メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Razer Blade 15" (2018) RAM Replacement
必要な工具と部品
  1. Razer Blade 15" (2018) RAM Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 1 Razer Blade 15" (2018) RAM Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
    FixBotに聞いてみる
    コメントを追加
  2. Razer Blade 15" (2018) RAM Replacement, Unfasten the back cover: 手順 2、 1の画像 1
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
    FixBotに聞いてみる
    コメントを追加
  3. Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: 手順 3、 3の画像 1 Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: 手順 3、 3の画像 2 Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
    FixBotに聞いてみる
    コメントを追加
  4. Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: 手順 4、 3の画像 1 Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: 手順 4、 3の画像 2 Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: 手順 4、 3の画像 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
    FixBotに聞いてみる
    コメントを追加
  5. Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: 手順 5、 3の画像 1 Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: 手順 5、 3の画像 2 Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: 手順 5、 3の画像 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
    FixBotに聞いてみる
    コメントを追加
  6. Razer Blade 15" (2018) RAM Replacement, Free the front edge: 手順 6、 3の画像 1 Razer Blade 15" (2018) RAM Replacement, Free the front edge: 手順 6、 3の画像 2 Razer Blade 15" (2018) RAM Replacement, Free the front edge: 手順 6、 3の画像 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
    FixBotに聞いてみる
    コメントを追加
  7. Razer Blade 15" (2018) RAM Replacement, Remove the back cover: 手順 7、 3の画像 1 Razer Blade 15" (2018) RAM Replacement, Remove the back cover: 手順 7、 3の画像 2 Razer Blade 15" (2018) RAM Replacement, Remove the back cover: 手順 7、 3の画像 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
    FixBotに聞いてみる
    コメントを追加
  8. Razer Blade 15" (2018) RAM Replacement, Soften the battery cable tape adhesive: 手順 8、 2の画像 1 Razer Blade 15" (2018) RAM Replacement, Soften the battery cable tape adhesive: 手順 8、 2の画像 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
    FixBotに聞いてみる
    コメントを追加
  9. Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: 手順 9、 3の画像 1 Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: 手順 9、 3の画像 2 Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
    FixBotに聞いてみる
    コメントを追加
  10. Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: 手順 10、 3の画像 1 Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: 手順 10、 3の画像 2 Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: 手順 10、 3の画像 3
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
    FixBotに聞いてみる
    コメントを追加
  11. Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: 手順 11、 3の画像 1 Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: 手順 11、 3の画像 2 Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: 手順 11、 3の画像 3
    • Two metal arms secure the left and right edges of each RAM stick.
    • Push the lower RAM stick's metal arms outward to disengage them.
    • Remove the RAM stick.
    • During reassembly, insert the RAM stick at a 30-degree angle, then push straight down to engage the metal arms.
    FixBotに聞いてみる
    コメントを追加
  12. Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: 手順 12、 3の画像 1 Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: 手順 12、 3の画像 2 Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: 手順 12、 3の画像 3
    • Disengage the upper RAM stick's arms and remove the RAM.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
Clay Eickemeyer
メンバー登録日: 09/19/22
105,388 ポイント
472のガイドは作成済み
チーム
Guide Team Guide Team人のメンバー
Staff
10 メンバー
19,790のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 45
今までの合計 672
