メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
SteelSeries Nimbus+ Controller Face Buttons Replacement
必要な工具と部品
    1. SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the phone mount: 手順 1、 2の画像 1 SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the phone mount: 手順 1、 2の画像 2
      • Use your fingers to remove the phone mount by pulling it straight out of the controller.
      FixBotに聞いてみる
      コメントを追加
    2. SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the sticker: 手順 2、 1の画像 1
      • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
      • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
      FixBotに聞いてみる
      コメントを追加
    3. SteelSeries Nimbus+ Controller Face Buttons Replacement, Unscrew the back cover: 手順 3、 1の画像 1
      • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
      FixBotに聞いてみる
      コメントを追加
    4. SteelSeries Nimbus+ Controller Face Buttons Replacement, Insert an opening pick: 手順 4、 2の画像 1 SteelSeries Nimbus+ Controller Face Buttons Replacement, Insert an opening pick: 手順 4、 2の画像 2
      • The back cover is held in place by plastic clips.
      • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
      FixBotに聞いてみる
      コメントを追加
    5. SteelSeries Nimbus+ Controller Face Buttons Replacement, Release the plastic clips: 手順 5、 2の画像 1 SteelSeries Nimbus+ Controller Face Buttons Replacement, Release the plastic clips: 手順 5、 2の画像 2
      • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
      FixBotに聞いてみる
      コメントを追加
    6. SteelSeries Nimbus+ Controller Face Buttons Replacement, Insert an opening pick: 手順 6、 2の画像 1 SteelSeries Nimbus+ Controller Face Buttons Replacement, Insert an opening pick: 手順 6、 2の画像 2
      • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
      FixBotに聞いてみる
      コメントを追加
    7. SteelSeries Nimbus+ Controller Face Buttons Replacement, Release the plastic clips: 手順 7、 2の画像 1 SteelSeries Nimbus+ Controller Face Buttons Replacement, Release the plastic clips: 手順 7、 2の画像 2
      • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
      FixBotに聞いてみる
      コメントを追加
    8. SteelSeries Nimbus+ Controller Face Buttons Replacement, Unfold the back cover assembly: 手順 8、 3の画像 1 SteelSeries Nimbus+ Controller Face Buttons Replacement, Unfold the back cover assembly: 手順 8、 3の画像 2 SteelSeries Nimbus+ Controller Face Buttons Replacement, Unfold the back cover assembly: 手順 8、 3の画像 3
      • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
      • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
      FixBotに聞いてみる
      コメントを追加
    9. SteelSeries Nimbus+ Controller Face Buttons Replacement, Disconnect the battery cable: 手順 9、 3の画像 1 SteelSeries Nimbus+ Controller Face Buttons Replacement, Disconnect the battery cable: 手順 9、 3の画像 2 SteelSeries Nimbus+ Controller Face Buttons Replacement, Disconnect the battery cable: 手順 9、 3の画像 3
      この手順で使用する道具:
      • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
      FixBotに聞いてみる
      コメントを追加
    10. SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the back cover assembly: 手順 10、 1の画像 1
      • Remove the back cover assembly.
      FixBotに聞いてみる
      コメントを追加
    1. SteelSeries Nimbus+ Controller Face Buttons Replacement, Unscrew the board: 手順 11、 1の画像 1
      • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
      FixBotに聞いてみる
      コメントを追加
    2. SteelSeries Nimbus+ Controller Face Buttons Replacement, Disconnect the thumbstick board: 手順 12、 3の画像 1 SteelSeries Nimbus+ Controller Face Buttons Replacement, Disconnect the thumbstick board: 手順 12、 3の画像 2 SteelSeries Nimbus+ Controller Face Buttons Replacement, Disconnect the thumbstick board: 手順 12、 3の画像 3
      • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
      FixBotに聞いてみる
      コメントを追加
    3. SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the board: 手順 13、 1の画像 1
      • Remove the board with the thumbsticks from the mainboard.
      FixBotに聞いてみる
      コメントを追加
    1. SteelSeries Nimbus+ Controller Face Buttons Replacement, Unscrew the mainboard: 手順 14、 1の画像 1
      • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
      FixBotに聞いてみる
      コメントを追加
    2. SteelSeries Nimbus+ Controller Face Buttons Replacement, Lift up the mainboard: 手順 15、 3の画像 1 SteelSeries Nimbus+ Controller Face Buttons Replacement, Lift up the mainboard: 手順 15、 3の画像 2 SteelSeries Nimbus+ Controller Face Buttons Replacement, Lift up the mainboard: 手順 15、 3の画像 3
      • Use your fingers to lift up the mainboard from the front case.
      • Remove the mainboard.
      FixBotに聞いてみる
      コメントを追加
    1. SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the face buttons: 手順 16、 3の画像 1 SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the face buttons: 手順 16、 3の画像 2 SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the face buttons: 手順 16、 3の画像 3
      この手順で使用する道具:
      • Use a pair of tweezers to remove the face buttons from the housing.
      • The alignment pegs on each button are designed to prevent incorrect installation. Make sure your new buttons fit properly in the controller case.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Adriana Zwink
メンバー登録日: 12/18/19
68,072 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
58,260のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 35
今までの合計 707
