メインコンテンツにスキップ
Samsung Galaxy Note10 Plus 5G Rear Cover Replacement
必要な工具と部品
  1. Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Heat the rear cover: 手順 1、 1の画像 1
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Insert an opening pick: 手順 2、 3の画像 1 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Insert an opening pick: 手順 2、 3の画像 2 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Insert an opening pick: 手順 2、 3の画像 3
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Begin to slice the adhesive: 手順 3、 3の画像 1 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Begin to slice the adhesive: 手順 3、 3の画像 2 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Begin to slice the adhesive: 手順 3、 3の画像 3
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Slice around the perimeter of the phone: 手順 4、 3の画像 1 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Slice around the perimeter of the phone: 手順 4、 3の画像 2 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Slice around the perimeter of the phone: 手順 4、 3の画像 3
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    • The rear cover will begin to separate from the phone as you finish all sides of the phone.
  5. Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Lift off the rear cover: 手順 5、 2の画像 1 Samsung Galaxy Note10 Plus 5G Rear Cover Replacement, Lift off the rear cover: 手順 5、 2の画像 2
    • Lift the rear cover straight up to remove it.
    • Follow this guide to reinstall the rear cover and replace the adhesive.
    • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
    • If you're using Tesa tape to reattach components, follow this guide.
終わりに
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
2 の人々がこのガイドを完成させました。
Arthur Shi
メンバー登録日: 01/03/18
253,248 ポイント
526のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
17,137のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 49
今までの合計 2,211
