メインコンテンツにスキップ
Samsung Galaxy Book Pro 15" Screen Replacement
必要な工具と部品
  1. Samsung Galaxy Book Pro 15" Screen Replacement, Remove the rubber feet: 手順 1、 3の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement, Remove the rubber feet: 手順 1、 3の画像 2 Samsung Galaxy Book Pro 15" Screen Replacement, Remove the rubber feet: 手順 1、 3の画像 3
    • Before you begin, power down your laptop and unplug it.
    • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
    • Insert an opening pick between the rubber foot and the rear case.
    • Pry up with the opening pick to release the clips securing the foot.
    • Remove the foot.
    • Repeat this procedure for the three remaining feet.
    • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
  2. Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten the rear case: 手順 2、 2の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten the rear case: 手順 2、 2の画像 2
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the rear case.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3313.
  3. Samsung Galaxy Book Pro 15" Screen Replacement, Insert an opening pick: 手順 3、 3の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement, Insert an opening pick: 手順 3、 3の画像 2 Samsung Galaxy Book Pro 15" Screen Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Apply a suction cup to the rear case, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear case and the frame.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy Book Pro 15" Screen Replacement, Release the clips: 手順 4、 3の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement, Release the clips: 手順 4、 3の画像 2 Samsung Galaxy Book Pro 15" Screen Replacement, Release the clips: 手順 4、 3の画像 3
    • Slide the pick along the bottom edge of the rear case to release its plastic clips.
    • Repeat this process for the left and right edges, but stop before reaching the top edge.
  5. Samsung Galaxy Book Pro 15" Screen Replacement, Remove the rear case: 手順 5、 3の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement, Remove the rear case: 手順 5、 3の画像 2 Samsung Galaxy Book Pro 15" Screen Replacement, Remove the rear case: 手順 5、 3の画像 3
    • The top edge of the rear case is lightly adhered to the frame.
    • Pull the top of the rear case away from the frame to separate the adhesive and release the remaining clips.
    • If you're having trouble separating the adhesive, use an iOpener, hair dryer, or heat gun to soften it.
    • Remove the rear case.
    • During reassembly, perform the following:
    • If you're using a using a genuine Samsung replacement rear case, be sure to peel off any adhesive liners from the rear case before securing the top edge's clips.
    • If you're reusing your rear case, you can use some pre-cut adhesive to re-adhere the top edge if your existing adhesive is no longer sticky.
    • This is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down completely before you continue working.
  6. Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the battery: 手順 6、 2の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the battery: 手順 6、 2の画像 2
    • Insert a spudger between the frame and the bottom of the battery cable connector.
    • Pry up and disconnect the battery cable connector.
  7. Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the display: 手順 7、 2の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the display: 手順 7、 2の画像 2
  8. Samsung Galaxy Book Pro 15" Screen Replacement: 手順 8、 2の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement: 手順 8、 2の画像 2
    • Disconnect the display cable by sliding it out from its socket on the motherboard.
  9. Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the antenna: 手順 9、 3の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the antenna: 手順 9、 3の画像 2 Samsung Galaxy Book Pro 15" Screen Replacement, Disconnect the antenna: 手順 9、 3の画像 3
    • Use the tip of a spudger to pry up and disconnect the two WLAN antenna cables.
    • Pry under the bottom of the cable's metal head and not the cable itself.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  10. Samsung Galaxy Book Pro 15" Screen Replacement, Unclip the antenna cables: 手順 10、 3の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement, Unclip the antenna cables: 手順 10、 3の画像 2 Samsung Galaxy Book Pro 15" Screen Replacement, Unclip the antenna cables: 手順 10、 3の画像 3
    • Use a spudger to pry up and unclip the antenna cables from their clips on the daughterboard.
  11. Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten some of the hinge screws: 手順 11、 2の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten some of the hinge screws: 手順 11、 2の画像 2
    • Use a Phillips screwdriver to remove one 4.5 mm-long screw securing each screen hinge (two screws total).
    • Each hinge has a second screw, which you should leave in place for now.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #1650.
  12. Samsung Galaxy Book Pro 15" Screen Replacement: 手順 12、 1の画像 1
    • Fully open the screen and stand your laptop up on one side.
  13. Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten the remaining screws: 手順 13、 3の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten the remaining screws: 手順 13、 3の画像 2 Samsung Galaxy Book Pro 15" Screen Replacement, Unfasten the remaining screws: 手順 13、 3の画像 3
    • Use a Phillips screwdriver to remove the two remaining 4.5 mm screws (one from each hinge).
    • Remove the topmost screw last, using one hand to steady both halves of the laptop to make sure they don't separate and fall over unexpectedly.
  14. Samsung Galaxy Book Pro 15" Screen Replacement, Remove the screen: 手順 14、 3の画像 1 Samsung Galaxy Book Pro 15" Screen Replacement, Remove the screen: 手順 14、 3の画像 2 Samsung Galaxy Book Pro 15" Screen Replacement, Remove the screen: 手順 14、 3の画像 3
    • Keep a firm grip on both the screen and frame of the laptop. Either half can fall unexpectedly during this step.
    • Push both halves of the laptop together so that the hinges can be lifted clear of their recesses in the frame.
    • Push the frame of the laptop away from you while pulling the screen toward you to separate it.
  15. Samsung Galaxy Book Pro 15" Screen Replacement: 手順 15、 1の画像 1
    • Remove the screen.
    • During reassembly, first install the hinge screws without tightening them fully. Then adjust the screen until it's correctly centered and aligned on each side. Finally, tighten the screws.
終わりに
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
124,540 ポイント
581のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,298のガイドは作成済み
コメント 1 件
Will this screen work on the galaxy book 2 pro? Are they the same screens?
saad abdullah - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 77
過去 30 日: 270
今までの合計 4,546
