メインコンテンツにスキップ
iMac Intel 21.5インチ EMC 2638 電源ユニットの交換
必要な工具と部品
  1. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換, ディスプレイアセンブリ: 手順 1、 1の画像 1
    この手順で使用する道具:
    iMac Intel 21.5" Cardboard Service Wedge
    購入する
    • ヒンジを外すと、iMacはバランスが取れなくなり、作業が難しくなります。iMac Service Wedgeがあれば修理作業は素早く、簡単ですが、なくても対応できます。
    • iFixitの梱包用ボックスを使ってウェッジ用サポートを作ることができます。こちらから組み立てガイドを参照してください。
    • iMacの作業を始める前に、コンピューターの電源を外して電源のキャパシタを放電するため約10秒間電源を押し続けてください。
    • キャパシタの鉛や、電源の裏側にある露出した半田付け接合部分に接触しないよう、特にご注意ください。基盤の端のみを持ってください。
    The wedge is an extremely tight fit for this model. I was worried that the amount of force needed to use it as shown might damage the stand, so I used it with the long side down instead. It worked fine that way and didn’t need anywhere near as much force to insert.
    roberttrevellyan - 返信
    Here’s a good YouTube vid on upgrading the RAM: Can a Normal Person Upgrade the RAM in the 2017 21.5" iMac?
    Dan - 返信
    Here are a couple tips from me:
    1) Expose the adhesive to extreme temperatures. I did this by transporting my iMac in my car, screen-down on a piece of cardboard on a cold February morning (in Chicago). When I went to pick up the iMac, the screen practically fell off the chassis. I would have been distraught by this if I hadn’t already planned this replacement. So it was a happy accident.
    2) Remember to expell the residual power from the power supply by pushing the power button while the iMac is unplugged. This does NOT guarantee it’s safe to touch, but when I accidentally brushed the solder and exposed capacitors, I didn’t get shocked.
    jerrid_foiles - 返信
    Instead of using the wedge, I placed the iMac faced up with the top side (web cam) facing me while I ran the pizza roller around. It worked out great!
    Sam Fung - 返信
    “All iMacs also come with a traditional hard drive” mine doesn’t!! it’s HDD bay is completely empty, no SATA cable or anything. I guess I’ll have to upgrade the PCIe SSD instead.
    Chris Hughes - 返信
    There is no replacement glass for this model, it is part of the LCD and impossible to remove or replace- the entire LCD has to be replaced unfortunately if the glass is cracked or damaged. You will have to Google search for a replacement. Also be careful with some of the lock tight tork screws as I broke one of my screw mounts taking one out.
    Phil Tesone - 返信
    I used this service wedge but also found it a very tight fit. The same stabilization can be achieved by using a big rolled up towel.
    Ernst - 返信
    While this is a good instruction guide, I recommend to also look at OWC’s instruction video about drive installation, before starting the exercise. Those install videos are very detailed and useful.
    Ernst - 返信
    Main advice: TAKE YOUR TIME with the pizza roller.
    Make several passes, until you really feel like there's no more sticker in the way. Stay away from the camera though (approx. 1inch / 2.5cm on both sides). This will reduce the work left with the plastic card. Adhesive is really on the edge of the screen so there is absolutely no need to go any further than the recommended 1cm / 3/8inch depth.
    Where are the sensitive parts?
    Facing your iMac, imagine you're looking at a watch. There are antennas on 1, 2 and 4 o'clock. Do not insert any metal piece there (nor anywhere else, btw). Other than that AND the screen cables underneath the camera, not much danger.
    Froggy Manny - 返信
  2. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 2、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 2、 2の画像 2
    • ディスプレイの左側の電源付近から、iMac開口ツールをガラスパネルと背面エンクロージャーの間に差し込みます。
    • iMac開口ツール上の回転軸を押し込んでもディスプレイの奥深くまで届きません。もし異なるツールを使用する場合、ディスプレイから9.5mm以上は差し込まないでください。それ以上深く差し込むと、アンテナケーブルに深刻なダメージを与えてしまいます。
    Don’t get too worried about starting exactly where the picture says. The glue is stronger in some parts so just start wherever is easier and then work slowly and patiently around in the direction shown.
    Richard Cook - 返信
    As this guide doesn’t cover replacing the adhesive strips, I found referring to the following was useful (noting that it’s not for the same model of iMac, so the modification they mention wasn’t necessary): iMac Intel 21.5インチ EMC 2544の接着ストリップの交換
    Alan Digby - 返信
    It is very easy to crack the glass in front of the LCD during this step. I used the guitar pick, maybe it was too thick… crack is just on the frame but anyway it is disappointing :(
    Nikolay - 返信
    This part of the exercise should be done with extreme patience. I took my sweet time with the opening tool, rolling it through the entire panel and enclosure gap over and over again, until I was very sure no parts were sticking together anymore. And when I thought I was I done, I decided to do it over again.
    Ernst - 返信
    You can "warm up" the adhesive before try to cut it with the tool using a hair dryer. Heat the edges for about a minute, keep moving it so you don't cause stress in the glass. Also the above note.. use the tool and then the cards. Do not use a guitar pick or other objects as the thickness will cause you to break the front glass, which is a bonded part of the display (expensive).
    Carl Schultz - 返信
    Merci pour ce conseil
    bry nicolas -
  3. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 3、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 3、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 3、 3の画像 3
    • ピザカッターのようにツールを使いますー隙間に沿ってスライスしながら、フォーム製接着剤を切り込んでください。
    • カット用の車輪の裏の持ち手をしっかり持って内側に押し込んでください。もし外向きに引っ張ると車輪がハンドルから外れてしまいます。
    • ツールをディスプレイの左側に沿って下側から上部に向けてスライスします。
    Erreur de traduction: "de bas en haut" et non de" haut en bas" sur le côté gauche de l'écran
    Moreau - 返信
    If re-opening a screen that was opened and re-attached using iFixit’s adhesive strips, I would strongly recommend heating it first with an iOpener, heat gun or hair dryer. 20 minutes after attaching with the iFixit adhesive I tried to open it again with the pizza slicer to fix something and cracked the screen on the left-hand side.
    plasticpool - 返信
  4. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 4、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 4、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 4、 3の画像 3
    • 左側コーナー上部周辺までスライスします。
    Ne pincez pas l’écran avec l’autre main. Vous exercez une pression inutile sur le verre et empêchez la roulette de couper le joint.
    phfoglia - 返信
  5. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 5、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 5、 2の画像 2
    • ディスプレイ上部左側から接着剤を切開します。
  6. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 6、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 6、 2の画像 2
    • ディスプレイ上部に沿って開口ツールをスライスします。
    • すでに切開した箇所も、接着剤が完全に切断されているか確認するため、複数回に渡って前後にスライドしてください。
    In this step can I cut along the display without make any damage to the front camera?
    arisnordico - 返信
    Hi! Actually - there is no need to cut the tape around the camera area - there is no tape to cut at all! And so, the way go is easy - just pass 10 mm to the left and to the right from camera and start cutting!
    P.S. Just did the whole procedure to replace a RAM and to add SSD on PSIe an hour ago! Seems to be different reading the instructions... you know - 2/10 and so on. But it's really not that hard, trust me. I'll give it 5/10.
    P.P.S. By the way there is one trick to pass the difficult steps. Any action which requires pulling smth (motherboard, speaker, power supply unit) from the narrow crack (or should i say - slit?) at the bottom of your Imac is really not so easy.
    And the trick is to first remove a thin metal stripe with some kind of insulation on it which held by 5 small (very small!!) screws at the bottom of your Imac. After you done it - it's easy to pull everything! Pay attention to the fact that one of this 5 screws at the center are more shortly than others.
    dv1977 - 返信
    I did all steps like this manuell but now the Display wont work only some colered strips are to see! Whats happend??
    Can anybody help me ? Maybe the connector cable is broken?
    djfanta - 返信
    Check both connectors, probably one of them not seated well
    pzhivulin -
    You can add a SATA SSD if you already have a PCIe SSD Factory?
    kaserlik - 返信
    If you're changing cracked EMC 2638 display to new assembly, there's two more steps:
    Step 24: Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
    Carefully pull the display data cable from its socket on the display assembly.
    Step 25: Use the tip of a spudger to unplug bracket of the thermal sensor small cable near display data cable.
    Carefully remove scotch tape covering thermal sensor. Using iSesamo or flat tip of the spudger carefully peel the thermal sensor away.
    pzhivulin - 返信
    omg - forgot to switch the termal sensor from the old display...
    now fan runs like crazy...
    Andrei Balotescu -
    The key thing is to never put any force on the opening tool when working through the tape. Just roll it back and forth with ease.
    Ernst - 返信
  7. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 7、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 7、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 7、 3の画像 3
    • ディスプレイ上部の右側コーナー周辺までツールをスライドしながら、接着剤を切開します。
  8. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 8、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 8、 2の画像 2
    • ディスプレイの右側に沿ってツールを上部から下側に向けてスライドします。
  9. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 9、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 9、 2の画像 2
    • ディスプレイ右側の下部まで開口ツールをスライドさせて、ここで作業を終えます。
    • ここでもう一度、ディスプレイ全体に沿って開口ツールをスライドさせ、接着剤をスライスできたか確認しましょう。
    Yes, do it many times to loosen the adhesive.
    Noah Ralston - 返信
    Would be good data to show the 3 areas (wifi antennas where the "tape" is larger and covers them. The rest of the "tape" is 1.4" and easy. Also after removing the display, be sure to remove the old "tape" from both the display and the rubber parts of the case. Use the spudger to start an end and it should pull off easily. Careful on the baackside of the display as you can scratch off the black paint/covering.
    Carl Schultz - 返信
  10. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 10、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 10、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 10、 3の画像 3
    • 開口ツールがディスプレイ上の接着剤の大部分を切断できても、ディスプレイはわずかにケースに装着されたままです。残りの接着剤から完全に乖離するため、プラスチックカードを使用してください。
    • iMacのフロント側を上向きにしてテーブル上に置いてください。
    • iMac右側の上部から、ディスプレイとフレームの間にプラスチックカードを差し込みます。
    • 9.5mm以上はプラスチックカードを差し込まないでください。内部コンポーネントにダメージを与えてしまいます。
    this step is extremely important NOT to stick in the cards too far….. doing so, you risk a 600 euro replacement as I experienced………
    Edgar Broekema - 返信
    I drew a 3/8” line on my cards with a marker first.
    Max Romano - 返信
    I’m reading this on the EU store, please change all measurements to cm/mm.
    Morgana Devina - 返信
    @ifixit The next batch of cards you create should have a line printed on the card 3/8” in from the edges. Would make a nice reference.
    Richard Giratd - 返信
    Here’s where OWC provides glass removal suction cups, which is a better solution than plastic cards.
    The suction cups help to easily lift the glass panel, without risking the damaging of any internal wiring that the plastic cards could cause.
    Ernst - 返信
    Better to remove stand wedge at this point? Can’t see from pics
    derekrobinson - 返信
  11. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 11、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 11、 2の画像 2
    • ディスプレイとフレームの間に隙間を作るように、丁寧にプラスチックを外側に向けてひねります。
    • ディスプレイのガラスに圧力がかからないように注意しながら、ゆっくりと動かします。約6mm程度の隙間ができれば十分です。
    This part must be done very carefully or you can damage the flat cable from display, despite it was under a iron cover.
    Cassio Machado - 返信
  12. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 12、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 12、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 12、 3の画像 3
    • 残りの接着剤を乖離させながら、iMacの上部右側コーナーからディスプレイ中央に向けてプラスチックカードをスライドします。
    • iSightカメラ手前で止めてください。これ以上進むとダメージを与えてしまいます。
    You don't need to do it like this, simply open the iMac bendidng the LCD completely and use the pizza cutter to remove the adhesive.
    Felix - 返信
    Using glass removal suction cups will avoid running this risk of damaging the camera (or any wiring).
    Ernst - 返信
  13. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 13、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 13、 2の画像 2
    • 接着剤が再装着するのを防ぐため、ディスプレイ上部右側コーナー付近にプラスチックカードを差し込んだままにします。
  14. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 14、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 14、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 14、 3の画像 3
    • 2枚目のプラスチックカードをiMac上部左側付近のディスプレイとフレームの隙間に差し込みます。
  15. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 15、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 15、 2の画像 2
    • ゆっくりとカードを上向きにツイストして、ディスプレイとフレームの間の隙間を広げます。
    • 反対側も同様に、接着剤が乖離するようにゆっくりとツイストします。ディスプレイのガラスに余分な圧力がかからないようご注意ください。
  16. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 16、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 16、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 16、 3の画像 3
    • プラスチックカードを中央に向けてゆっくりとスライドして、iSightカメラの手前で止めます。
  17. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 17、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 17、 2の画像 2
    • プラスチックカードを左側上部コーナーの裏側に差し込みます。
  18. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 18、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 18、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 18、 3の画像 3
    • コーナー付近に差し込んだ2枚のプラスチックカードを手に取り、ディスプレイとケースの間の隙間を広げるようにカードを外側に向けてツイストします。
    • もし接着剤が剥がれていない箇所がある場合はツイスト作業を止めて、どちらかのカードを使って接着剤を切断します。
    • フレームからディスプレイ上部を持ち上げます。
    • 約5cm程度以上は、ディスプレイを持ち上げないでください。ディスプレイデータケーブルやパワーケーブルが基板に接続されたままの状態です。
  19. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換, ディスプレイ: 手順 19、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換, ディスプレイ: 手順 19、 2の画像 2
    • ディスプレイを片手で持ちながら、もう一方の手を使ってディスプレイパワーケーブルの接続を外します。
    • コネクタに簡単にアクセスできる位置までディスプレイを持ち上げます。一方で、ケーブルを伸ばしてコネクタにストレスを与えてしまうほど高く持ち上げないでください。(約16cm程度)
    Pulling the display power cable by the wires makes me nervous..
    bstaud - 返信
    I had a small flight light ready so I could see. Follow the directions - don’t blindly pull.
    Noah Ralston - 返信
    Head lamp gives you the best hands free view!
    Macrepair SF - 返信
    bstaud - The display power cable has two squeezable levers on each end of the cable’s width.
    Squeeze the left lever with your thumb while you simultaneously squeeze the right lever with your
    index finger, and gently pull the cable straight back and out, and the cable comes out very easily.
    Ted Horodynsky - 返信
    When reassembling, make sure you get a “click” confirmation that both the levers have locked AND the pins have seated on this connector. I was treated to a black screen upon startup, and had to re-cut my newly installed adhesive strips to get back in to firm up this connection. Better would be power up with the bottom adhesive in place, screen resting in place and held on top with blue painter tape to confirm connections, THEN pull off screen-side adhesive tape covers for final re-bonding.
    Robert McKillip - 返信
    Can someone post a link to actually purchase these cables?
    Jay Hernandez - 返信
    E-bay had one for me
    Roger - 返信
  20. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 20、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 20、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 20、 3の画像 3
    • スパッジャーの先端を使って、ディスプレイのデータケーブル上のメタル製固定ブラケットを引き上げます。
    • ディスプレイのデータケーブルをロジックボード上のソケットから丁寧に引き抜きます。
    • ディスプレイデータケーブルのコネクタをソケットからまっすぐ引き抜いてください。
    Sure could use a magnified picture of this connector and socket, especially the first time you go in. And it is the most critical step of the whole operation — bung it up and we’re toast.
    bstaud - 返信
    Hi bstaud! If you hover over the image you can click on the magnifying glass and get a large image of any guide photo. Hope that helps!
    Sam Goldheart -
    To clarify, the connector pulls out in the plane of the logic card, not perpendicular.
    David Thompson - 返信
  21. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 21、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 21、 2の画像 2
    • ディスプレイを垂直に近い位置まで持ち上げます。
    • この時点でディスプレイの底に沿って接着剤のストリップが付いたままです。そのため、ディスプレイがフレームに対してヒンジのように開きます。数回にわたってディスプレイを上下に動かすとここに留められた接着剤が緩くなります。
    Where can I find a replacement display for my iMac?
    Braydon Boyce - 返信
    iFixit has listings for replacements. Go to the Parts section
    jerrid_foiles -
  22. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 22、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 22、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 22、 3の画像 3
    • 必要に応じて、プラスチックカードを使って底側の接着ストリップの一部を切断することもできます。
    • 下端ディスプレイの接着ストリップ片側の端にある小さなタブをつかみ、接着剤をiMacの上部に引き寄せて剥がします。
    • この手順をもう一方の接着ストリップにも同じ作業を繰り返して、取り除きます。
    • もし、どちらかの接着ストリップを外す前に切断してしまった場合は、プラスチックカードで残りの接着剤を除去してください。
    Cutting through this extra adhesive on the bottom took a bit more effort than the step and picture implied (to me). Unlike the other edges, here don't be afraid to really push the card in there to break the seal, there's nothing behind that adhesive that is breakable.
    phil - 返信
    cutting through the adhesive is unnecessary if it's not been opened before (outside of an apple store) there will be a tab at the end of each VHB strip that you can use to simply pull the vhb strips off.
    Rory McKenna - 返信
    YES, exactly the same here. more but more simple.
    Lucio Alves -
    To save a few steps and a bit of time, if you have a helper, they can hold the display at a 90° angle while you unscrew the brackets and remove/replace the hard drive rather than remove the display entirely. Also reduces the likelihood of damaging the display as you remove and handle it.
    marty - 返信
    The proper way to remove the display according to the Macintosh tech manual and videos is as Rory McKenna and Lucio Alves have learned is to pull the tab at the end of each VHB strip until it is off.
    Ben Varela - 返信
    This worked great! look for small left over adhesive on either edge of the bottom of the screen and pull each one towards the center. Screen assembly removes after that with no fuss.
    Miguel Rivas -
    Would Nitrile Gloves help here to avoid getting shocked?
    Thomas Z. - 返信
  23. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 23、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 23、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 23、 3の画像 3
    • フレームをディスプレイから持ち上げてiMac本体より取り出します。
    • 片一方をゆっくりと持ち上げて、接着ストリップを剥がしながら、片方も持ち上げてください。
    • ディスプレイを持ち上げる際は特にご注意くださいー大きくて、重く、ガラス製です。
    • 再組み立ての際は、新しい接着剤をインストールするためにディスプレイ用の接着剤ガイドを参照してください。
  24. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換, 下部サポートブラケット: 手順 24、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換, 下部サポートブラケット: 手順 24、 2の画像 2
    • 下部サポートブラケットを固定している次の5本のネジを外します。
    • 3.2 mmネジー4本
    • 1.7 mmネジー1本
    • あるEMC 2544モデルでは、上の5本のネジサイズが全て同じものがあります。
    • ネジにアクセスするために、iMac底側の端に沿って付けられたディスプレイ用接着剤を剥がさなければなりません。
    I used the CR-V 4.0 standard screwdriver head to help peel away the adhesive lining. My fingers were too big to grab it, and my fingernails too short to get the removal started. This 4 screw head worked perfectly.
    airshack - 返信
  25. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 25、 1の画像 1
    • iMac筐体から下部サポートブラケットを取り出します。
    Of all the parts of this entire procedure, replacing this one piece is the hardest part! The screws are tiny and they just don’t seem to want to grab the support piece. Also it seems to perform no function which is also annoying.
    John M - 返信
    I left mine out. LOL
    jerrid_foiles -
    Line up the screw holes and press on the bracket from the back to help the screws grab. If your fingers are too big, press with the flat side of your spudger. As long as there’s no gap between the bracket and the iMac’s frame, the screws should grab easily.
    Jeff Suovanen -
    I put it in at a slight angle lining up the right hand side holes, screwed in the two screws and gently pressed my finger behind it on the rest
    jmorphett5 - 返信
    If you only want to replace the HD and RAM, take a big shortcut and leave the logic board in, as well as all the parts needed to remove it (speaker, power supply etc). Once the display is removed, just take out the fan and the top two logic board screw. There is than sufficient space to gently remove and insert the two ram modules. HD can easily be replaced with an SSD by just removing the HD mounting brackets...
    diddl14 - 返信
    Voces mudaram de modelo iMac, desta foto para proxima, esse modelo desta foto nao tem slot nvme. O da proxima foto sim. Voces me fizeram comprar un nvme por engano...
    tgb4rr0s tege - 返信
  26. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換, ハードドライブブラケット: 手順 26、 1の画像 1
    • リア筐体にハードドライブブラケットを固定している次のネジを外します。
    • 左側ハードドライブブラケットから21 mm T10トルクスネジー2本
    • 9 mm T10トルクスネジー1本
    • 27 mm T10 トルクスネジー1本
    Pay attention to this photo and where the fan is. It is 180° from where the previous step shows it is oriented to you.
    Max Romano - 返信
  27. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 27、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 27、 2の画像 2
    • iMacから左右のハードドライブブラケットを外します。
  28. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換, 電源ユニット: 手順 28、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換, 電源ユニット: 手順 28、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換, 電源ユニット: 手順 28、 3の画像 3
    • 次の2~3の手順では、作業の手が露出したパワーサプライの表面周辺に近づきます。露出した半田付け部分やパワーサプライの表面に触らないでください。ロジックボードに繋がっているボードに取り付けられた多数の大容量コンデンサから高電圧ショックが発生する危険性があります。
    • スパッジャーの先端を使って、パワーボタンケーブルコネクタの両側を抑えて、丁寧にソケットから外します。
    I would advise that before removing the PSU unit and all other components from the bottom of the case that you remove the 5 screws at the bottom of the display which hold an insulation strip in place.
    The guide shows this piece removed, but does not tell you how to remove it.
    There will be 5, small J1000 screws. The middle one, which goes over Apple Logo is the shorter one of the 5, all others are the same length. Once this piece is gone removing the components is much easier, and chance of damage lessened.
    [deleted] - 返信
    Added to the guide. Thanks for the tip!
    Jeff Suovanen -
    No need to remove power board and logic board and all other components, just remove the fan and it is quite "easily" accessable to change the RAM. Just need to use the tools to remove the old RAM and carefully install the new RAM.
    I just did it without removing the logic or power board
    Oleksandr Trokhymchuk - 返信
    could you elaborate a little more, I would love to skip the rest of these steps. How did you accomplish this?
    ej P -
    Oleksandr Trokhymchuk,
    Thank you! You just saved me so much time! I wouldn’t call this “easy” but it saved me a lot of time and effort.
    Joshua Ericson -
    ej P: remove the fan assembly first. Then remove the connector that runs from the iSight camera to the logic board on the left.
    the RAM is located right near that cable. It’s tricky to remove but you can pop open the connectors with a black nylon stick and the RAM chip will pop up at 45 degrees. Make a mental note on which way you will need to install the new ram as it’s tough to see. For the Crucial memory I got it was label side facing away you (facing towards rear metal enclosure).
    the second chip has a plastic adhesive piece on it that you should probably attach to the new ram.
    remove both chips then install the new ram in sequence from the board out.
    Wizdom On Wheels - 返信
    In the photo for Step 28, the power button cable connector is placed around the power board screw hole on the top left of the power board.
    However, on the iMac I upgraded, the power button cable connector was “fed” through the power power screw hole on the top left of the power board. The cable was too short to run around and below the hole.
    Hence, I had to ensure the cable was “fed” through the hole during re-assembly and the screw carefully screwed back through the hole.
    I guess every iMac is assembly just a bit differently, just to make repairs that much more fun.
    Tim Telcik - 返信
    This is not correct and may have been assembled incorrectly during a previous repair.
    Charlie Nancarrow -
    Just replaced the hard drive and RAM with SSD and 16GB respectively and did NOT remove the power supply or logic board. Tricky is a word to describe putting the RAM in without removing the logic board. You work in the dark with little room to get your fingers in between the logic board and the back of the case. I put the first RAM chip in without a problem (the one next to the logic board), but the second to four tries and dropped it behind the logic board three times before finally getting it to position correctly. Just impossible to see and must work but feel. Still it was faster than removing all the components… though did remove the fan (needed cleaning anyway). All in all I can’t say enough about the help the guide was through the upgrade ! Thanks !
    Ray Burgard - 返信
    I found this connector to be very tight and was afraid of breaking it off. I just kept slowly working on it—it did eventually come out.
    I did try to sneak the RAM in without removing the logic board but my fingers were too big. I found it too difficult and just continued on with this guide.
    Mikkif - 返信
    I was not able to install the memory without removing all the components. My fingers are too big and I could barely get in that tight spot to swap out the memory. The hardest part about the power supply is that one connector under the chin next to the Apple logo. Once it is out, you are home free because it is so easy to plug it back in when you are putting it all back together again. Ridiculous that Apple did not put a simple access door behind those memory slots because they are on the backside of the Mac! They did an access door on the PowerBooks and it did not ruin the appearance. They could have designed a cool looking pop out door that only had a thin seam around it so it would still look good. Then you could remove the access door to upgrade the memory easily.
    Peter Hillman - 返信
    Does anyone know if this is the same situation as in the 2017 model? I just changed RAM in the 2017 version and also skipped taking out the logic board. I just bent a pair of tweezers and put some tape around the tips to make them less scratchy and used them to place the RAM modules into the slots. Worked supereasy and much much quicker than performing the complete tear down of the whole machine.
    Nils Witte - 返信
    This step is impossible!
    Cecily Walker - 返信
    @wizdomonwheels, I don’t see how I can get the RAM shield off of the logic board to access the RAM without removing the logic board. What am I missing?? I’m guessing that those of you that are suggesting this technique are working on older iMac models that don’t have the RAM shield.
    jiclark - 返信
    Yes, you are correct. It is likely the various steps are a bit different on each model. If I recall I was likely working on a 2015 or older system. If there’s a shield in the way, I can’t think of a way you could get around it without pulling the logic board.
    Wizdom On Wheels -
  29. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 29、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 29、 2の画像 2
    • スパッジャーの先端を使って、電源供給コントロールのケーブルコネクタの両側を押して、ソケットから丁寧に引き抜きます。
  30. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 30、 1の画像 1
    • リアエンクロージャーにパワーサプライを固定している7.2 mm T10トルクスネジを2本、外します。
    • iMacの新型モデルでは7.2 mm T8トルクスネジが使用されています。
    • 再組み立ての際は、ボード裏の電源ボタンワイヤを切断しないようにご注意ください。
    In my case, the left side corner of the PS was caught against the Lower Support Bracket, and I had to remove the LSB in order to get the PS freed and out.
    I think the author Walter Galan should put this in the main section of his instructions. I have TWO identical iMac 14,1 / i5 2.7GHz / 21 Inch Late 2013 / Order ME086LL/A. They both required removing the LSB. Thank you very much Walter Galan & others for your contributions.
    Ted Horodynsky - 返信
    Those screws were definitely not T10 but T9 on my unit
    Vincent Monteil - 返信
    Those screws were T8 on my unit.
    jag32mobile - 返信
    c'est du torx 08
    pascal cacou - 返信
  31. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 31、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 31、 2の画像 2
    • パワーサプライの作業をする際は、パワーサプライの裏側に付いている露出した半田付け部分やコンデンサに接触しないよう、特にご注意ください。ロジックボードの端のみを持って作業を続けてください。
    • パワーサプライを前側に倒します。
    When replacing the PSU (on the re-build) take care not to trap the power button cable behind it - I did...
    Dave Hallett - 返信
  32. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 32、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 32、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 32、 3の画像 3
    • パワーサプライをわずかに引き上げて、リアエンクロージャーから取り出します。
    • パワーサプライを反時計回りに回転させて、向かって右側を左側より約2㎝程度高く上げてください。
    Ted Horodynsky - 返信
  33. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 33、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 33、 2の画像 2
    • パワーサプライを右側にスライドさせて、リアエンクロージャーに留められたネジポストから外します。
  34. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 34、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 34、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 34、 3の画像 3
    • パワーサプライを前方に掲げて、リアエンクロージャーから取り外します。
    • この時点で、パワーサプライをiMacから完全に取り出さないでくださいーロジックボードにまだケーブルが繋がったままです。
  35. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 35、 2の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 35、 2の画像 2
    • パワーサプライの裏側についている露出した半田付け接合部分やコンデンサリードに触らないよう、特にご注意ください。
    • ロジックボード裏にあるDCパワーケーブルのコネクションにアクセスするには、パワーサプライを裏返します。
    • DCパワーケーブルコネクタの裏側にあるタブをつまんで、ロジックボード裏のソケットからまっすぐ引き抜きます。
    when pulled the cable, even slightly, the actual female piece that connects to the logic board came off. am i screwed?
    Racheal Major - 返信
    Repairing sockets that come off the logic board is possible, but very specialised work. Unless you have a magnifying lamp and the necessary desoldering and soldering skills, it will be difficult but not impossible.
    Charlie Nancarrow - 返信
    The tab is at the far end of the connector, so you’ll need to reach farther than you might think.
    lkollar - 返信
    When I pulled the disconnect, I pushed down on the disconnect, instead of pushing down on the tab on the disconnect and bent those pins… tried to straighten the bent pins and two of the pins broke off the logic board. Will I need a new logic board or can I purchase the pins…?
    Ray AA - 返信
    I could not disconnect this cable without fear of breaking something (as previous posters did). I found that I could skip this and the next step by wrapping the power supply in a couple layers of a small towel (to prevent shorting with any other metal surfaces), and laying the power supply on the aluminum face of the iMac near the Apple logo. This got it out of the way enough to do what I needed on the logic board (changing PRAM battery) after completing removal of the other items in this guide.
    Phil McInnis - 返信
  36. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 36、 3の画像 1 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 36、 3の画像 2 iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 36、 3の画像 3
    • 次の手順から複数の修理ガイドでは、iMacの向きを反対にすると作業がしやすくなります。
    • スパッジャーの平面側先端を使って、ACインレットケーブルコネクタの側面にあるクリップを内側に押します。
    • リリース用のクリップをスパッジャーで押しながら、ACインレットケーブルを摘んで、ソケットからコネクタをまっすぐ引き出します。
    I didn't disconnect the input cable to the power supply. Because I had the machine lying on its back throughout, I placed it on to the metal bit at the bottom of the machine instead (with a cloth to stop the metal getting scratched). The AC inlet cable was pretty tricky to get un-locked, and the PSU sat on the case fine. It didn't hinder anything else throughout the guide.
    Dave Hallett - 返信
    I thought from Dave’s comment that I could leave the power supply completely in place, but I was mistaken. In order to remove the hard drive assembly after you remove the center screw in it, you’ll need to at least unscrew it and the HD assembly will slip out. Like Dave said, you don’t need to unplug the AC or PSU, which I left hanging.
    Getting power supply to the logic board unplugged is also tricky without unscrewing the two bottom screws. They didn’t make this part easy.
    delacrj2 - 返信
    Kleiner Rechtschreibfehler - statt „denac“ muss es wohl „den iMac“ heißen
    Gonzalo - 返信
    Au ja. Du kannst so was selbst ausbessern. Einfach auf “Übersetzen" gehen und loslegen.
    VauWeh - 返信
    I would like to thanks Dave Hallett for his tip of not removing the AC inlet connector of the power supply. I simply wrapped the board in bubble wrap and taped to the iMac case, out of the way, thus giving access to the remaining disconnection procedures and preventing the board from scratching to the iMac case. It also made reassembly much simpler.
    Rob Hogan - 返信
    Yeah, that AC inlet plug was a nasty one to unplug, mainly because I was trying not to bump the solder joints on the PSU. After a few wiggles and pulls while manipulating the spudger tool to release the clip, it finally unplugged. Made it easier by removing the PSU completely so you don’t have to worry about it. Don’t worry, plugging it back in is a breeze!
    Peter Hillman - 返信
    With the right tool this plug comes out very easily. Forget about your tiny computer tools, go to the garage and grab a regular old needle nose pliers. Grab the clip and the plug at the same time. The plug will come right out.
    Carin Ann Loewen - 返信
    Carin Ann— The most helpful comment on this procedure. After reading what you wrote I maneuvered the board, grabbed the clip with my left hand (a little awkward because of the cooling enclosure), squeezed the front of the plug, and got it out.
    Glen Kohler - 返信
    +1 for needle nose pliers!
    Sam - 返信
  37. iMac Intel 21.5インチ EMC 2638 電源ユニットの交換: 手順 37、 1の画像 1
    • iMacからパワーサプライを取り出します。
    erreur: retirer "la carte d'alimentation" et non" le disque dur" !!!!!
    Moreau - 返信
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
13 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
4人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,783 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
コメント 1 件
Great guide. My question is this however, How does one test this PSU before they replace it? I can't seem to find a PSU pinout for this particular unit (661-7111)
Stephen De Tomasi - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 26
過去 30 日: 139
今までの合計 10,334
