メインコンテンツにスキップ
TicWatch E3 Motherboard Replacement
必要な工具と部品
  1. TicWatch E3 Motherboard Replacement, Power down your watch: 手順 1、 2の画像 1 TicWatch E3 Motherboard Replacement, Power down your watch: 手順 1、 2の画像 2
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. TicWatch E3 Motherboard Replacement, Loosen the adhesive: 手順 2、 1の画像 1
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. TicWatch E3 Motherboard Replacement, Insert an opening pick: 手順 3、 3の画像 1 TicWatch E3 Motherboard Replacement, Insert an opening pick: 手順 3、 3の画像 2 TicWatch E3 Motherboard Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Insert an opening pick into the recess between the watch frame and the top edge of the back cover.
    • Push the opening pick to create a gap between the back cover and the watch frame.
  4. TicWatch E3 Motherboard Replacement, Pry up the back cover assembly: 手順 4、 3の画像 1 TicWatch E3 Motherboard Replacement, Pry up the back cover assembly: 手順 4、 3の画像 2 TicWatch E3 Motherboard Replacement, Pry up the back cover assembly: 手順 4、 3の画像 3
    • Twist the opening pick to widen the gap between the back cover assembly and the watch frame.
    • Pry upward to loosen the back cover assembly.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the motherboard.
  5. TicWatch E3 Motherboard Replacement, Free the back cover assembly: 手順 5、 2の画像 1 TicWatch E3 Motherboard Replacement, Free the back cover assembly: 手順 5、 2の画像 2
    • Carefully lift up the bottom edge of the back cover assembly to make sure it isn't adhered to the watch frame anymore.
    • Avoid straining or tearing the sensor or battery cables.
  6. TicWatch E3 Motherboard Replacement, Open the watch: 手順 6、 2の画像 1 TicWatch E3 Motherboard Replacement, Open the watch: 手順 6、 2の画像 2
    • Grab the back cover assembly and carefully bring it into an upright position next to the watch housing.
  7. TicWatch E3 Motherboard Replacement, Disconnect the battery cable: 手順 7、 2の画像 1 TicWatch E3 Motherboard Replacement, Disconnect the battery cable: 手順 7、 2の画像 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  8. TicWatch E3 Motherboard Replacement, Disconnect the sensor cable: 手順 8、 2の画像 1 TicWatch E3 Motherboard Replacement, Disconnect the sensor cable: 手順 8、 2の画像 2
    • Use a spudger to disconnect the sensor cable by prying the connector straight up from its socket.
  9. TicWatch E3 Motherboard Replacement, Remove the back cover assembly: 手順 9、 2の画像 1 TicWatch E3 Motherboard Replacement, Remove the back cover assembly: 手順 9、 2の画像 2
    • Remove the back cover assembly.
  10. TicWatch E3 Motherboard Replacement, Disconnect the display cables: 手順 10、 2の画像 1 TicWatch E3 Motherboard Replacement, Disconnect the display cables: 手順 10、 2の画像 2
    • Use a spudger to disconnect the right display cable by prying the connector straight up from its socket.
  11. TicWatch E3 Motherboard Replacement: 手順 11、 2の画像 1 TicWatch E3 Motherboard Replacement: 手順 11、 2の画像 2
    • Use a spudger to disconnect the left display cable by prying the connector straight up from its socket.
  12. TicWatch E3 Motherboard Replacement, Free the display cable: 手順 12、 3の画像 1 TicWatch E3 Motherboard Replacement, Free the display cable: 手順 12、 3の画像 2 TicWatch E3 Motherboard Replacement, Free the display cable: 手順 12、 3の画像 3
    • Carefully slide an opening pick underneath the display cable to separate it from the motherboard.
    • Use your opening pick to fold the display cable in an upright position.
  13. TicWatch E3 Motherboard Replacement, Unfasten the motherboard screws: 手順 13、 1の画像 1
    • Use a Phillips screwdriver to remove the four 4.1 mm-long screws securing the motherboard.
  14. TicWatch E3 Motherboard Replacement, Pry up the motherboard: 手順 14、 2の画像 1 TicWatch E3 Motherboard Replacement, Pry up the motherboard: 手順 14、 2の画像 2
    • Insert a spudger underneath the edge of the motherboard opposite to the watch buttons.
    • Pry up to loosen the motherboard.
  15. TicWatch E3 Motherboard Replacement, Remove the motherboard: 手順 15、 2の画像 1 TicWatch E3 Motherboard Replacement, Remove the motherboard: 手順 15、 2の画像 2
    この手順で使用する道具:
    • Use a pair of tweezers to remove the motherboard.
終わりに
Compare your new replacement part to the original part—you may need to transfer remaining components like the watch buttons or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch E3 answers community for help.
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
246,799 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,629のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 398
