メインコンテンツにスキップ
Samsung Galaxy M51 Battery Replacement
必要な工具と部品
  1. Samsung Galaxy M51 Battery Replacement, How to remove the SIM Tray: 手順 1、 3の画像 1 Samsung Galaxy M51 Battery Replacement, How to remove the SIM Tray: 手順 1、 3の画像 2 Samsung Galaxy M51 Battery Replacement, How to remove the SIM Tray: 手順 1、 3の画像 3
    • Insert a SIM eject tool into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
  2. Samsung Galaxy M51 Battery Replacement, Heat an iOpener: 手順 2、 1の画像 1
    • Before beginning this procedure, completely power off your phone.
    • Prepare an iOpener and apply it to the back cover for at least two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Samsung Galaxy M51 Battery Replacement, Create an opening gap: 手順 3、 3の画像 1 Samsung Galaxy M51 Battery Replacement, Create an opening gap: 手順 3、 3の画像 2 Samsung Galaxy M51 Battery Replacement, Create an opening gap: 手順 3、 3の画像 3
    • Apply a suction handle to the back cover, as close to the USB-C port as possible.
    • Lift the back cover's bottom edge with your suction handle, opening a slight gap between the back cover and the frame.
    • Insert the tip of an opening pick in the gap you created.
    • Slide the opening pick to the bottom left corner and leave it there.
  4. Samsung Galaxy M51 Battery Replacement, Slice through the adhesive: 手順 4、 2の画像 1 Samsung Galaxy M51 Battery Replacement, Slice through the adhesive: 手順 4、 2の画像 2
    • Insert a second opening pick and slide it from the bottom left corner to the bottom right corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Samsung Galaxy M51 Battery Replacement: 手順 5、 2の画像 1 Samsung Galaxy M51 Battery Replacement: 手順 5、 2の画像 2
    • Insert a third opening pick under the bottom right corner of the back cover.
    • If you have any trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide it along the right edge of the phone to the top right corner to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Samsung Galaxy M51 Battery Replacement: 手順 6、 2の画像 1 Samsung Galaxy M51 Battery Replacement: 手順 6、 2の画像 2
    • Insert a fourth opening pick under the top right corner.
    • Slide it along the top edge to the left corner to cut the adhesive.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  7. Samsung Galaxy M51 Battery Replacement: 手順 7、 2の画像 1 Samsung Galaxy M51 Battery Replacement: 手順 7、 2の画像 2
    • Insert a fifth opening pick on the top left corner and slide it along the edge to cut the remaining adhesive.
  8. Samsung Galaxy M51 Battery Replacement, Remove the back cover: 手順 8、 1の画像 1
    • Remove the back cover.
  9. Samsung Galaxy M51 Battery Replacement, Disconnect the fingerprint sensor: 手順 9、 2の画像 1 Samsung Galaxy M51 Battery Replacement, Disconnect the fingerprint sensor: 手順 9、 2の画像 2
    • Use the pointy end of a spudger to disconnect the fingerprint sensor from the motherboard.
  10. Samsung Galaxy M51 Battery Replacement, Remove the screws: 手順 10、 1の画像 1
    • Remove the 15 4.0 mm-long Phillips #00 screws securing the midframe.
  11. Samsung Galaxy M51 Battery Replacement, Release the plastic clips: 手順 11、 3の画像 1 Samsung Galaxy M51 Battery Replacement, Release the plastic clips: 手順 11、 3の画像 2 Samsung Galaxy M51 Battery Replacement, Release the plastic clips: 手順 11、 3の画像 3
    • The midframe is held by plastic clips.
    • Insert an opening pick between midframe and display near the usb-c port.
    • Slide the opening pick to bottom right corner to release the plastic clips.
  12. Samsung Galaxy M51 Battery Replacement: 手順 12、 3の画像 1 Samsung Galaxy M51 Battery Replacement: 手順 12、 3の画像 2 Samsung Galaxy M51 Battery Replacement: 手順 12、 3の画像 3
    • Slide the opening pick along the right edge to release the plastic clips.
  13. Samsung Galaxy M51 Battery Replacement: 手順 13、 3の画像 1 Samsung Galaxy M51 Battery Replacement: 手順 13、 3の画像 2 Samsung Galaxy M51 Battery Replacement: 手順 13、 3の画像 3
    • Slide the opening pick along the top edge to release the midframe from the plastic clips.
  14. Samsung Galaxy M51 Battery Replacement: 手順 14、 3の画像 1 Samsung Galaxy M51 Battery Replacement: 手順 14、 3の画像 2 Samsung Galaxy M51 Battery Replacement: 手順 14、 3の画像 3
    • Slide the opening pick along the left edge to release the plastic clips.
  15. Samsung Galaxy M51 Battery Replacement, Remove the midframe: 手順 15、 1の画像 1
    • Remove the midframe.
  16. Samsung Galaxy M51 Battery Replacement, Battery Disconnect: 手順 16、 2の画像 1 Samsung Galaxy M51 Battery Replacement, Battery Disconnect: 手順 16、 2の画像 2
    • Use the flat end of a spudger to disconnect the battery.
  17. Samsung Galaxy M51 Battery Replacement, Disconnect the interconnect flex cable: 手順 17、 2の画像 1 Samsung Galaxy M51 Battery Replacement, Disconnect the interconnect flex cable: 手順 17、 2の画像 2
    • Use a flat end of a spudger to disconnect the interconnect flex cable from the motherboard.
  18. Samsung Galaxy M51 Battery Replacement: 手順 18、 2の画像 1 Samsung Galaxy M51 Battery Replacement: 手順 18、 2の画像 2
    • Use the flat end of a spudger to disconnect the interconnect cable from the daughterboard.
  19. Samsung Galaxy M51 Battery Replacement, Heat an iOpener: 手順 19、 1の画像 1
    • Apply an iOpener for 2-3 minutes to the screen to loosen the adhesive underneath. You might need to repeat this procedure several times during the battery replacement.
    • If you have trouble to remove the battery during this process you can apply high concentration (over 90%) isopropyl alcohol to the edges of the battery to loosen the adhesive.
  20. Samsung Galaxy M51 Battery Replacement, Slice the adhesive: 手順 20、 3の画像 1 Samsung Galaxy M51 Battery Replacement, Slice the adhesive: 手順 20、 3の画像 2 Samsung Galaxy M51 Battery Replacement, Slice the adhesive: 手順 20、 3の画像 3
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert a plastic card underneath the bottom edge of the battery.
    • Slice the plastic card through all the adhesive until you're able to pry it up.
  21. Samsung Galaxy M51 Battery Replacement, Remove the battery: 手順 21、 1の画像 1
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Before installing a new battery, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
終わりに
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Adriana Zwink
メンバー登録日: 12/18/19
48,729 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,410のガイドは作成済み
コメント 1 件
Excellent step by step instructions. I had to change the charging port as well. Adhesive sticker specifically for the Samsung Galaxy M51 can be bought online as well. I really enjoyed the process.
Bernard - 返信
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 46
過去 30 日: 212
今までの合計 7,827
