メインコンテンツにスキップ
iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換
必要な工具と部品
  1. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換, ディスプレイアセンブリ: 手順 1、 1の画像 1
    この手順で使用する道具:
    iMac Intel 21.5" Cardboard Service Wedge
    購入する
    • ヒンジを外すと、iMacはバランスが取れなくなり、作業が難しくなります。iMac Service Wedgeがあれば修理作業は素早く、簡単ですが、なくても対応できます。
    • iFixitの梱包用ボックスを使ってウェッジ用サポートを作ることができます。こちらから組み立てガイドを参照してください。
    • iMacの作業を始める前に、コンピューターの電源を外して電源のキャパシタを放電するため約10秒間電源を押し続けてください。
    • キャパシタの鉛や、電源の裏側にある露出した半田付け接合部分に接触しないよう、特にご注意ください。基盤の端のみを持ってください。
    The wedge is an extremely tight fit for this model. I was worried that the amount of force needed to use it as shown might damage the stand, so I used it with the long side down instead. It worked fine that way and didn’t need anywhere near as much force to insert.
    roberttrevellyan - 返信
    Here’s a good YouTube vid on upgrading the RAM: Can a Normal Person Upgrade the RAM in the 2017 21.5" iMac?
    Dan - 返信
    Here are a couple tips from me:
    1) Expose the adhesive to extreme temperatures. I did this by transporting my iMac in my car, screen-down on a piece of cardboard on a cold February morning (in Chicago). When I went to pick up the iMac, the screen practically fell off the chassis. I would have been distraught by this if I hadn’t already planned this replacement. So it was a happy accident.
    2) Remember to expell the residual power from the power supply by pushing the power button while the iMac is unplugged. This does NOT guarantee it’s safe to touch, but when I accidentally brushed the solder and exposed capacitors, I didn’t get shocked.
    jerrid_foiles - 返信
    Instead of using the wedge, I placed the iMac faced up with the top side (web cam) facing me while I ran the pizza roller around. It worked out great!
    Sam Fung - 返信
    “All iMacs also come with a traditional hard drive” mine doesn’t!! it’s HDD bay is completely empty, no SATA cable or anything. I guess I’ll have to upgrade the PCIe SSD instead.
    Chris Hughes - 返信
    There is no replacement glass for this model, it is part of the LCD and impossible to remove or replace- the entire LCD has to be replaced unfortunately if the glass is cracked or damaged. You will have to Google search for a replacement. Also be careful with some of the lock tight tork screws as I broke one of my screw mounts taking one out.
    Phil Tesone - 返信
    I used this service wedge but also found it a very tight fit. The same stabilization can be achieved by using a big rolled up towel.
    Ernst - 返信
    While this is a good instruction guide, I recommend to also look at OWC’s instruction video about drive installation, before starting the exercise. Those install videos are very detailed and useful.
    Ernst - 返信
    Main advice: TAKE YOUR TIME with the pizza roller.
    Make several passes, until you really feel like there's no more sticker in the way. Stay away from the camera though (approx. 1inch / 2.5cm on both sides). This will reduce the work left with the plastic card. Adhesive is really on the edge of the screen so there is absolutely no need to go any further than the recommended 1cm / 3/8inch depth.
    Where are the sensitive parts?
    Facing your iMac, imagine you're looking at a watch. There are antennas on 1, 2 and 4 o'clock. Do not insert any metal piece there (nor anywhere else, btw). Other than that AND the screen cables underneath the camera, not much danger.
    Froggy Manny - 返信
  2. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 2、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 2、 2の画像 2
    • ディスプレイの左側の電源付近から、iMac開口ツールをガラスパネルと背面エンクロージャーの間に差し込みます。
    • iMac開口ツール上の回転軸を押し込んでもディスプレイの奥深くまで届きません。もし異なるツールを使用する場合、ディスプレイから9.5mm以上は差し込まないでください。それ以上深く差し込むと、アンテナケーブルに深刻なダメージを与えてしまいます。
    Don’t get too worried about starting exactly where the picture says. The glue is stronger in some parts so just start wherever is easier and then work slowly and patiently around in the direction shown.
    Richard Cook - 返信
    As this guide doesn’t cover replacing the adhesive strips, I found referring to the following was useful (noting that it’s not for the same model of iMac, so the modification they mention wasn’t necessary): iMac Intel 21.5インチ EMC 2544の接着ストリップの交換
    Alan Digby - 返信
    It is very easy to crack the glass in front of the LCD during this step. I used the guitar pick, maybe it was too thick… crack is just on the frame but anyway it is disappointing :(
    Nikolay - 返信
    This part of the exercise should be done with extreme patience. I took my sweet time with the opening tool, rolling it through the entire panel and enclosure gap over and over again, until I was very sure no parts were sticking together anymore. And when I thought I was I done, I decided to do it over again.
    Ernst - 返信
    You can "warm up" the adhesive before try to cut it with the tool using a hair dryer. Heat the edges for about a minute, keep moving it so you don't cause stress in the glass. Also the above note.. use the tool and then the cards. Do not use a guitar pick or other objects as the thickness will cause you to break the front glass, which is a bonded part of the display (expensive).
    Carl Schultz - 返信
    Merci pour ce conseil
    bry nicolas -
  3. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 3、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 3、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 3、 3の画像 3
    • ピザカッターのようにツールを使いますー隙間に沿ってスライスしながら、フォーム製接着剤を切り込んでください。
    • カット用の車輪の裏の持ち手をしっかり持って内側に押し込んでください。もし外向きに引っ張ると車輪がハンドルから外れてしまいます。
    • ツールをディスプレイの左側に沿って下側から上部に向けてスライスします。
    Erreur de traduction: "de bas en haut" et non de" haut en bas" sur le côté gauche de l'écran
    Moreau - 返信
    If re-opening a screen that was opened and re-attached using iFixit’s adhesive strips, I would strongly recommend heating it first with an iOpener, heat gun or hair dryer. 20 minutes after attaching with the iFixit adhesive I tried to open it again with the pizza slicer to fix something and cracked the screen on the left-hand side.
    plasticpool - 返信
  4. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 4、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 4、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 4、 3の画像 3
    • 左側コーナー上部周辺までスライスします。
    Ne pincez pas l’écran avec l’autre main. Vous exercez une pression inutile sur le verre et empêchez la roulette de couper le joint.
    phfoglia - 返信
  5. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 5、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 5、 2の画像 2
    • ディスプレイ上部左側から接着剤を切開します。
  6. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 6、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 6、 2の画像 2
    • ディスプレイ上部に沿って開口ツールをスライスします。
    • すでに切開した箇所も、接着剤が完全に切断されているか確認するため、複数回に渡って前後にスライドしてください。
    In this step can I cut along the display without make any damage to the front camera?
    arisnordico - 返信
    Hi! Actually - there is no need to cut the tape around the camera area - there is no tape to cut at all! And so, the way go is easy - just pass 10 mm to the left and to the right from camera and start cutting!
    P.S. Just did the whole procedure to replace a RAM and to add SSD on PSIe an hour ago! Seems to be different reading the instructions... you know - 2/10 and so on. But it's really not that hard, trust me. I'll give it 5/10.
    P.P.S. By the way there is one trick to pass the difficult steps. Any action which requires pulling smth (motherboard, speaker, power supply unit) from the narrow crack (or should i say - slit?) at the bottom of your Imac is really not so easy.
    And the trick is to first remove a thin metal stripe with some kind of insulation on it which held by 5 small (very small!!) screws at the bottom of your Imac. After you done it - it's easy to pull everything! Pay attention to the fact that one of this 5 screws at the center are more shortly than others.
    dv1977 - 返信
    I did all steps like this manuell but now the Display wont work only some colered strips are to see! Whats happend??
    Can anybody help me ? Maybe the connector cable is broken?
    djfanta - 返信
    Check both connectors, probably one of them not seated well
    pzhivulin -
    You can add a SATA SSD if you already have a PCIe SSD Factory?
    kaserlik - 返信
    If you're changing cracked EMC 2638 display to new assembly, there's two more steps:
    Step 24: Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
    Carefully pull the display data cable from its socket on the display assembly.
    Step 25: Use the tip of a spudger to unplug bracket of the thermal sensor small cable near display data cable.
    Carefully remove scotch tape covering thermal sensor. Using iSesamo or flat tip of the spudger carefully peel the thermal sensor away.
    pzhivulin - 返信
    omg - forgot to switch the termal sensor from the old display...
    now fan runs like crazy...
    Andrei Balotescu -
    The key thing is to never put any force on the opening tool when working through the tape. Just roll it back and forth with ease.
    Ernst - 返信
  7. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 7、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 7、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 7、 3の画像 3
    • ディスプレイ上部の右側コーナー周辺までツールをスライドしながら、接着剤を切開します。
  8. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 8、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 8、 2の画像 2
    • ディスプレイの右側に沿ってツールを上部から下側に向けてスライドします。
  9. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 9、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 9、 2の画像 2
    • ディスプレイ右側の下部まで開口ツールをスライドさせて、ここで作業を終えます。
    • ここでもう一度、ディスプレイ全体に沿って開口ツールをスライドさせ、接着剤をスライスできたか確認しましょう。
    Yes, do it many times to loosen the adhesive.
    Noah Ralston - 返信
    Would be good data to show the 3 areas (wifi antennas where the "tape" is larger and covers them. The rest of the "tape" is 1.4" and easy. Also after removing the display, be sure to remove the old "tape" from both the display and the rubber parts of the case. Use the spudger to start an end and it should pull off easily. Careful on the baackside of the display as you can scratch off the black paint/covering.
    Carl Schultz - 返信
  10. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 10、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 10、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 10、 3の画像 3
    • 開口ツールがディスプレイ上の接着剤の大部分を切断できても、ディスプレイはわずかにケースに装着されたままです。残りの接着剤から完全に乖離するため、プラスチックカードを使用してください。
    • iMacのフロント側を上向きにしてテーブル上に置いてください。
    • iMac右側の上部から、ディスプレイとフレームの間にプラスチックカードを差し込みます。
    • 9.5mm以上はプラスチックカードを差し込まないでください。内部コンポーネントにダメージを与えてしまいます。
    this step is extremely important NOT to stick in the cards too far….. doing so, you risk a 600 euro replacement as I experienced………
    Edgar Broekema - 返信
    I drew a 3/8” line on my cards with a marker first.
    Max Romano - 返信
    I’m reading this on the EU store, please change all measurements to cm/mm.
    Morgana Devina - 返信
    @ifixit The next batch of cards you create should have a line printed on the card 3/8” in from the edges. Would make a nice reference.
    Richard Giratd - 返信
    Here’s where OWC provides glass removal suction cups, which is a better solution than plastic cards.
    The suction cups help to easily lift the glass panel, without risking the damaging of any internal wiring that the plastic cards could cause.
    Ernst - 返信
    Better to remove stand wedge at this point? Can’t see from pics
    derekrobinson - 返信
  11. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 11、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 11、 2の画像 2
    • ディスプレイとフレームの間に隙間を作るように、丁寧にプラスチックを外側に向けてひねります。
    • ディスプレイのガラスに圧力がかからないように注意しながら、ゆっくりと動かします。約6mm程度の隙間ができれば十分です。
    This part must be done very carefully or you can damage the flat cable from display, despite it was under a iron cover.
    Cassio Machado - 返信
  12. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 12、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 12、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 12、 3の画像 3
    • 残りの接着剤を乖離させながら、iMacの上部右側コーナーからディスプレイ中央に向けてプラスチックカードをスライドします。
    • iSightカメラ手前で止めてください。これ以上進むとダメージを与えてしまいます。
    You don't need to do it like this, simply open the iMac bendidng the LCD completely and use the pizza cutter to remove the adhesive.
    Felix - 返信
    Using glass removal suction cups will avoid running this risk of damaging the camera (or any wiring).
    Ernst - 返信
  13. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 13、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 13、 2の画像 2
    • 接着剤が再装着するのを防ぐため、ディスプレイ上部右側コーナー付近にプラスチックカードを差し込んだままにします。
  14. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 14、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 14、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 14、 3の画像 3
    • 2枚目のプラスチックカードをiMac上部左側付近のディスプレイとフレームの隙間に差し込みます。
  15. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 15、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 15、 2の画像 2
    • ゆっくりとカードを上向きにツイストして、ディスプレイとフレームの間の隙間を広げます。
    • 反対側も同様に、接着剤が乖離するようにゆっくりとツイストします。ディスプレイのガラスに余分な圧力がかからないようご注意ください。
  16. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 16、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 16、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 16、 3の画像 3
    • プラスチックカードを中央に向けてゆっくりとスライドして、iSightカメラの手前で止めます。
  17. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 17、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 17、 2の画像 2
    • プラスチックカードを左側上部コーナーの裏側に差し込みます。
  18. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 18、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 18、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 18、 3の画像 3
    • コーナー付近に差し込んだ2枚のプラスチックカードを手に取り、ディスプレイとケースの間の隙間を広げるようにカードを外側に向けてツイストします。
    • もし接着剤が剥がれていない箇所がある場合はツイスト作業を止めて、どちらかのカードを使って接着剤を切断します。
    • フレームからディスプレイ上部を持ち上げます。
    • 約5cm程度以上は、ディスプレイを持ち上げないでください。ディスプレイデータケーブルやパワーケーブルが基板に接続されたままの状態です。
  19. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換, ディスプレイアセンブリケーブル: 手順 19、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換, ディスプレイアセンブリケーブル: 手順 19、 2の画像 2
    • コネクタにアクセスできるほどのスペースを作るため、ディスプレイを持ち上げます。しかし、ケーブルが伸びて、コネクタの接続部分にストレスを与えないように、持ち上げすぎないようご注意ください。(約15cm程度が目安)
    • ディスプレイを片手で持ちながら、もう一方の手でディスプレイパワーケーブルの接続を外します。
    It was difficult to remove this connection. I ended up having to gently pull-up vertically a little on the wire side to unsnap it about 1mm and then horizontally wiggle it out.
    delacrj2 - 返信
    I had a difficult time removing this connection. I had to lift the wire-side about 1mm before it unsnapped and then carefully wiggle it out horizontally.
    delacrj2 - 返信
    Can this cable be replaced? I am worried mine is damaged. I have no display after the screen fell and stressed the display flex cables following an SSD upgrade.
    Jeremy Brainard - 返信
    This step should be done with extreme caution and care, as this step 19 is not described in great detail (sorry, author).
    The first (most outward) cable will slide out by gently pulling it by its tabs. The second (inner) cable is more tricky, as the locking lever must be moved backward first, before gently pulling backward on the cable connector. The angled tweezers are useful here, to help lift that locking lever, because fingers are too big for this.
    Ernst - 返信
    be VERY careful and SLOW...take your time. These displays crack VERY easily when removing and they'll spider web on you. I've done probably 20 or so of these and cracked 3 being super careful.....ugh.
    Faslane - 返信
    I found the best way to unplug this display power cable was to use my right hand, and the fingernails of my index finger and thumb to grab the ends of the tabs on either side of the connector, squeeze, and pull the connector out gently.
    Phil McInnis - 返信
    i think the cable nearest the case edge is held in by friction and can be gently pulled, maybe with fingernails or a spudger. The next cable is held by a wire lever clip as described above it unlocks so the cable can be removed. These cables are also fiddly to re-insert, I didn't get one of them home and had no display after power-up, so at the end, don't re-seal the screen until tested.
    Peter Taffs - 返信
  20. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 20、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 20、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 20、 3の画像 3
    • 引き続きディスプレイを片手で固定しながら、ディスプレイデータケーブル上にあるメタル製固定ブラケットを裏返します。
    • ロジックボード上のソケットから、ディスプレイデータケーブルをゆっくりと引っ張ります。
    • ディスプレイデータケーブルのコネクタを、ソケットからまっすぐ引っ張ります。その際、マザーボードにダメージを与えないよう気をつけながら、ケーブルをマザーボードと並行にして引き抜いてください。
    Cannot seem to find a replacement cable for this, as I suspect mine is damaged. Can’t even find a part number. Anyone know what it might be?
    https://www.amazon.com/gp/product/B08TTL...
    That's the part I ordered for mine and it seems to work ok. I did make a point of contacting the seller and advising them of my requirement and they ensured I got the right part and it matches the description of the link. Bear in mind I bear no responsibility if yours does not work since I am just sharing what I did and what I ordered. Thanks.
    Jim Stanford -
    I also need that cable.
    cameronjpu - 返信
    It's a little difficult to tell... but looking at the connection to the logic board on the video data cable, are the pins faced up or down?
    On the display, same question since it appears you have to "twist" the cable during the reconnection step.
    Jim Stanford - 返信
    For this particular cable, take a good look before pulling on anything. Plug is locked on its socket with a bracket. You can lift this bracket by holding the small, flat black plastic handle that is attached to it. If you're struggling to grab it, use the end of the pizza roller handle to lift it, or the tweezers. Cable then comes off by pulling parallel to the main board.
    Froggy Manny - 返信
    How can I tell if either of this cable is bad? My iMac display won't turn on after reconnecting it. I'm using an external display and everything is working except for the iMac display. If I go to settings - display the built-in display is recognize. But again nothing shows up in the screen - not even the apple logo when turning it on.
    Carlos Sosa - 返信
  21. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換, ディスプレイアセンブリの乖離方法: 手順 21、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換, ディスプレイアセンブリの乖離方法: 手順 21、 2の画像 2
    • ディスプレイをほぼ垂直になるまで持ち上げます。
    • この時点で、ディスプレイの下部に沿ってヒンジのようにフレームにディスプレイを固定しているする接着剤のストリップがまだ付いています。 ディスプレイを数回上下させると、この接着剤を緩めることができます。
    The best way to remove the chin adhesive is to use the tabs at either end (there are two strips that run from each outside corner to near the centre). Carefully pull the tabs up and the strips should peel off.
    Advance Technical Service - 返信
  22. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 22、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 22、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 22、 3の画像 3
    • 必要に応じて、プラスチックカードを使って底側の接着剤ストリップを切開できます。
    • 下端ディスプレイの接着ストリップ片側の端にある小さなタブをつかみ、接着剤をiMac上部側に引き寄せて剥がします。
    • この手順をもう一方の接着ストリップでも同じ作業を繰り返し、取り除きます。
    • どちらかの接着ストリップが切断して取り出せない場合は、プラスチックカードを使って、残りの接着ストリップ片を切り取ってください。
    At step 21-22, releasing the adhesive strips from the bottom of the display, I noticed a tab on the outer end of each strip. Pull the tab to remove the whole strip, no need to mess around with the plastic cards!
    Instead of the plastic cards, use the flat end of a spudger. Use it as scraper. Be careful as there are antennas mounted on the inside edge of the frame on the right side (facing you), and the top right (facing you). The original adhesive strips are on those as well. - ECJ
    ECJohansen - 返信
    A little bit of hot air (eg. hair dryer) will help soften the adhesive. Use a piece of cardboard or equivalent if you want to avoid blowing hot air towards the electronics.
    Be careful to remove absolutely everything - any remainder will create a bump and prevent your screen from sticking back to the frame when reassembling.
    Froggy Manny - 返信
    Froggy Manny - 返信
  23. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 23、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 23、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 23、 3の画像 3
    • ディスプレイをフレームから持ち上げて、iMacより取り出します。
    • 片側からゆっくりと持ち上げて、残っている接着剤を剥がしてください。
    • ディスプレイの取り扱いは特にご注意くださいー重量があり、大きく、ガラス製です。
    • 接着剤が切開できたら、古い接着ストリップはディスプレイを固定するために再利用することはできません。このガイドに従って、接着ストリップを交換して、リアエンクロージャーとディスプレイを固定してください。
    Après l'étape 23, j'ai suivi les instructions de la vidéo intitulée: Upgrade RAM in a mid-2017 21-inch iMac without complete disassembly.
    Lien: https://www.youtube.com/watch?v=_k9I7N9B...
    J'ai pu upgrader la RAM en enlevant juste le ventilateur.
    Koala - 返信
  24. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換, AirPort/Bluetooth カード: 手順 24、 1の画像 1
    • 4つのアンテナコネクタとAirPort/Bluetoothカードを固定している4.0 mm T5トルクスネジを2本外します。
    • 小さなワッシャーが各ネジに付いています。紛失しないようにご注意ください。
  25. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 25、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 25、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 25、 3の画像 3
    • スパッジャーを使って、AirPort/Bluetoothカード上のソケットから4つ全てのアンテナコネクタを持ち上げて、接続を外します。
  26. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 26、 1の画像 1
    • AirPort/Bluetoothカードをロジックボードに固定している3.3mm T5トルクスネジを2本外します。
  27. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 27、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 27、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 27、 3の画像 3
    • AirPort/Bluetoothカードにアクセスするために、アンテナケーブルを慎重に脇に寄せます。
  28. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 28、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 28、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 28、 3の画像 3
    • AirPort/Bluetoothカードをロジックボードから1-2 mm以上引き抜かないでください。深刻なダメージに繋がります。
    • AirPort/Bluetoothカードの端をしっかりと掴んで、ロジックボード下側のソケットからまっすぐ引き抜きます。
    • 指でアンテナコネクタのソケットを触らないようにご注意ください。油脂はメタルの腐食の原因となり、接触障害を起こす可能性があります。
  29. iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 29、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 29、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) AirPort/Bluetoothカードの交換: 手順 29、 3の画像 3
    • 再組立の際に、AirPortカードのインストールが難しい場合は、先端がカーブしたピンセットを使用して、カードの向きを調整し、ロジックボードの背面にあるスロットに差し込みます。
    • ピンセットを下向きにして、アンテナコネクトソケットの隣にあるAirportカードのネジ穴に先端を通します。
    • 指を使って、AirMacカードの端を押し下げて、ロジックボードとほぼ水平になるまで角度を調整します。
    • AirMacカードをロジックボードのスロットに合わせ、コネクタ付近のネジ穴とロジックボードのネジ穴の位置が揃うまでカードをスロットに押し込みます。
    • 参考までに、3番目の画像は、AirMacカードのインストール方法を分かりやすくするために、ロジックボードを取り外して裏返した状態です。
終わりに
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
2人の作成者と共同で作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
196,299 ポイント
416のガイドは作成済み
3 件のコメント
Hello, I would like to know which other airport is compatible with this model of IMAC 21.5 "? I have 1 2017 4k but do not find to buy this Airport and maybe it is compatible with another, can you help me?
Jonathas - 返信
Thanks for the guide Asam!
@johnninfor
Yes, I would like to know as well the exact model number for iMac 21.5 4K 2017? The other iMac guides sugged another module that may not be compatible with this model? The only bits that are readable are BCM?
Oh, I saw it - step 29, I must be blind ;) It’s BCM943602CDP, thanks!
Martin Lambev - 返信
I may have damaged the sockets for the antenna connectors (#1 and #3 reading from L -R) in the process of reassembling my late 2017 iMac after replacing my 8 GB RAM DIMMs (REMBER testing after a kernel panic failed, and OWC sent me new DIMMs, which pass REMBER testing.
However, now I cannot pair my BT mouse, or unlock the iMac with my Apple Watch, or pair my AirPods Pro reliably. Curiously, my Magic keyboard works just fine. When the AirPods Pro seem to pair, the music playback to them is awful (stuttering). I know that I couldn’t pop those two antenna connectors onto the little pins on the BT/Airport board the way they were before, but I don’t seem to have any network issues (SPEEDTEST results are similar to previous testing). I don’t know where to get an Airport/BT card or whether that really is my issue, but it certainly corresponds to making the repair. I did reset NVRAM and delete the BT p-list files; neither of those seemed to make any difference.
Jim Robertson - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 36
過去 30 日: 123
今までの合計 5,991
