はじめに
Use this guide to replace the USB-C port and daughterboard in your Samsung Galaxy Tab S7+ Wi-Fi.
Note: this guide is for the Wi-Fi version. For the 5G version, click here.
In order to replace the USB-C port and daughterboard, you must remove the screen. The screen has sensitive components, so there's a risk you'll damage it during the procedure. Be sure to apply plenty of heat and be extremely careful during the prying stage.
Before you begin, refer to the Samsung Self-Repair document for safety information.
For your safety, fully discharge the battery before disassembling your tablet. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Note: Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
必要な工具と部品
Apply a heated iOpener to the bottom edge of the device to loosen the adhesive underneath.
While you're waiting for the adhesive to loosen, note the following:
There's a long circuit board attached to the screen that sits parallel to the bottom edge.
This image shows an example of the display separating from the glass panel.
Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
Lift the screen with the suction handle to create a small gap between the screen and the frame.
Insert an opening pick into the gap between the frame and the screen.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a new opening pick into the gap you created.
Slide the new pick along the bottom edge of the device towards the bottom-right corner.
Apply a heated iOpener to the right edge of the device to loosen the adhesive underneath.
Rotate the opening pick around the bottom-right corner of the device.
Slide the new pick along the right edge of the device towards the top-right corner.
Apply a heated iOpener to the top edge of the device to loosen the adhesive underneath.
Rotate the opening pick around the top-right corner of the device.
Slide the new pick along the top edge of the device towards the top-left corner.
Apply a heated iOpener to the left edge of the device to loosen the adhesive underneath.
Rotate the opening pick around the top-left corner of the device.
Slide the new pick along the left edge of the device towards the bottom-left corner.
Rotate the opening pick around the bottom-left corner of the device.
この手順で使用する道具:Tweezers$4.99
With the top of the device facing you, pull the screen up and away from you like you're opening a book.
Rest the screen upside down and parallel to the frame before continuing.
This is a good point to power on your tablet and test all functions before sealing it up. Be sure to power your tablet back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
If you're using Samsung custom-cut adhesives, follow this guide. If you're using double-sided tape, follow this guide.
Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the screen.
Use a Phillips #00 screwdriver to remove the fifty 3 mm-long screws securing the frame bracket to the frame.
Bottom-left = 9 screws
Bottom-right = 14 screws
Top-right = 12 screws
Top-left = 15 screws
Lift the frame bracket away from the frame, making sure to thread the display cable through its socket.
Use the flat end of a spudger to pry up and disconnect the battery's press connector secured to the motherboard.
Use the flat end of a spudger to pry up and disconnect the daughterboard interconnect cable's press connector secured to the motherboard.
Use a Phillips #00 screwdriver to remove the two 2 mm screws securing the charging daughterboard to the frame.
Insert a spudger between the charging daughterboard and the frame.
Pry up with the spudger to release the clips securing the charging daughterboard.
Use your fingers to remove the charging daughterboard.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and follow the Samsung Self-Repair document (beginning page 9) to make sure your device is fully functional.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Tab S7+ Answers community for help.
3 の人々がこのガイドを完成させました。
