メインコンテンツにスキップ
Xiaomi Poco F3 Loudspeaker Replacement
必要な工具と部品
  1. Xiaomi Poco F3 Loudspeaker Replacement, Heat the rear glass: 手順 1、 1の画像 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen and internal battery are both susceptible to heat damage.
  2. Xiaomi Poco F3 Loudspeaker Replacement, Insert an opening pick: 手順 2、 2の画像 1 Xiaomi Poco F3 Loudspeaker Replacement, Insert an opening pick: 手順 2、 2の画像 2
    • Secure a suction handle to the right edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Xiaomi Poco F3 Loudspeaker Replacement, Slice the adhesive: 手順 3、 2の画像 1 Xiaomi Poco F3 Loudspeaker Replacement, Slice the adhesive: 手順 3、 2の画像 2
    • Slide the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Xiaomi Poco F3 Loudspeaker Replacement: 手順 4、 3の画像 1 Xiaomi Poco F3 Loudspeaker Replacement: 手順 4、 3の画像 2 Xiaomi Poco F3 Loudspeaker Replacement: 手順 4、 3の画像 3
    • Insert a second opening pick at the top right corner.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
  5. Xiaomi Poco F3 Loudspeaker Replacement: 手順 5、 2の画像 1 Xiaomi Poco F3 Loudspeaker Replacement: 手順 5、 2の画像 2
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick in the bottom right corner.
    • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  6. Xiaomi Poco F3 Loudspeaker Replacement: 手順 6、 3の画像 1 Xiaomi Poco F3 Loudspeaker Replacement: 手順 6、 3の画像 2 Xiaomi Poco F3 Loudspeaker Replacement: 手順 6、 3の画像 3
    • Insert a fourth opening pick in the bottom left corner of your phone.
    • Slide the opening pick along the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. Xiaomi Poco F3 Loudspeaker Replacement: 手順 7、 2の画像 1 Xiaomi Poco F3 Loudspeaker Replacement: 手順 7、 2の画像 2
    • Insert a fifth opening pick underneath the top left corner.
    • Slide the opening pick along the top edge of the rear glass to slice the remaining adhesive.
  8. Xiaomi Poco F3 Loudspeaker Replacement, Remove the rear glass: 手順 8、 1の画像 1
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Xiaomi Poco F3 Loudspeaker Replacement, Unscrew the motherboard cover: 手順 9、 1の画像 1
    • Use a Phillips screwdriver to remove the eleven screws securing the motherboard cover:
    • Ten 3.4 mm-long screws
    • One 1.5 mm-long screw
  10. Xiaomi Poco F3 Loudspeaker Replacement, Lift up the motherboard cover: 手順 10、 2の画像 1 Xiaomi Poco F3 Loudspeaker Replacement, Lift up the motherboard cover: 手順 10、 2の画像 2
    • Insert the tip of an opening pick under the bottom left edge of the motherboard cover.
    • Use the opening pick to lift up the motherboard cover and release the plastic clips that hold the cover in its place.
    • Don't remove the motherboard cover all the way yet! It's still connected to the motherboard.
  11. Xiaomi Poco F3 Loudspeaker Replacement, Disconnect the motherboard cover: 手順 11、 2の画像 1 Xiaomi Poco F3 Loudspeaker Replacement, Disconnect the motherboard cover: 手順 11、 2の画像 2
    • Use your fingers to lift up the motherboard cover to access the connector on the motherboard.
    • Use a spudger to disconnect the motherboard cover by prying the connector straight up from its socket at the motherboard.
    • Remove the motherboard cover.
  12. Xiaomi Poco F3 Loudspeaker Replacement, Disconnect the battery: 手順 12、 2の画像 1 Xiaomi Poco F3 Loudspeaker Replacement, Disconnect the battery: 手順 12、 2の画像 2
    • The battery connector is covered by a graphite foil. Carefully fold it up or tape it to the top edge of the Poco F3 to access the battery connector.
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
  13. Xiaomi Poco F3 Loudspeaker Replacement, Remove the SIM card tray: 手順 13、 3の画像 1 Xiaomi Poco F3 Loudspeaker Replacement, Remove the SIM card tray: 手順 13、 3の画像 2 Xiaomi Poco F3 Loudspeaker Replacement, Remove the SIM card tray: 手順 13、 3の画像 3
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the left bottom edge of the Poco F3.
    • Press firmly to eject the tray.
    • Remove the SIM card tray from the phone.
  14. Xiaomi Poco F3 Loudspeaker Replacement, Unfasten the loudspeaker screws: 手順 14、 1の画像 1
    • Use a Phillips screwdriver to remove the seven 3.5 mm-long screws securing the loudspeaker.
  15. Xiaomi Poco F3 Loudspeaker Replacement, Disconnect the antenna cable: 手順 15、 2の画像 1 Xiaomi Poco F3 Loudspeaker Replacement, Disconnect the antenna cable: 手順 15、 2の画像 2
    • Use a spudger to pry up and disconnect the black antenna cable from the motherboard.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  16. Xiaomi Poco F3 Loudspeaker Replacement, Pry up the loudspeaker: 手順 16、 3の画像 1 Xiaomi Poco F3 Loudspeaker Replacement, Pry up the loudspeaker: 手順 16、 3の画像 2 Xiaomi Poco F3 Loudspeaker Replacement, Pry up the loudspeaker: 手順 16、 3の画像 3
    • Insert an opening pick between the frame and the top left of the loudspeaker.
    • Use the opening pick to pry up the loudspeaker by tilting it downwards.
  17. Xiaomi Poco F3 Loudspeaker Replacement, Remove the loudspeaker: 手順 17、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers or your fingers to remove the loudspeaker.
    • Compare your new replacement part to the original part—you may need to transfer remaining components like the antenna cable.
終わりに
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
作成者
1人の作成者と共同作成されました。
Adriana Zwink
メンバー登録日: 12/18/19
50,416 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
141 メンバー
17,895のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 28
過去 30 日: 128
今までの合計 1,820
