メインコンテンツにスキップ
iPad 4 Wi-Fiのバッテリーの交換
必要な工具と部品
  1. iPad 4 Wi-Fiのバッテリーの交換, iOpenerの使用方法: 手順 1、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換, iOpenerの使用方法: 手順 1、 2の画像 2
    • 電子レンジに付着している汚れがiOpenerに付いてしまうことがあるので、使用前に電子レンジの底をきれいに拭き取ってください。
    • iOpenerを電子レンジ中央に置きます。
    • 回転型の電子レンジ:iOpenerが電子レンジのターンテーブルで回転しているか確認してください。iOpenerが作動中に留まってしまうと、熱しすぎや焦げてしまいます。
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - 返信
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - 返信
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - 返信
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - 返信
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - 返信
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - 返信
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - 返信
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - 返信
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - 返信
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - 返信
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - 返信
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 返信
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - 返信
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    trebor65 - 返信
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - 返信
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - 返信
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - 返信
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - 返信
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - 返信
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - 返信
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - 返信
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - 返信
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - 返信
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - 返信
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - 返信
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - 返信
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - 返信
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - 返信
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - 返信
    Can’t you just use a hair curler instead?
    Aspect22 - 返信
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - 返信
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    Dan Smith - 返信
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    Dan Smith - 返信
  2. iPad 4 Wi-Fiのバッテリーの交換: 手順 2、 1の画像 1
    • iOpenerを30秒温めます。
    • 修理作業中はiOpenerが冷めてしまいますので、使用毎に電子レンジに30秒入れて温めてからご利用ください。
    • 作業中、iOpenerを温めすぎないようにご注意ください。過熱すると、iOpenerが破裂することがあります。100˚Cを超えるまで加熱しないでください。
    • 膨らんでいる状態のiOpenerは絶対に触らないでください。
    • 適切に温められたiOpenerは約10分間、温かい状態を保ちます。
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - 返信
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - 返信
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - 返信
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - 返信
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - 返信
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - 返信
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - 返信
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - 返信
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - 返信
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - 返信
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - 返信
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - 返信
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - 返信
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 返信
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    Dennis - 返信
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - 返信
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - 返信
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - 返信
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - 返信
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - 返信
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - 返信
  3. iPad 4 Wi-Fiのバッテリーの交換: 手順 3、 1の画像 1
    • 電子レンジからiOpenerを取り出します。iOpenerの中央は熱くなっているため、両端の平面になっている部分を持ってください。
    • iOpenerは大変熱くなっていることがあります。必要であれば、オーブン用のミトンカバーをご利用ください。
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - 返信
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    breadandbits - 返信
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - 返信
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - 返信
    This thing melts when placed up side down in the microwave…
    Mark - 返信
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - 返信
  4. iPad 4 Wi-Fiのバッテリーの交換, iOpenerを使った他の温熱方法: 手順 4、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換, iOpenerを使った他の温熱方法: 手順 4、 2の画像 2
    • 電子レンジがない場合は、熱湯の中にiOpener をいれて温める方法もあります。
    • 鍋を十分な量のお湯で満たして、iOpener を完全に沈めます。
    • お湯を沸かして熱くなったら火を止めます
    • iOpenerを熱湯の中に約2−3分間沈めます。iOpener全体が完全に浸かっているか確認してください。
    • トングなどを浸かって、温まったiOpenerをお湯から取り出します。
    • タオルでiOpener全体を拭き取ります。
    • iOpenerが非常に熱い場合は、先端のタブを持って火傷をしないようにご注意ください。
    • iOpenerの準備は整いました。iOpenerを再度温める必要がある場合は、お湯を沸騰させて、火を止めてからiOpenerを2-3分間浸してください。
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - 返信
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - 返信
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Robert Garcia - 返信
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - 返信
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - 返信
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - 返信
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
  5. iPad 4 Wi-Fiのバッテリーの交換, フロントパネル: 手順 5、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換, フロントパネル: 手順 5、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換, フロントパネル: 手順 5、 3の画像 3
    • 液晶画面に割れがある場合、画面がさらに割れるのと破片によって怪我するのを防ぐため、画面にテープなどを貼って保護してください。
    • iPadの液晶画面全体に透明なテープを端を重ねるようにして貼ります。
    • これにより、割れた画面の破片を固定し、ディスプレイをこじ開けたり持ち上げたりするときにバラバラになりません。
    • この修理ガイドの記述通りに作業を進められるようベストを尽くしてください。しかしガラスが壊れてしまった場合、作業を続けるに従ってひび割れは広がっていきます。ガラスを取り出すために、メタル製のこじ開け用ツールを使用してください。
    • 保護眼鏡を着用して目を保護し、LCDスクリーンを損傷しないように注意してください。
    Yes...wear safety glasses for sure when doing this!
    Josh West - 返信
    If you have ANY cracks FOR SURE do the tape. I would also make sure to wear safety glasses as it can fly all over even with the tape. And do it somewhere that you don't mind tiny glass shards going everywhere. I had one 3 inch crack in the glass in the lower right corner and it started spidering. The plastic pics don't work once well once they hit a broken point in the glass so you better have a lot of heat to loosen the adhesive, or you end up using an exacto knife to get around the cracked spots.
    jesseokerlund - 返信
    On a few occasions I had an unexpected pop as the glass shattered and little shards struck me in the face. I had taped the surface but pieces at the edge still managed to break free. My advice: definitely wear the safety glasses, and definitely tape the entire glass surface.
    robertmhussey - 返信
    Echo jesseokerlund's comments that you will have glass flying. I made the mistake of doing the repair at my kitchen table and had a lot of cleanup to do. The job would be much easier if there was no broken glass, and the hardest part is where the glass is broken right next to the bezel. I used the metal spudger to work those pieces free, but it takes some time.
    robertmhussey - 返信
    + 1 on the safety glass, I almost got hurt while doing this.
    alexisfogel - 返信
    I followed all the safety precautions mentioned: tape, safety glasses… The best advice I saw on this is to put the iPad in the sun for a few minutes. I placed mine on the windshield of my car in direct sunlight for about 5 minutes. I also used the iOpener to keep heat on the edges I wasn’t working on. I was able to easily remove the glass without any shards flying in about 30-40 minutes total. Great advice and safest way I’ve seen to remove broken glass.
    Robert Jenkins - 返信
  6. iPad 4 Wi-Fiのバッテリーの交換: 手順 6、 1の画像 1
    この手順で使用する道具:
    Safety Glasses
    $3.19
    購入する
    • 繰り返しになりますが、この手順では割れた画面での作業になるので、飛び散った破片による怪我を防ぐために保護メガネの着用を強く勧めます。
    • iOpenerをiPadの画面の右の端に沿って平らに、iPadとiOpenerが隙間なく接触するようにおきます。
    • iPad上にiOpenerのバッグを約90秒間載せてください。接着剤が温まって、柔らかくなったらフロントパネルを開いてください。
    It is ver likely that the glass you are trying to replace is broken, and this is tempered glass therefore it will chatter in many small pieces while you are working on it. Take this safety advice very seriously and protect your eyes!!! The glass pieces fly everywhere. AGAIN: PROTECT YOUR EYES!!!! BE SAFE!!!
    McGiord - 返信
    This last statement cannot be underemphasized! I got two shards of very fine glass into my right eye, luckily got them out right away, before reaching for the safety goggles! Later on, I removed them again because working w/ the small parts was easier. Protect your eyes, people!
    Lou Bomski -
    Just use some scotch wide transparent tape and cover the broken screen BEFORE you start to taking it apart. It will hold all the shards together and nothing will fly around.
    Vatevaaa -
    I covered the screen in clear packing tape to control glass particles.
    I placed the ipad outside in direct afternoon sunlight for an hour and all of the adhesive was softened quite well.....the screen was off in just a few minutes !
    John - 返信
    This is a very good idea John, I wish I'd seen this comment before I spent hours picking tiny bits of glass off the glue!
    Tom Scott -
    Thumbs up for this tip. I left it out in the sun for 15 min only and it worked a treat. I used a razor blade. The plastic tools are next to useless.
    olafgoy -
    I had some issues after replacing this cable.
    Once I had it in and back together only the down volume was working, and shortly after the gyro gave out.
    I ended up going to where the new cable connects to the board, removing it, then replacing it as gently as possible. Not too firm.
    I also removed a foam spacer in that area because it was pushed out over the gyro board.
    Now I'm back to full functionality!
    clatekeen - 返信
    me 2 my volumen up doesn't work and the switch sound/silent any fix?
    Zadd -
    Badly broken screen, taped and warmed about 15 minutes on heating pad set on high. Perfect, gentle, overall warming! Mark the front with Sharpie, ie WiFi, cable, etc. Used thin metal iSes... type tool and guitar pics. BUY NEW Plastic bezel!!! So super cheap. Rewarm on heating pad as necessary. Compressed air helpful to blow away tiny glass bits. Wear glasses! Take breaks! This is easy if you warm carefully and are patient!
    Max - 返信
    I am in the process of replacing a shattered screen on an iPad 3 wifi, and I literally was removing glass piece by piece! I do recommend having a roll of wide clear sealing tape at hand. Then, when you see loose glass shards, pull off about 4 to 5 inches, and stick the tape to pick up the loose glass, and once in a while, fold the tape onto itself (sticky to sticky side), and set it aside. This helps keep it from getting everywhere. Also, spread news paper under your work. Some people don't really think of these things, but the fact is, hardened glass will find its way into your skin very easily. Extremely sharp!
    dbrown900 - 返信
    Have not attempted this repair on my wife's iPad 2, but is there a reason that you put the iOpener on top of the device rather than putting the device on top of the iOpener? After all, heat rises.
    Stephen Weber - 返信
    Can someone please explain which is the right side of the ipad?
    padeacon - 返信
    loll... that's a good one.
    Alex -
  7. iPad 4 Wi-Fiのバッテリーの交換: 手順 7、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 7、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 7、 3の画像 3
    • iPadの右上隅(iPad上部から約5cm以内の場所)にある接着リングには、小さな隙間があります。 この小さな隙間をこれから利用します。
    • ツールをミュートボタンと位置を揃えます。 プラスチックの開口ツールの先端をフロントガラスとプラスチックのベゼルの間の隙間に挿入します。隙間を広げるのに十分なだけ、開口ツールの先端を差し込んでください。
    • ガラスとプラスチックの間に開口ツールのアングルが入った先端を挿入するには、ある程度の力が必要です。適度にプラスチックの開口ツールを前後に動かしながら、根気よく作業を続けてください。
    there is the power flex cable near the top right side of the screen. It could be damaged is not careful.
    cli168 - 返信
    Yes, I severed this one on my first attempt. Might note that you want to start prying open below the sound controls. Additionally I found that a razor was helpful in getting the first pic into the device. Obviously you want to be careful as a razor could cause some serious damage, but I just used the tip of the metal to get some space to fit a pick.
    Nick Dresang - 返信
    Maybe I was doing it wrong, but the plastic opening tool I was using kept bending before it was prying anything apart. Therefore I suggest using either a metal spudger or a razor blade to make the very first opening but being VERY careful. My assistant/wife later scratched the LCD going overboard with the metal tools.
    Logan Kennedy - 返信
    There is a way of making the Wifi/Bluetooth Antenna replacement much easier. If you have a steady hand and a soldering iron simply desolder the connecting cable from the bottom of the antenna and solder it back onto the new antenna. This means there is no need to dismantle the iPad and the repair is much faster. Hope this helps :-)
    Richard - 返信
    The process was pretty straightforward, you do need to be careful in a few spots (like the wifi antenna in the lower right) but overall I found it to be of medium level of difficulty.
    It took me 2.5hrs to slowly dismantle and replace the broken screen.
    Here are some tips I learned while doing it:
    - instead of plastic spudger, better to use kit knife or razor blade. I found plastic to bend and malform quite easily.
    - watch out for lower right corner where wifi antenna sits, it's easy to damage it
    - if you have a cracked screen, use protective goggles - i used tape to secure broken glass pieces together, but that didn't quite work and lots of glass was flying as I was prying the screen off the ipad
    - opening tool you put in the microwave sold here is not worth it - didn't do that great for me. I mostly used a hair drier and was very successful melting adhesive
    - tools I'd only need again to do it again - guitar picks, kit knife, phillips screwdriver, hair drier :D
    Overall, I found it to be quite interesting project!
    michalmotykiewicz - 返信
    Seconding the problem about plastic components. They just aren't strong / precise enough to fight this glass. Save them for the really nasty bits like the wifi cable, and use an X-Acto or equivalent everywhere else.
    Golden Neckbeard -
    Wish I would have seen your comment before I went through it. Switched to a razor blade and that helped for sure. Thought about a hair dryer as well but stuck with the micro heating tool. Probably should have done the dryer. :-/
    Josh West -
    Had much more success using the metal spudger versus the plastic opening tool that came with the front panel kit.
    Paul Boyer - 返信
    I had success using Paddle Pop sticks instead of guitar picks. (not sure what they are called in the US). The guitar picks tended to deform and melt with the heat of my hot gun. The glue used to attach the screen is just amazingly strong! It takes a lot of patience to remove all the fragments. I have done about 6 screens now and it is a turdful job!
    Jack - 返信
    I think we call those popsicle sticks. They seem kind of thick for this, at least a lot thicker than a guitar pick.
    John -
    It is not glue, they use a very strong double sided 3M tape
    Odus182 -
    Pay attention to the Power Button cable located in the upper right corner !!!
    Nathan - 返信
    Successful battery change but I did sever the cord/ribbon to the power/sleep button. As my iPad had been opened before at a repair shop, I think they put adhesive over the cord as the small section was stuck underneath the LCD, barely visible. So be careful not to put adhesive above that exposed ribbon/cord to the power/sleep button or the next time you open it up, it's severed.
    Breadman - 返信
    On the iPad 2 I repaired, the opening started at 1 inch and ended at 3mm.
    Justin H - 返信
    Like others i found the plastic tool pretty useless. Exacto, razor blade, or small metal pick/pry tool works much better to get that first guitar pick inserted. Be careful not to damage the bezel too much. Unless to plan to replace it.
    B Kirkham - 返信
    If you have an iPAD that has been repaired before note that the adhesive strip might not have an opening by the volume control as shown. I replaced the glass and the new glass had a 2" gap to the left of the Home button only.
    winwoodc - 返信
    The glass is much thinner than you'd think and I broke mine trying to lever it off before the adhesive has softened enough. Be VERY gentle!
    winwoodc - 返信
    My plastic opening tool broke in no time flat. Perhaps I was pressing down too hard and not wiggling it enough. But for me I found that the metal spudger was the best tool for the job. I was able to wiggle it while slowly prying up the glass and once it was under the surface of the glass I was able to work it along the edge quite easily. I saw that some people used a razor blade but I would be afraid the blade would break. The metal spudger was just thin enough to do the job well.
    robertmhussey - 返信
    !!!!!!razor-blade & hair-dryer !!!!!!!
    sean blanche - 返信
    I have found that using these plastic picks, spudgers and edge tools are ineffective as tools for inserting or creating a gap and glue separation action.
    They are just too soft and too thick for this, causing cracks and not able to reach underneath without causing stresses.
    After heating the adhesive with a heat gun (and using cardboard to shield the lcd screen) I have been using a metal round headed scalpel to insert between the glass and bezel, and to very carefully use as an adhesive separation tool at a very oblique angle so as to miss any sensitive cables or components.
    Also, instead of this iTool heating pad and a microwave, they should create an electrically heated shaped pad, this would avoid the constant cooling and reheating and maintain the right temperature.
    G Trieste - 返信
    Addendum, I have a temperature controlled heat gun, and set it to 180F for this.
    G Trieste - 返信
    The iOpener works fine, I'm not sure what y'all are talking about. To be fair, you have to press the iOpener into the iPad in order for it to work, which isn't explained well in this tutorial. Wear heat-resistant gloves when you do this, the center portion of the iOpener gets VERY hot. I use a pair of gloves from ACE Hardware. While it takes a bit more effort with the picks, I was able to heat up one side of the iPad, then seperate the adhesive with the picks the rest of the way through.
    I do not recommend using the little blue tool they show above, the part you're supposed to wedge in is way too thick. I use the Jimmy and some opening picks.
    Third image is slightly misleading, you want to go about a centimeter below the volume button.
    Emrys Quick - 返信
  8. iPad 4 Wi-Fiのバッテリーの交換: 手順 8、 1の画像 1
    • ツールが適切な位置、プラスチック製ディスプレイベゼルとフロントパネルガラスの間に置かれているか確認してください。
    This visual is helpful. It would be great also to have a diagram of the top of the ipad, marked with "top," "bottom," "left," "right," and then an arrow pointing to each of the problematic areas, such as wifi cable, digitizer cable, etc. It would be easier to see the whole schematic while working rather than scrolling through the instructions and trying to visualize each piece separately. Good to see where to be careful...
    Christa - 返信
    sean blanche - 返信
  9. iPad 4 Wi-Fiのバッテリーの交換: 手順 9、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 9、 2の画像 2
    • フロントガラスとプラスチック製ベゼルの間にプラスチック製開口ツールの先端を差し込んだまま、プラスチック開口ツールの右側の溝にプラスチック製開口ピックをスライドします。
    My screen was too broken for this "heat, cut with picks, and leave in place" method to work anywhere but the top, where it was essentially undamaged.
    I wound up using a spudger through all the cracked sections to pry upwards just *inside* the perimeter of the adhesive, intentionally breaking the digitizer and the glass further, until I could remove the entire front panel except for the adhered portions - about half the perimeter in my case.
    I then used tools to pry up the glass from the *opposite* direction, that is the broken interior edge I had earlier created, thus not having to fight the bezel and also having a clear line of sight to any interior components I might be damaging.
    Of course, doing it this way made it much easier to drop tiny shards of glass all over the interior, but I found a little diligent cleaning much easier than trying to keep the glass intact while breaking the glue, as in this guide.
    Golden Neckbeard - 返信
    I found that using a scraper blade was the easiest way to get under the glass, both for broken and unbroken areas.
    Jeff Snider - 返信
  10. iPad 4 Wi-Fiのバッテリーの交換: 手順 10、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 10、 2の画像 2
    • iPadからプラスチック製開口ツールを取り出し、フロントガラスの下奥深く、最長12.5mm程度まで開口ピックを押し込みます。
    It should be noted that the glass can be much more difficult to remove when it is cracked and shattered (as is usually the reason for replacement) . Depending on the location and severity of the cracks, the order and technique of removal requires modification.
    I have found that putting a layer of clear packing tape over the entire screen is helpful, wether it's cracked or not. It will prevent the spraying of glass shards, should the glass break while separating the adhesive; with a broken screen, it should eliminate the risk of cutting yourself during removal, as well as hold all the pieces together. Unfortunately, it also makes the iOpener slightly less effective, so peel it back when applying it. Suction cups can also be helpful during final removal of the glass.
    Having a hot air gun/pencil can be helpful in removing smaller pieces if broken glass that remain once the bulk of it is removed.
    Nick V - 返信
    Just trashed an I pad... Not an electronics person. Did an iphone 5 battery with no problems was following instructions and once I hit the next step I realized I had already screwed up the screen... Moving forward tring to unhook LCD pictures are not very clear on which direction to push or pull so broke that... Now writing a review on it... Take it to a pro if you aren't certain!
    rondiedonelson - 返信
    I found that the adhesive could be separated when the pick or spudger was in at a depth of between 1/4" (6.4 mm) and 3/8" (9.5 mm). You can always go back and work it in deeper if you are having trouble separating.
    robertmhussey - 返信
    Yoh but this is not so simple of your screen is shattered to the edges. Basically I had to lift, shatter more, and then pick off the splintered glass with tweezers bit by bit. Patience is a virtue here. I gave up on saving the adhesive and used it to help remove the splinters. I basically removed the edges of the iPad like that and then lift glass off. WEAR SAFETY GLASSES. I would be blind now if I didn’t. wifi antenna -Go slow make sure it’s hot +check what you are doing in the crack. Remove all splinters fromiPad when it’s open. Clean LCD with a microfibre cloth and inside of your new digitizer. When I first reassembled, the home button didn’t work. I reopened and made sure the two gold connectors align with the two spikes on the body. I placed the home button board face down onto the connector spikes with adhesive on the other side, then lowered the digitiser onto it so the board would stick to the digitiser. Notes: forget plastic spudger they’re only place holders, I used a blade knife and metal Spudgers
    Sarah Pegden - 返信
  11. iPad 4 Wi-Fiのバッテリーの交換: 手順 11、 1の画像 1
    • iPadの右側の接着剤を解放する作業をしながら、iOpenerを再度温め、iPadの底部端に置きます。
    I have found that its better to put more than one pick down the side of the screen to keep it open and prevent it from sticking back down.
    Roberto Enrieu - 返信
    I had a pick in and used the spudger to make some headway but after 10cm the screen cracked. Be very slow and reheat the glue often.
    Alex - 返信
  12. iPad 4 Wi-Fiのバッテリーの交換: 手順 12、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 12、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 12、 3の画像 3
    • 底部端をiOpenerで温めながら、iPadの右端から接着剤を解放し始めます。
    • iPad端に沿って開口ピックを下にスライドして、接着剤を解放します。
    • 接着剤は非常に強固で、かなりの力が必要な場合があります。注意深く作業してください。
    • フロントガラスの下に開口ピックの先端を確認出来たら、ほんの少しだけピックを引き出します。開口ピックを使って、どの部分にもダメージを与えないようにしながら、LCD上の残り全ての接着剤を剥がします。
  13. iPad 4 Wi-Fiのバッテリーの交換: 手順 13、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 13、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 13、 3の画像 3
    • 接着剤を剥がすには、iPadの右側端に温めたiOpener戻す必要があるかもしれません。これは作業中、温めたiPadがどれだけ冷めてくるかによります。
    • 開口ピックが接着剤で動かなくなった場合、iPadの端に沿って開口ピックを”回転/捻る”ように動かして、接着剤を切開して移動させます。
    The volume power button cable is really close to the edge and is frequently loose and non adherent to the frame. If your pick is deep into the iPad, you are almost sure to cut the cable. Be very cautious around the top right corner of the iPad.
    silvain1038 - 返信
    I absolutely severed this cable when loosening the adhesive around the volume button area. There is really no way of knowing if this cable somewhat elevated from the frame and therefore susceptible to being cut, and it happens to be right where one starts to remove the face with the guitar picks. The cable is directly in from the down volume button, so be extra careful not to put the guitar pick in too far in this area. I recommend buying a power/volume button cable just in case. Replacing this cable is also not easy, but doable. Just try to avoid doing it.
    nickmalmquist - 返信
    Why not work in reverse to the top edge, and back around to the area where that cable may be unsecured? Haven't don't an iPad (yet, staring one in the face right now) but that would be my alternative so the screen is mostly loose and you could possibly see the cable looking from the now open left side of the glass?
    Matt Needham - 返信
  14. iPad 4 Wi-Fiのバッテリーの交換: 手順 14、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 14、 2の画像 2
    • iPadの底部角から1つ目の開口ピックを取り外す前に、2つ目のピックをフロントガラスの右端に差し込み、接着剤が再接着しないよう防止します。
    • iOpenerを再度温めて、iPadの上端に置きます。
  15. iPad 4 Wi-Fiのバッテリーの交換: 手順 15、 1の画像 1
    • 次のいくつかの手順は、細心の注意を払ってください。
    • Wi-Fiアンテナは、iPadのリアケースの右下端にネジとケーブルで固定されています。Wi-Fiアンテナの位置の関係上、Wi-Fiアンテナに回復不可能のダメージを与える恐れがあるので、用心して作業を行うことが必要不可欠です。
    • アンテナをiPad底部に固定している脆いパーツにダメージを与えないように、アンテナをフロントパネルに留めている接着剤を解放する必要があります。次の手順を注意深く参照してください。
    I cut through my wifi cable partially, but it still works (surprisingly). I'd recommend staying well clear of this with the pick. When you go to lift the screen (future step, NOT NOW), use a really good light, start to lift the glass slightly at the corner and you will be able to see the cable. Then you can heat it more and watch the cable as you pull through the adhesive there making sure your not catching the cable.
    B Kirkham - 返信
    If you heat the sides and top, releasing the adhesive, you can peel the broken glass front panel up from the body and with a little force the bottom comes loose. This avoids working around and damaging the Wi-Fi Antennae.
    Michael Vovaris - 返信
    I know it is hard to tell from the photo, but the Wi-Fi antenna is kind of like a flap that opens on the right and is attached on the left. So if you use a pick to slide from right to left, the pick might slide under the flap and then sever how it is attached. When I had my pick just to the right of where the Wi-Fi antenna is, I was able to twist my pick a little (like you are tightening a screw) and pry the screen up where the antenna is located. Then I just moved my pick to the left of the antenna and could continue loosening the screen.
    Laurie Higgins - 返信
    Irreversible damage to the Wi-Fi antenna is nearly unavoidable, but this is not the end of the world since you can pick up a perfectly fine replacement on-line for a few bucks. Many digitizer screen replacement kits include a new WiFi antenna and new bezel since removing the screen without damage to these is also nearly impossible. If your iPad is old enough to need a new battery, and you plan on keeping it thru at least another battery's expected life span, then I would plan on replacing the digitizer screen, bezel, and WiFi antenna as part of the battery replacement. The battery is going to be the most expensive of the set, say around $15 (US), and adding the other three will only add about another $15 (check the prices in ebay, amazon, etc.). Removing the screen often results in damage to the on/off and volume control cable since it too runs along the upper right hand edge of the base right under the screen. If you cut thru this then add another $1 to replace it too.
    Jerry - 返信
    Based on my experience just (nearly) completing this job on an iPad 2, CDMA, is that the trickiest step is reconnecting the three CDMA antenna cables on the underside of the CDMA chip that is part of the logic board assembly. These are nearly microscopic button connectors (maybe 0.5 mm in diameter). I needed 8X magnification glasses, very bright light, tweezers, and incredible luck to get these reattached. They pop off no problem, but getting them positioned to apply pop-on force takes a LOT of patients! Maybe someone knows a trick to doing this? There’s a similar connector on the WiFi cable but the chip it attaches to can be removed from the logic board so you’re able to manage positioning them interdependently. The CDMA chip is attached (soldered?) to the logic board and the three button connectors are on the underside, and pretty close to one another, so getting all THREE attached and then the logic board in place is a miracle.
    Jerry - 返信
  16. iPad 4 Wi-Fiのバッテリーの交換: 手順 16、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 16、 2の画像 2
    • iPadの右下角あたりに開口ピックをスライドして、接着剤を解放します。
    • 右下角から奥深くまでピックをスライドしないでください。Wi-Fiアンテナにダメージを与える恐れがあります。
    Be sure to have a replacement Bluetooth Wi-Fi antenna because it is very likely to get the cable broken at this step.
    McGiord - 返信
    Be extremely careful and patient at this step. Proceed slowly with only the tip ( 1/16th in. - 2mm max.) of the pick. There are two tinny screws that attach the bottom of the antenna to the iPad frame. This antenna part is easly severed if the pick goes too far.
    Happenned to me and had to replace the antenna.
    Marc Bouchard - 返信
  17. iPad 4 Wi-Fiのバッテリーの交換: 手順 17、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 17、 2の画像 2
    • この手順は、フロントパネルの右下端に沿って開口ピックをスライドする作業が必要です。Wi-Fiアンテナは、角に非常に近い場所にあり、接着剤を正しく剥がせなければ、容易に切断してしまいます。
    • フロントガラスの下からピックを完全に取り出さず、ピック先端の最長3mm程度がフロントガラスの下に挟まった状態になるように、ほんの少しだけ引き抜きます。
    • iPadの底部端に沿って開口ピックの先端をスライドして、Wi-Fiアンテナに留められた接着剤を解放します。
    I nearly broke my wifi antenna because I didn't read this whole step clearly and didn't go backwards and release the antenna from the front panel. Admittedly, this is my own fault but I've edited the step to make this point more clear.
    Logan Kennedy - 返信
    My screen was way too shattered for me to be able to use the screen instructions as suggested, so I followed the general principal but ignored the order around, because that simply wouldn't have worked...and destroyed the antenna.
    Maybe step one should be "BE CAREFUL IN THIS CORNER OR YOU WILL BREAK THE ANTENNA!" A diagram highlighting where all the cables (antenna, digitiser, volume, toggle switch) lie with the screen still attached would be helpful too.
    HRB - 返信
    Or maybe you should have read the entire thing before starting if you were not planing on following it step by step
    Hawesg Garrett -
    I Broke my antenna like many others. It is glued to the glass and has 1mm thick foam backing that is also glued to the inner case. Then there is a tiny grounding connector screwed at the lower edge of the case. Once you can get things loosened up around this antenna, you will need to detach this antenna from the glass. Work at it with your picks or spudger until you get it free, if you do not get it to release from the glass you will break the grounding ribbon. I bought a cheap aftermarket antenna on amazon for $3. turns out it has a bad cable coming from it. I was able to unsolder the cable from the one I broke and solder it to the new antenna.
    chrisnewitt - 返信
    This BEGS for an Archer "Just The Tip" reference.
    Christian - 返信
    It wasn't obvious to me at first that I'd broken the antenna. A picture of the antenna that works compared with one that is broken would be useful. Fortunately I'd ordered the replacement part just in case, as suggested.
    I think using extra heat on this spot may make it easier to unstick without breaking the antenna?
    A diagram of what the antenna looks like, from the side, would make it clearer what to do with the pick. You are trying to detach the antenna from the glass, without ripping it off where it's screwed into the bottom of the ipad. Since you can't see what you are doing, and the antenna is quite fragile, that's tricky.
    I think once you've broken one you would know better how to do it. When you slide the pick to the right you need to be sure the pick is moving above the antenna and not snagging on it in any way, and you need to be sure the antenna is completely detached from the glass, so you don't tear it when you lift the glass up.
    Chris Jordan - 返信
    Can anybody give me a clue as to what the exact part is in step 57, As there are slightly different cables for the ipad 2, Mine is A1395, Thanks.
    Jasper - 返信
    Another lesson learned while removing the WiFi antenna. The photo shows the iPad laying face up on the table, but to see what you’re doing when detaching the antenna you ‘re better off with the iPad edge up so you can see how the antenna is attached. The antenna is very, very easily broken. To be honest, it’s a lot easier to replace a broken antenna than to try to pry it loose.
    nigel - 返信
    Please mind that the GSM model has on the upper side left and right from the front camera the 3G antennas. When I removed the broken glass I cut the right one off which I have to fix now.
    st mo - 返信
  18. iPad 4 Wi-Fiのバッテリーの交換: 手順 18、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 18、 2の画像 2
    • Wi-FIアンテナ(デバイス右端から約75 mm、またはホームボタンのすぐ隣)を通過したら、開口ピックを奥まで完全に差し込みます。
    • ピックを右にスライドさせ、フロントガラスに固定している接着剤を剥がして、Wi-Fiアンテナを解放します。
    • アンテナは、ネジとケーブルで、iPadの底面に取り付けられています。 この手順では、アンテナをフロントパネルから取り外し、パネルを取り外すときにアンテナが損傷しないようにします。
    Be extremely cautious on this step! I did it wrong and my antenna went to !@#$.
    Lars Lien Ankile - 返信
    Also once it is unattached from the front panel, if the antennas adhesive touches the glass again it can re-adhere to front panel and may rip apart after all. Keep a close eye on it or leave a pick or card in there to prevent it from re-sticking.
    Danny Hartley - 返信
    Ordering a replacement antenna to anticipate the one you will brake(I should say shred) is probably your smartest move to have a successful repair
    Sebastien CHAPUIS - 返信
  19. iPad 4 Wi-Fiのバッテリーの交換: 手順 19、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 19、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 19、 3の画像 3
    • iPad下部に沿って接着剤を切開し、ホームボタンの周辺では開口ピックの大部分を引き抜いて、わずかな先端だけ差し込むようにします。ホームボタンを通過したら、10 mmの深さまで再挿入します 。
    • 接着剤が下端に沿って冷却されている場合、再度iOpenerを準備して、接着剤を温めてください。
    • iOpenerを電子レンジで1分以上加熱しないでください。再度加熱する前に、必ず2分以上開けてください。
  20. iPad 4 Wi-Fiのバッテリーの交換: 手順 20、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 20、 2の画像 2
    • 続けて、iPadの底部端沿いの全ての接着剤を解放します。
    • iPad 4モデルでは、ホームボタンリボンケーブルにダメージを与えないようにするため、このエリアでは最長10mmの深さまでピックを差し込んでください。
    • ホームボタン付近のフロントガラスの下に開口ピックを押し込み、ピックをそのままの状態にします。
    This should include details about the Home Button Ribbon Cable. Unlike an iPad 3 (which doesn't have this cable) the iPad 4 has a Home Button Ribbon Cable that runs along the left side of the Home Button and is adhered to the glass. If the guitar pick is inserted too far (more than 0.5") it is possible to damage or sever this cable.
    robjpete - 返信
    There is a reason this is an iPad 2 Wi-Fi EMC-2560 repair guide. This guide isn't for iPad 3 or 4...
    Christian -
    I think the guides carry common steps between them. I'm reading this string of comments on multiple ipad 3/4 repair guides.
    Anticept - 返信
    Can I suggest putting the warning in red at the top of the instruction rather than half-way through it? I work from these guides by scrolling through them as I go, and I'd already put the spudger through the ribbon cable before I read the warning!
    spl23 - 返信
  21. iPad 4 Wi-Fiのバッテリーの交換: 手順 21、 1の画像 1
    • 電子レンジでiOpenerを温めなおし、iPadの左端に置き、その部分に留められた接着剤を温めます。
    I believe this should say to place the iOpener on the top edge, since the instructions go there next.
    lizgoldnm - 返信
  22. iPad 4 Wi-Fiのバッテリーの交換: 手順 22、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 22、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 22、 3の画像 3
    • 開口ピックをiPadの上端に沿ってスライドさせ、フロント向きカメラのブラケット周辺では少し引き抜いてください。
    • この部分の接着剤は非常に厚く、かなりの力が必要になる場合があります。 iPadが滑ったり損傷したりしないように注意して、慎重に作業してください。
    • 接着剤が冷却している場合、上端に沿って温めたiOpenerを載せて、接着剤が柔らかくなったら、作業を続けます。
    • 開口ピックが接着剤に詰まって動かない場合は、手順9を参照しながら、開口ピックを”回転/捻る”ように移動させます。
    In my case I damaged the right GSM antenna which was somehow sticked to the front panel... Be really careful as I really didn't felt that I was damaging anything...
    MattLise Gaillzik - 返信
    +1 on the right 3g antenna - it is adhered to the glass and I cut right through it with the opening pick. The replacement included adhesive to re-stick it to the glass, so this is a definite feature of this antenna. This is a thin film similar to the wifi antenna, so maybe going around it at a shallow depth from the corner to the camera and then returning to the corner slightly deeper would allow you to separate the antenna from the glass without damaging it.
    doog - 返信
    Be very careful when going around the front camera, I cracked my screen by prying up too much and causing too much stress!
    Rowdydtk - 返信
    The GSM component is glued to the screen with different adhesive (more like glue). I managed to not damage this but it was really tricky. The guitar pick is too thick and weak to release this from the screen. Id recommend you wait until you lift the glass (future step, NOT NOW). Then, with a good light you'll see the white plastic adhered to the glass. A thin metal pick or exacto is needed to patiently cut & pry your way through the adhesive. Careful of the camera as your pulling in that direction.
    B Kirkham - 返信
  23. iPad 4 Wi-Fiのバッテリーの交換: 手順 23、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 23、 2の画像 2
    • iPad上端に沿って接着剤を引き続き切開し、左上角周辺を開口ピックでスライドします。
    • 接着剤が十分に温まっている場合、iOpenerをiPadから外してください。 接着剤に粘着性が残っている場合、iOpenerを再加熱してデバイス左端に載せます。
  24. iPad 4 Wi-Fiのバッテリーの交換: 手順 24、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 24、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 24、 3の画像 3
    • iPad左端に沿って開口ピックをスライドさせ、接着剤を切開します。 左側全体に沿ってデジタイザが搭載されているため、接着剤は薄くなっています。 デジタイザの損傷を防ぐために、ピックを浅く(最大10 mm以下)差し込んでください。
    • デジタイザケーブルは、iPad下部から約50 mmの位置に搭載されています。iPad下部から約60 mm程度までスライドしたら、ここで開口ピックを止めます。
    The second photo does not show the iPad 4's Home Button Ribbon Cable.
    robjpete - 返信
    Because this is for an iPad 2
    Odus182 -
    @odus182 It says clear as day that this is an iPad 4 guide!
    Mike Enos -
    This is the hardest part the digitizer cable runs the length of this side and u have to be very carefull with the pick . Only go in an 1/8 inch I severed it by going the half (recommended) luckily I had a new screen standing by . I used I opener for heating and it was slow but ok.
    wperrin623 - 返信
    How do i fix my digitiser if it's broken? Do i need to buy a new iPad screen with digitiser?
    Jenny Le - 返信
    just ruined my digitiser..any ideas how to fix it?
    dleimonis -
    There is an error in the red text in this step. It says ‘The digitizer cable is located approximately 2" from the bottom of the iPad’. The next sentence says .. ‘Stop sliding the pick when you get ~2.25" from the bottom of the iPad.. This will slice and ruin that cable. The last sentence should read ‘Stop sliding the pick when you get ~1.75" from the bottom of the iPad.’ so you stop cutting glue before you get to the digitizer cable.
    @Jenny & @dleimonis - you can buy the digitizer and new cable by itself if you do not need an LCD also. They are separate parts.
    Jon Lucenius - 返信
  25. iPad 4 Wi-Fiのバッテリーの交換: 手順 25、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 25、 2の画像 2
    • iPadの底部端の下にある開口ピックを使って、左下角に沿って接着剤を解放します。
    • デジタイザーケーブルの底部は、iPadの底部から最長25mmしかありません。このケーブルを切断しないよう確認しながら、作業は注意深く、かつ慎重に進めてください。
    If your screen is broken or shattered there are no worries with the digitizer cable, It is all on the new screen.
    Danny Hartley - 返信
    Exactly. I purposely severed mine as it was a complete screen replacement and made the LCD removal easier.
    jesseokerlund - 返信
  26. iPad 4 Wi-Fiのバッテリーの交換: 手順 26、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 26、 2の画像 2
    • 開口ピックを1つ使って、iPadの右下角を持ち上げ、指で掴みます。
    • iPadの周囲沿いの接着剤によって再び接着される場合があります。この場合、フロントガラスが接着剤で固定されているiPad端の下にピックをスライドして、接着剤を"切開"します。
    Should be right-hand corner
    longg - 返信
    Be very careful when pushing the guitar pick around the corner of the power/volume buttons. The ribbon cable for these buttons may be stuck to the adhesive and break when lifting the screen or when sliding the pick along this area. I have done 4 iPad 2 repairs and at least one of the delicate components do not make it. I would recommend ordering a wi-fi/bluetooth antenna, bezel with strips, and a power/volume cable. It is nice to have a "just-in-case" part or two, they are very inexpensive. I noticed that the I tended to break one of these delicate components when the screen was shattered in the area of those components.
    thetechandtutor - 返信
    nickmalmquist - 返信
    At this point it is a good idea to get the packing tape back out and wrap it around 2 or 3 of your fingers making a circle with the sticky on the outside. Make it loose enough you can place your fingers on the table surface to the side and pull your fingers out. When you remove all the tiny parts/screws in the next steps put them on top of the tape so you know exactly where they are when you need them
    windizy - 返信
  27. iPad 4 Wi-Fiのバッテリーの交換: 手順 27、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 27、 2の画像 2
    • iPadの右上角と右下角を掴んで、iPadからフロントガラスを回転させて外します。
    • まだ残っている接着剤に注意してください。開口ピックを使って、フロントパネルに付けられた接着剤の残留部分を切断してください。
    Check to the right of the Home button to see if the wifi/bluetooth antenna is still stuck to the glass side or has released. If it is still stuck to the glass use the guitar pick to carefully scrape it off. If your goal is to replace the antenna, then you needn't be so careful.
    jerry81 - 返信
    Be very careful not to touch the LCD. It's a pain to remove smudges. One thing that might help when you need to hold it while reattaching it during reassembly: attach a small suction cup to the metal side. That way you can avoid touching the sides where your hand might slip to the LCD side.
    patjmccarthy - 返信
    Do you need to use some adhesive strips to remount the plastic bezel? The bezel I ordered didn't come with any and the ones you can order only seem to have strips for mounting the glass and not the bezel.
    James - 返信
    You'd better. The original bezel is glued. You can find 3mm fine/double-sided (black) tape on Amazon. I use it when I replace the bezel because they fit perfectly under the bezel. I use for all sorts of repairs on iPhones, Samsungs, etc. Such as this [one|http://www.amazon.com/gp/product/B005GIS...]
    Rany -
    In order to prevent touching the LCD screen with your finger(s), I use the thin plastic food wrapper to cover it. It will temporary stick to the LCD screen and provide excellent protection from fingerprints.
    Th Th - 返信
    Very good suggestion. It worked like a charm.
    Laurie Higgins -
    you can use latex gloves to keep smudges and finger prints from the screen. I'm getting ready to repair mine, thanks for all the comments and tips. Btw, I wonder if a vacuum cleaner would work for removing small pieces of glass.
    De Dios sept.10 2014
    dediosjon - 返信
    where is the connecotr for home button at the ipad 3....i have nothin where i can plug in the flex cable comin from the button
    Georg Heinze - 返信
    Go slowly as you lift up the glass and be sure that you are not tearing a ribbon cable. When I lifted the glass the digitizer cable was torn and unusable. Perhaps I had cut it with the pick/spudger but it tore completely off when I lifted the glass. Good thing I had purchased the full front panel assembly with the digitizer (IF116-018-3).
    robertmhussey - 返信
    When reassembling I used canned air to blow off dust on the LCD before closing it up.
    robertmhussey - 返信
    You can use a clean soft brush like a make-up brush or small paint brush to brush off the LCD.
    Laurie Higgins - 返信
    I like how the pictures show an intact screen being removed (although the one in step 4 has a couple of cracks in). I don’t know if anyone would have the luxury of being able to remove a screen in one piece, the ipads I've fixed have been completely smashed pretty much all the way around the outside of the lcd underneath. I used this guide to know where to watch for cables etc - very helpful. I end up using a window scraper/razor to scrape off the glass shards/adhesive around the edge. Glass shards/dust all over the lcd is easy enough to get off but cleaning the lcd after that is a real pain. Does anyone have any suggestions how to clean the lcd properly?
    jmzaj - 返信
    When reassembling the glass, align the camera first. On the back of the glass there are two pins on the metal camera frame.
    Align them to the camera first, in order to avoid to get a ‘bulge’ visible on the glass or on the back of the iPad.
    Luca Forti - 返信
    +1 to Luca’s comment. This deserves a RED NOTE for reassembly. I probably just destroyed my new wifi antenna due to not having a reassembly call out for alignment of the screen. Had to pry things back apart and wifi antenna looks like it may have bit the dust. So this is a VERY important bit to know for a first timer.
    Benjamin Pappas - 返信
    When reinstalling the front panel check the home button’s ribbon cable doesn’t get trapped. If it gets folded back on itself, the cable will break and you’ll have a reassembled iPad with a non-functioning home button.
    nigel - 返信
  28. iPad 4 Wi-Fiのバッテリーの交換, フロントパネルアセンブリ: 手順 28、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換, フロントパネルアセンブリ: 手順 28、 2の画像 2
    • アルミフレームにLCDを固定している2mm #00プラスネジ を4本外します。
    • 左下のネジはホームボタン用リボンケーブルコネクタによって隠れています。左下ネジを取り出すには、慎重にホームボタンのリボンケーブルを作業の邪魔にならない位置に移動させてください。
    The 00 bit didn't fit my screws. Needed to use the 000 bit.
    David Siebecker - 返信
  29. iPad 4 Wi-Fiのバッテリーの交換: 手順 29、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 29、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 29、 3の画像 3
    • プラスチックの開口ツールもしくはスパッジャーを使って、iPadからLCDの右端を持ち上げます。
    • 左端に沿ってLCDを裏返して、フロントガラスパネルの上に載せます。
    • LCDを取り出す際はご注意ください。リボンケーブルはデリケートで、過度に引っ張ると切断することがあります。
    But….WHY would you lay it like that? Laziness creates f ups..
    Giovanni - 返信
  30. iPad 4 Wi-Fiのバッテリーの交換, LCD: 手順 30、 1の画像 1
    • スパッジャーの先端を使って、LCDリボンケーブルコネクタを覆っているテープを引き剥がします。
    This should be the point where you disconnect/isolate the battery.
    Jacob Beranek - 返信
    I see there is a battery isolator in the iOpener kit but they don’t mention using it here. I didn’t isolate the battery on my last fix and didn’t have an issue - maybe I was just lucky. Will try to remember to do it in future.
    jmzaj - 返信
    Battery disconnection:
    This is the correct way to repair an iPad 4 (see 16:00 min)
    I didn’t do this and blew the backlight. Cheers ifixit.
    https://www.youtube.com/watch?v=HXmS3e1s...
    rumblefish - 返信
  31. iPad 4 Wi-Fiのバッテリーの交換: 手順 31、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 31、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 31、 3の画像 3
    • LCDリボンケーブルのZIFコネクタ上の固定フラップを跳ね上げます。
    • 指やピンセットを使って、ロジックボード上のソケットからLCDリボンケーブルを引っ張ります。
    The cable SLIDES toward the edge - NOT lifts out!!! My iPad is damaged where I must now sell for parts - instructions are NOT specific about the cable SLIDING - photo appears that it LIFTS out!!!!
    samattie - 返信
    Thank you yes sliding the cable out worked great.
    Patrick Gross - 返信
    IMPORTANT NOTE. you MUST disconnect the battery before disconnecting the LCD, or you risk blowing out the back light. This is a basic step for any device, disconnect the battery for you disconnect ANYTHING else.
    Thomas Gehman - 返信
    God.... why didn't I check these comments first?!?! Just had the same problem as samattie. Instructions said 'pull it from its socket', included a picture that kinda looked like it had been pulled upwards, and (unlike other less-fragile dangers) did not include any warning of a danger to be careful of. Now, after 1 mistake, even though I didnt use hardly any force at all, the cover flap to the zif connector is broken, and some of the pins are bent or missing (a single sneeze is probably enough to bend them, an they dont even need that much to fall out if exposed)... so all this effort was a total failure. Next I can tell my 9 yr old son I wasn't able to help him fix the ipad he accidentally dropped. Think he'll be happy if I give him an etch-a-sketch instead?
    I know its nobodys fault but my own... but especially now, knowing this was pointed out 2 years ago but still left from the guide.... all I can say is FU too. This will be the first and last time I ever try and use this junk site.
    O Marrow - 返信
    The instructions are not clear and there is an assumption that you should know the cable slide out to the left. Closely inspecting the connector with good light or inspecting the replacement parts should make this very clear. If you are obliviously working you might mess it up. If you are paying attention at all this is an easy task.
    Big Tom - 返信
    that's it! &&^& you ifixit &&^&.you. you inbred authors and op's.
    Aleksandar Dejanovic - 返信
  32. iPad 4 Wi-Fiのバッテリーの交換: 手順 32、 1の画像 1
    • LCDの表面を触らないようにして、フロントパネルからLCDを持ち上げて外します。
  33. iPad 4 Wi-Fiのバッテリーの交換, フロントパネルアセンブリ: 手順 33、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換, フロントパネルアセンブリ: 手順 33、 2の画像 2
    • Wi-Fiアンテナ、スピーカーケーブル、ホームボタンリボンケーブルを覆っている電子テープがあれば剥がします。
    I recommend disconnecting the cable at the home button and leaving it attached here. It is a challenge to get it back in,
    Joel Mann - 返信
  34. iPad 4 Wi-Fiのバッテリーの交換: 手順 34、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 34、 2の画像 2
    • ホームボタンリボンケーブルのZIFコネクタ上の固定フラップを跳ね上げます。
  35. iPad 4 Wi-Fiのバッテリーの交換: 手順 35、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 35、 2の画像 2
    • ピンセットを使って、ロジックボード上のソケットからホームボタンリボンケーブルをまっすぐ引き抜きます。
    It helps quite a bit to peel the black plastic block off the aluminum case to give you the room to work with the home button cable on reassembly. Lean the new digitizer against something so it's at a 90 degree angle to the bottom case to help line up the cable connector to the ZIF socket. Use the tweezers on either side of the "neck" of the cable to encourage it back into the ZIF socket; it doesn't require too much force.
    Boz Duffield - 返信
    Instead of disconnecting the cable here, Take out the two screws on the home button and remove it there, Re-installing this cable is a challenge. The adhesive is gently peeled away under the cable near the home button.
    Joel Mann - 返信
    I wish I had taken Joel Mann’s advice to disconnect the cable elsewhere. Re-installing this cable was !&&* for me! Took several tries and nearly destroyed it in the process.
    lizgoldnm - 返信
    Yes, the home button cable reconnects gold-side-up. It feels weird, but it works that way.
    Cassandra Gelvin - 返信
    I damaged the tiny grey bit that sits over the flex connector Does that mean I have wrecked it?
    Robyn - 返信
  36. iPad 4 Wi-Fiのバッテリーの交換: 手順 36、 1の画像 1
    • リアケースの奥からホームボタンリボンケーブルを巻き戻して外します。
  37. iPad 4 Wi-Fiのバッテリーの交換: 手順 37、 1の画像 1
    • ピンセットを使って、デジタイザーリボンケーブルをロジックボードに留めているテープを剥がします。
    At this point you really should disconnect and isolate the battery before unplugging any cables.
    Jacob Beranek - 返信
  38. iPad 4 Wi-Fiのバッテリーの交換: 手順 38、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 38、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 38、 3の画像 3
    • 2つのデジタイザーリボンケーブルZIFコネクタ上の固定フラップを跳ね上げます。
  39. iPad 4 Wi-Fiのバッテリーの交換: 手順 39、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 39、 2の画像 2
    • スパッジャーの平面側先端を使って、デジタイザーリボンケーブルの下から接着剤をほぐします。
    • ロジックボード上のソケットから、デジタイザーリボンケーブルをまっすぐ引き抜きます。
  40. iPad 4 Wi-Fiのバッテリーの交換: 手順 40、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 40、 2の画像 2
    • デジタイザーリボンケーブルをめくります。そして、スパッジャーの平面側先端を使って、ケーブルをアルミニウム製のリアケースに留めている接着剤を削ります。
  41. iPad 4 Wi-Fiのバッテリーの交換: 手順 41、 1の画像 1
    • 指を使って、アルミニウム製フレームの奥からデジタイザーリボンケーブルを引き抜きます。
    • iPadからフロントパネルを取り外します。
  42. iPad 4 Wi-Fiのバッテリーの交換, ヘッドホンジャックケーブル: 手順 42、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換, ヘッドホンジャックケーブル: 手順 42、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換, ヘッドホンジャックケーブル: 手順 42、 3の画像 3
    • ピンセットを使って、ヘッドホンジャックアセンブリケーブルコネクタを覆っている絶縁テープを引き剥がして外します。
    • スパッジャーの先端を使って、ヘッドホンジャックケーブルをロジックボードに固定している2つのZIFコネクタ上の固定フラップを跳ね上げます。
  43. iPad 4 Wi-Fiのバッテリーの交換: 手順 43、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 43、 2の画像 2
    • スパッジャーの平面側先端を、ヘッドホンジャックアセンブリのケーブルの下にスライドして、背面アルミフレームにケーブルを固定している接着剤を剥がします。
    • ヘッドホンジャックアセンブリのケーブルを、ロジックボード上のソケットからまっすぐ引き抜きます。
  44. iPad 4 Wi-Fiのバッテリーの交換, ロジックボードコネクタ: 手順 44、 1の画像 1
    • ロジックボード上の各ソケットから次のコネクタの接続を外します:
    • Wi-Fiアンテナケーブル
    • スピーカーコネクタケーブル
    • ドック/Lightningコネクタケーブル
    • このコネクタを覆っている黒のテープがあります。ピンセットを使って、テープを剥がします。
    • ソケットではなく、コネクタの下から持ち上げているか確認してください。ソケットを持ち上げると、深刻なダメージを引き起こす可能性があります。
    This was an ambiguous step. The Dock/Lightning connector and Wi-Fi antenna cable lift off fairly easily, but the Speaker connector cable does not. I ruined the existing Logic Board at this step. Not an emotional event, as I was replacing it, anyway, but showing how the connector looks, lifted out of it’s socket, would have helped. What tool did you use to pull/lift the connector from it’s socket? Prying from under the wires just stressed the wires, and I had to stop that attempt for fear of damaging the connector. Once I ripped the socket from the Logic Board, I was able to pry the two apart with my fingers, and had a better understanding of how to connect the Speaker cable to the replacement Logic Board. Sometimes these connections slide together, sometimes they’re pressed down into a socket connector. Do one when the other was intended, and you ruin things. You fell short, here.
    robk64 - 返信
    it would be helpful to show the image as to how to pry speaker connection cable.
    ian - 返信
    All connectors are pressed directly into the logic board (in the negative-Z direction). Use a spudger or, with extreme caution, tweezers, remove the connector straight out and away (plus-Z direction). Perform leverage as close to the connector as possible, to reduce any risk of wire damage. The dock/lightning connector is rectangular and centered in the depicted area highlighted in yellow.
    Josh Crim - 返信
    I applied some heat with a fan to the connector and pried him softly up from the left to the right. My first ipad went to !&&*, but with my workaround the second one was saved.
    Nils Grobys - 返信
    For the speaker cable, the connector needs to be lifted straight up to be released. The connector actually fits within a raised socket that surrounds it on three sides (up/camera side, and left and right sides). For this reason, don't try to pry directly from the left, the right, or the camera side, because you will actually be prying the socket rather than the connector. I used a pointed metal tweezer to pry on the bottom right corner immediately next to and just underneath where the wires connect. The socket popped off immediately with little force.
    chrism83 - 返信
    Not showing how the speaker cable comes off is a serious oversight. The connector lifted off logic board. Disappointed. Everything good until that critical point. And then, you don't have logic board in stock.
    Vincent Martinez - 返信
    Another another vote for needing more information on how to disconnect the speaker cable. That is a major oversight, and on my iPad 4 it didn’t pop off easily either, probably due to age.
    Lee Chong Yew - 返信
  45. iPad 4 Wi-Fiのバッテリーの交換, ロジックボード: 手順 45、 1の画像 1
    • ロジックボードをアルミニウム製リアパネルに固定している次の4本のネジを外します。
    • 2.1mm #00プラスネジ 3本
    • 2.5mm #00プラスネジ 1本
  46. iPad 4 Wi-Fiのバッテリーの交換: 手順 46、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 46、 2の画像 2
    • Lightningコネクタの反対側の端からロジックボードを掴んで、iPadから注意深く引き離します。
  47. iPad 4 Wi-Fiのバッテリーの交換, バッテリー: 手順 47、 1の画像 1
    • バッテリーは、大量の強力な接着剤でアルミニウムフレームに頑丈に固定されています。
    • 次の手順では、バッテリー下より1回あたり4cmずつ接着剤を除去していきます。 これにより、バッテリーに過度のストレスがかかるのを防ぎます。
    • iPadからバッテリーを取り外すときは、バッテリーに穴を開けたり損傷したりしないように十分注意してください。 バッテリーには有毒な化学物質が含まれており、吸入すると有害です。
    Ifixit please make a better quality metal spudger mine took a beating in this process.
    Rich1981 - 返信
    The danger of puncturing or breaking open a Lithium Ion battery cannot be emphasized strongly enough. I have first hand experience of trying to leaver out a battery from an iphone 7+ and it literally combusted on the desk I was working on. It was still in the case and fell onto the floor burning like a flare and filling the room and then the house with toxic smoke. I could not believe what I was seeing. Fortunately it burned out very quickly and I wasn’t burned, which was a miracle, unfortunately it destroyed the phone. I hate to think what would happen if you punctured a battery in an iPad . In short be very, very, very careful when trying to remove one of these batteries, take your time, be patient, and use a lot of heat and often to soften the glue
    Sean Wren - 返信
  48. iPad 4 Wi-Fiのバッテリーの交換: 手順 48、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 48、 2の画像 2
    • メタル製スパッジャーの平面側先端を、iPad下部付近の下に差し込みます。
    • メタル製スパッジャーをバッテリーの下に約3cmスライドして差し込み、接着剤を剥がします。
    • 接着剤は非常に強力なため、接着剤を乖離するにはかなりの力が必要です。慎重に、ゆっくりと作業を進めてください。メタル製スパッジャーが作業中、滑らないようにご注意ください。
    I do not recommend to remove the battery with the metal spudger.
    A used credit or customer card is the better way
    Andre Pankalla - 返信
    we here at pctechnologygroup use a 12” steel ruler to slide under the battery it helps to put iPad on heating mat to soften adhesive, we also put label remover on the ruler to cut through the tape
    richardjgreen - 返信
    using a spatula is also a good option
    Jonas Fischer - 返信
    I agree about the spatula—it’s strong and rigid. The long narrow ones that short-order cooks use are thinner and have a sharp edge. Also, you can use the iOpener, the heating pad you used to open the touchscreen. Put the iPad on top of the iOpener, so that it lies under whichever strip of glue you’re currently prying apart. It’s much more effective than it was with the glass screen, because the metal case conducts heat right to the glue.
    Brian Pickrell - 返信
  49. iPad 4 Wi-Fiのバッテリーの交換: 手順 49、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 49、 2の画像 2
    • 前の手順を参考にして、別の接着ストリップの下に、最大4cmまでスパッジャーをスライドして差し込みます。
  50. iPad 4 Wi-Fiのバッテリーの交換: 手順 50、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 50、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 50、 3の画像 3
    • メタル製スパッジャーをバッテリーコネクタの下にスライドして差し込み、コネクタを固定している接着剤を剥がします。
  51. iPad 4 Wi-Fiのバッテリーの交換: 手順 51、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 51、 2の画像 2
    • バッテリー上部付近の接着剤を続けて剥がします。
  52. iPad 4 Wi-Fiのバッテリーの交換: 手順 52、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 52、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 52、 3の画像 3
    • 最後の接着剤の端から始めて、金属スパッジャーをバッテリーの下に4cm差し込みます。
    • スパッジャーをさらにバッテリーの下に押し込みながら、リアケースに対してできるだけ水平にスパッジャーを保ってください。バッテリーが変形するのを防止できます。
    • 残りの接着剤についても同じ作業を繰り返します。
  53. iPad 4 Wi-Fiのバッテリーの交換: 手順 53、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 53、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 53、 3の画像 3
    • 前と同じ方法で、接着ストリップ全体の下約8cmまでスパッジャーを差し込んで、接着剤を剥がします。
  54. iPad 4 Wi-Fiのバッテリーの交換: 手順 54、 3の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 54、 3の画像 2 iPad 4 Wi-Fiのバッテリーの交換: 手順 54、 3の画像 3
    • 最後に、iPadの右側端に向けて、メタル製スパッジャーを一気に押し込みます。
    • この作業を反対側にも続けて、接着剤全体を剥がします。
  55. iPad 4 Wi-Fiのバッテリーの交換: 手順 55、 2の画像 1 iPad 4 Wi-Fiのバッテリーの交換: 手順 55、 2の画像 2
    • バッテリーから全ての接着剤が剥がれているか確認してください。
    • バッテリー左側をゆっくりと持ち上げます。iPad右側に向けて裏返すように持ち上げます。
    • 残っている接着剤があれば、メタル製スパッジャーを使って剥がします。
    • iPadからバッテリーを取り出します。
    Hello, just wondering, what type of glue or adhesive should I use when puttion it back to new housing? Thanks
    pendejo - 返信
    Just completed ipad 3 battery replacement. I might have killed the cellular connectivity because I got a missing sim card warning, which is no big deal because I never use it. I would put this as one of the most difficult fix it jobs I have done. During screen removal, I killed the super thin, black plastic bezel, and put a tiny micro crack in the front glass. After inflicting this damage, I decided, in for a penny in for a pound, and purchased both from iFixit and got quick delivery. Now I have an iPad with a decent battery and will try to get a couple more years out of it. If I had this job to do over and someone was willing to do it for $100, I would pay, but it always fun to fix something yourself.
    chuckcappetta - 返信
    That’s a nasty and still potentially hazardous battery to dispose of. A word here about what to do with it for disposal would be a nice addition.
    Haig Keshishian - 返信
終わりに
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。また、フロントパネルを再度取り付ける際は、私たちのiPad 4 Wi-Fiのフロントパネルの接着ストリップガイドを参照してください。
57 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
2人の作成者と共同で作成されました。
Walter Galan
694,692 ポイント
1,203のガイドは作成済み
9 件のコメント
I have just done this replacement, but have some problems now with the charging.
The iPad indicates charging (lightning symbol next to battery icon), but the charge does not "fill up", instead it resides at 0 percent.
When i disconnect the charger after a few hours, it shows 100%, but only lasts a short time before it plummets to 0% again.
Is there something that needs to be done in the settings etc after replacing the battery? Do i need to reset the iPad, or "tell it" that it has a new battery..?
oyvindrosmer - 返信
Could Be a Charging IC Usually the second culprit of a dying battery.
stephenthormodson -
Thanks for a very precise tutorial! Just completed it and all seems perfect.
Lara Snuffer - 返信
I experienced major confusion during reassembly when attempting to insert the ribbon cable into the ZIF connector slot. An illustration of this would have saved some heart-ache. Otherwise an excellent guide!
Stephen Svoboda - 返信
What adhesive is best to attach the new battery?
Tina Ward - 返信
I had no problem except the LH Adhesive was applied directly on entire side of the digitizer and it was destroyed. When I put it back together with a new front panel I made sure the strip was on the frame. A couple of close ups would be nice.
Hitech Expert - 返信
Everything is very good, but step 29 should be “Disconnect the battery“!
Alexey Astashkov - 返信
Whew! this was by far the most complicated repair I’ve done. Very difficult because glue is the worst. Here’s a few pointers: 1.) ZIF connectors…be careful, be sure you know which direction the little hold-down bar flips up (toward the cable.) and proceed carefully. 2.) The flat cable slides out, not up. 3.) When reinserting the flat cable, make sure you insert it so the printed guide line on the cable aligns with the ZIF connector, otherwise you digitizer or LCD will not work. 4.) If you smell a funny chemical smell whilst gouging out the battery, you have torn the foil on the battery. The fumes are toxic, get ventilation and be more careful as you proceed. A respirator and gloves are not overdoing it at this point. The Glue Is A Pain! 5.)Your old battery will probably not come out in one piece. Do not throw it in the garbage, take it to an electronic waste site.
This job took me four hours and I’m not going to do this one again. Not for a device that’s 10 years old.
mkeehnel - 返信
Was successful. Thanks. Two things on reassembly. Really need to put the screen adhesive on when it is removed. Natural to do it last since putting the screen on is the last step, but that is a hassle. Also, you need to be extra careful with both the button cable insertion and routing, it is easy to get it smashed when you fold things back together.
cmintz - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 45
過去 30 日: 219
今までの合計 65,927
