はじめに
Use this guide to replace the back cover on your Samsung Galaxy S21 Ultra.
Before you begin, refer to the Samsung Self-Repair document for safety information.
Note: Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
必要な工具と部品
Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
この手順で使用する道具:Tweezers$4.99
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using Samsung custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and follow the Samsung Self-Repair document (beginning page 9) to make sure your device is fully functional.
9 の人々がこのガイドを完成させました。
2 件のコメント
Why would the adhesive only provide water resistance but not ingress protection? Is it inferior to OEM?
Is replacing the glass over the cameras a similar process, or can that be done without removing the back plate?
