換: 手順 31、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 31、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 31、 3の画像 3
    • 前面カメラのハウジングがフロントパネルに装着することがありますが、ハウジングを剥がしてカメラ上に戻して保護してください。
    • カメラハウジングを片方の端に寄せて、接着剤から乖離して、フロントパネルから取り外します。
    • 前面カメラのハウジングをリアケースの窪みに戻します。
  32. iPad Mini 2 LTE バッテリー交換: 手順 32、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 32、 2の画像 2
    • LCDに留められた次の#00プラスネジを外します。
    • 3.3mmネジ 3本
    • 4.5mmネジ 1本
    • LCDネジを覆っているテープがあれば、ピンセットで剥がします。
  33. iPad Mini 2 LTE バッテリー交換: 手順 33、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 33、 2の画像 2
    • 液晶ディスプレイを完全に取り外さないでください。液晶ディスプレイは、ホームボタン側から数本のケーブルでiPadに接続されています。前面カメラ側の端からのみ持ち上げる。
    • LCDとLCDシールドプレートの間のLCDの下にスパッジャーの平面側を差し込み、ゆっくりと持ち上げます。
    • シールド板の下にスパッジャーを入れないよう十分注意してください。LCDとシールドの間に挟んでください。
    • 少し曲げるだけでもLCDに永久的なダメージを与えてしまうので、細心の注意を払って持ち上げてください。
  34. iPad Mini 2 LTE バッテリー交換: 手順 34、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 34、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 34、 3の画像 3
    • LCDは少量接着剤で固定されています。そのため、シールドプレートからLCDを引き上げる前に接着剤を緩めてください。
    • LCDとLCDシールドプレートの間にスパッジャーを挿入し、iPadの奥までスライドさせます。
  35. iPad Mini 2 LTE バッテリー交換: 手順 35、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 35、 2の画像 2
    • LCDとスピーカーの間には、2本の幅広のテープが張られています。
    • 片手でLCDを持ち、もう片方の手でiPadの背面本体を持ちます。
    • iPadからLCDを完全に取り外さないでください。
    • デジタイザケーブルを引っ張らないように注意しながら、LCDをスピーカーからゆっくりと引き離し、テープを剥がします。
  36. iPad Mini 2 LTE バッテリー交換: 手順 36、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 36、 2の画像 2
    • LCDを完全に取り外さないでください。LCDは、ホームボタン側から数本のケーブルでiPadに接続されています。前面カメラ側の端からのみ持ち上げてください。
    • iPadのLCDを本のページをめくるようにして、カメラ付近を持ち上げ、背面ケースのホームボタン側に回します。
    • 液晶ディスプレイを裏返す際には、液晶ケーブルに気をつけながら慎重に行ってください。
    • LCDをフロントパネルガラスの上に置き、これでディスプレイケーブルにアクセスできます。
  37. iPad Mini 2 LTE バッテリー交換: 手順 37、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 37、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 37、 3の画像 3
    • LCDと接着タブの間にスパッジャーの先端をスライドさせて差し込み、ディスプレイを解放します。
    • ケーブルを傷つけないように注意しながら、2つの接着タブの間を慎重に押してください。
  38. iPad Mini 2 LTE バッテリー交換: 手順 38、 1の画像 1
    • LCDシールドプレートから1.8mm #00プラスネジを7本外します。
  39. iPad Mini 2 LTE バッテリー交換: 手順 39、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 39、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 39、 3の画像 3
    • スパッジャーの平面側先端を使って、iPadからLCDシールドプレートを持ち上げて外します。
    • LCDシールドプレートを取り外します。
  40. iPad Mini 2 LTE バッテリー交換, LCD: 手順 40、 1の画像 1
    • ディスプレイケーブルブラケットから次の#00プラスネジを外します。
    • 2.7mmネジ 1本
    • 1.4mmネジ 2本
  41. iPad Mini 2 LTE バッテリー交換: 手順 41、 1の画像 1
    • iPadからディスプレイケーブルブラケットを取り外します。
  42. iPad Mini 2 LTE バッテリー交換: 手順 42、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 42、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 42、 3の画像 3
    • スパッジャーの平面側先端を使って、ロジックボード上のソケットからバッテリーコネクタを慎重に持ち上げます。
    • ソケットではなく、バッテリーコネクタのみを持ち上げるよう十分注意してください。ロジックボードソケットを持ち上げると、コネクタを完全に壊す可能性があります。
    BE SURE TO DISCONNECT THE BATTERY! If you don’t, when you put it back together the backlight will not light.
    Owen Stevens - 返信
    And be sure to use something to block the connector from falling back and touching the battery connector again - a little tape or foam, or a piece of plastic will hold it safely.
    info - 返信
    When I reassemble the iPad, must I first connect the display and then the battery? or do I have to reverse and connect the battery first and then the display?
    Marco Santoro - 返信
    During reassembly this is where you want to reconnect the battery then power up the device to test. Make sure the LCD, digitizer, home button, etc., are functioning properly BEFORE you seal it up.
    Jeana Morales - 返信
  43. iPad Mini 2 LTE バッテリー交換: 手順 43、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 43、 2の画像 2
    • スパッジャーを使って、ロジックボード上のソケットからLCDコネクタを持ち上げます。
    • コネクタ横の大型ICに触らないようにしてください。破損の恐れがあります。画像で示されているように、慎重にコネクタ側面を持ち上げます。
  44. iPad Mini 2 LTE バッテリー交換: 手順 44、 1の画像 1
    • iPad MiniからLCDを持ち上げて外します。
    Need to add step for disconnecting the plug for digitizer as well
    ajnilges - 返信
  45. iPad Mini 2 LTE バッテリー交換, バッテリー: 手順 45、 2の画像 1 iPad Mini 2 LTE バッテリー交換, バッテリー: 手順 45、 2の画像 2
    • バッテリーはiPadケースに接着剤で固定されているため、温めて柔らかくしてから取り出せます。
    • iOpenerを温めて、iPadケースの裏面中央に載せます。
    • 約2分間置いたら、次はカメラの反対側、iPadの右側端に載せます。
    Hair dryer works just as well. Approx 3 or so minutes oh high.
    Billinski - 返信
    Did not show gow to disconnect touch pannel before removing battery
    T V - 返信
  46. iPad Mini 2 LTE バッテリー交換: 手順 46、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 46、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • 次の手順では、バッテリーとiPadの背面ケースの間に、薄いプラスチックカードをスライドさせて、バッテリーを固定している接着剤を乖離します。 バッテリーを曲げないように、カードをできるだけ平らに保つように注意してください。バッテリーが損傷し、危険な化学物質が放出される可能性があります。
    • iPadを裏返して、ロジックボードと右側スピーカーに近いバッテリーセルの下にプラスチックカードを挿入します。
    • 強い抵抗がある場合は、iOpenerを再度温めて、前の手順を繰り返して、接着剤が柔らかくなるまで待ってください。
    While I successfully replaced the battery I found that removing the original battery was tougher than removing the digitizer. I had to use more force to cut through the adhesive. Pay attention at this stage as you could easily damage the motherboard or surrounding cables.
    mxmbulat - 返信
    Yes this is a bit of a pain, but I did succeed after about 5 minutes.
    I used a standard out of date credit card or equivalent, which is strong and costs nothing.
    Working from the edge nearest the case, as shown above, I managed to get about 1 cm lifted, then apply hairdryer in that gap, directly between battery and case, followed by some brute force with the card to keep sliding, wiggling and prying. Eventually one of the cells is lifted out of the way. More heat with hairdryer on back side of case, then as before slide the credit card hard under the battery, wiggling, eventually getting the whole battery out without damage.
    Billinski - 返信
    working on my wife's 5 year old iPad mini I found more heat needed than suggested, 5 minutes with a hot opener and quite a lot of force. Got the battery out sucessfully. Thanks for the detailed guide, absolutely first class.
    Tim Boycott-Brown - 返信
    Fun Fact: Using IPA helps soften the adhesive, making it easier to cut with a card.
    AAAAAAAA - 返信
  47. iPad Mini 2 LTE バッテリー交換: 手順 47、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 47、 2の画像 2
    • プラスチックカードを取り出し、ケース端付近のバッテリーセルの下に差し込みます。
  48. iPad Mini 2 LTE バッテリー交換: 手順 48、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 48、 2の画像 2
    • 2番目のプラスチックカードを、ロジックボード側のバッテリーセルの下に差し込みます。(フロント向きカメラ付近)
  49. iPad Mini 2 LTE バッテリー交換: 手順 49、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 49、 2の画像 2
    • 2枚目のカードを取り出し、ヘッドホンジャック付近のバッテリーの下に差し込みます。
  50. iPad Mini 2 LTE バッテリー交換: 手順 50、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 50、 2の画像 2
    • 両側のカードを摘み、ケース側のバッテリーセルを背面ケースから約4cm持ち上げます。
    • バッテリーセルを曲げないように、ゆっくりと接着剤を剥がします。
  51. iPad Mini 2 LTE バッテリー交換: 手順 51、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 51、 2の画像 2
    • 右側のカードを、もう一方のバッテリーセルの下にスライドします。
  52. iPad Mini 2 LTE バッテリー交換: 手順 52、 2の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 52、 2の画像 2
    • 他のバッテリーセルの下から左側カードを上方に移動します。
    See my comment in Step 51
    Billinski - 返信
    Billinski - 返信
    Billinski - 返信
  53. iPad Mini 2 LTE バッテリー交換: 手順 53、 3の画像 1 iPad Mini 2 LTE バッテリー交換: 手順 53、 3の画像 2 iPad Mini 2 LTE バッテリー交換: 手順 53、 3の画像 3
    • 両側のカードを摘んで、リアケースからバッテリーを持ち上げます。
    • iPadからバッテリーを取り出します。
    Billinski - 返信
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
28 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
sfukukawaさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
7人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
471,738 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,545のガイドは作成済み
4 件のコメント
This guide is clearly not for the LTE version. There’s no mention of the antenna cable on the top right that I cut because I didn’t know it was there. Also no mention of properly cleaning the old adhesive and installing the new adhesive strips. This guide is only half complete
Will Lyon - 返信
Great guide. Was able to successfully perform a battery swap for a customer. One minor critique: Step 43 is to remove the LCD, then step 44 starts the process to remove the battery. But there are no instructions to remove the digitizer. It’s a small step to remove the digitizer ribbon, but it’s omission did cause me some minor confusion and had me second guessing myself for a few seconds.
Menelik Seth - 返信
My A1490 does not seem to have a LCD shield plate and no apparent screw holes in case to fit one.
Bob Pluck - 返信
Wow this thing is designed to be non-repairable. Thanks apple.
huseyin isbilir - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 30
過去 30 日: 146
今までの合計 19,337
