メインコンテンツにスキップ
Whirlpool Refrigerator Dispenser Assembly Replacement
必要な工具と部品
  1. Whirlpool Refrigerator Dispenser Assembly Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Dispenser Assembly Replacement, Unfasten the dispenser panels: 手順 2、 2の画像 1 Whirlpool Refrigerator Dispenser Assembly Replacement, Unfasten the dispenser panels: 手順 2、 2の画像 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the dispenser panels: 手順 3、 3の画像 1 Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the dispenser panels: 手順 3、 3の画像 2 Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the dispenser panels: 手順 3、 3の画像 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator Dispenser Assembly Replacement, Unfasten the control board: 手順 4、 1の画像 1
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator Dispenser Assembly Replacement: 手順 5、 3の画像 1 Whirlpool Refrigerator Dispenser Assembly Replacement: 手順 5、 3の画像 2 Whirlpool Refrigerator Dispenser Assembly Replacement: 手順 5、 3の画像 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the control board: 手順 6、 3の画像 1 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the control board: 手順 6、 3の画像 2 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the control board: 手順 6、 3の画像 3
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the control board: 手順 7、 1の画像 1
    • Remove the control board.
  8. Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the plastic clip: 手順 8、 3の画像 1 Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the plastic clip: 手順 8、 3の画像 2 Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the plastic clip: 手順 8、 3の画像 3
    • Use a flathead screwdriver, or a similar tool, to pry up the plastic clip securing the water hose.
    • Remove the plastic clip.
  9. Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the water hose: 手順 9、 3の画像 1 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the water hose: 手順 9、 3の画像 2 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the water hose: 手順 9、 3の画像 3
    • Use a flathead screwdriver, or a similar tool, to pry up the water hose enough to grip it with your fingers.
    • Pull the water hose straight up to disconnect it.
  10. Whirlpool Refrigerator Dispenser Assembly Replacement, Reposition the cables: 手順 10、 2の画像 1 Whirlpool Refrigerator Dispenser Assembly Replacement, Reposition the cables: 手順 10、 2の画像 2
    • Reposition the cables so they lay in front of the top plastic clip.
  11. Whirlpool Refrigerator Dispenser Assembly Replacement, Unclip the dispenser assembly: 手順 11、 3の画像 1 Whirlpool Refrigerator Dispenser Assembly Replacement, Unclip the dispenser assembly: 手順 11、 3の画像 2 Whirlpool Refrigerator Dispenser Assembly Replacement, Unclip the dispenser assembly: 手順 11、 3の画像 3
    • Depending on your device, the amount of plastic clips that secure the dispenser assembly can vary.
    • Use a flathead screwdriver, or a similar tool, to press the plastic clip toward the dispenser assembly.
    • Repeat for the other plastic clips to completely separate the dispenser assembly from the chassis.
  12. Whirlpool Refrigerator Dispenser Assembly Replacement, Reposition the dispenser assembly: 手順 12、 2の画像 1 Whirlpool Refrigerator Dispenser Assembly Replacement, Reposition the dispenser assembly: 手順 12、 2の画像 2
    • Pull the dispenser assembly away from the chassis enough to access its connectors.
  13. Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the dispenser assembly: 手順 13、 3の画像 1 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the dispenser assembly: 手順 13、 3の画像 2 Whirlpool Refrigerator Dispenser Assembly Replacement, Disconnect the dispenser assembly: 手順 13、 3の画像 3
    • While performing this step, support the dispenser assembly so it doesn't fall.
    • Disconnect the connector attached to the dispenser assembly.
  14. Whirlpool Refrigerator Dispenser Assembly Replacement, Remove the dispenser assembly: 手順 14、 1の画像 1
    • Remove the dispenser assembly.
  15. Whirlpool Refrigerator Dispenser Assembly Replacement, Meter the dispenser assembly: 手順 15、 2の画像 1 Whirlpool Refrigerator Dispenser Assembly Replacement, Meter the dispenser assembly: 手順 15、 2の画像 2
    • If you own a multimeter, you can test your solenoid's resistance.
    • With the button in its neutral position, the multimeter should read "open circuit" or "OL."
    • With the button pressed, the multimeter should read close to 0Ω.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
作成者
2人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,927 ポイント
89のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
45 メンバー
702のガイドは作成済み
2 件のコメント
The bottom side of refrigeration is not working but the top inversely working the cooling process
Dawit Muluneh - 返信
I'd take a look at one of two troubleshooting pages:
Freezer Not Freezing or Refrigerator Not Cooling
nicO -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 70
今までの合計 2,040
