メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Texas Instruments TI-30 XS Multiview Solar Panel Replacement
必要な工具と部品
    1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: 手順 1、 2の画像 1 Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: 手順 1、 2の画像 2
      • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
      • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
      • Use the spudger (or fingernail) to pry into the space between the blue back cover and the white body to take off the back cover.
      FixBotに聞いてみる
      コメントを追加
    2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the battery compartiment: 手順 2、 1の画像 1
      • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
      • Lift the metal plate from the battery and set it to the side.
      FixBotに聞いてみる
      コメントを追加
    3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Eject the battery: 手順 3、 1の画像 1
      • Use the spudger (or fingernail) to lift the battery from the black holder.
      FixBotに聞いてみる
      コメントを追加
      • Put the new CR2032 battery in. Never insert a different type of battery!
      • Make sure the positive side of your CR2032 is facing up.
      • Reverse the steps 2 and 1.
      FixBotに聞いてみる
      コメントを追加
    1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Free the solar panel: 手順 5、 1の画像 1
      • Use the #00 Phillips screwdriver to remove the one 3mm Phillips screw holding the solar panel in place.
      FixBotに聞いてみる
      コメントを追加
    2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Carefully pull the panel out: 手順 6、 1の画像 1
      • Be careful not to pull the solar panel too far out, as the wires connecting it to the calculator are fragile and could be ripped off.
      • Carefully pull the solar panel away from the calculator, as shown to the left.
      FixBotに聞いてみる
      コメントを追加
    3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Unsolder the wires: 手順 7、 1の画像 1
      • The capacitor might not be discharged. Proceed with caution.
      • Unsolder the three wires from the motherboard.
      • Unsoldering help can be found here.
      • To re-solder the wires from the new solar panel to the calculator motherboard take notice of the color and placement of the wires.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
5人の作成者と共同で作成されました。
Aaron Feinstein
メンバー登録日: 10/01/15
401 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 11-2, Forte Fall 2015 Cal Poly, Team 11-2, Forte Fall 2015人のメンバー
CPSU-FORTE-F15S11G2
4 メンバー
15のガイドは作成済み
1件のガイドコメント
Do you know where I could get a replacement solar panel for the calculator?
Josh - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 44
今までの合計 3,071
