メインコンテンツにスキップ
Razer Blade 15" (2018) Hard Drive Replacement
必要な工具と部品
  1. Razer Blade 15" (2018) Hard Drive Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2018) Hard Drive Replacement, Unfasten the back cover: 手順 2、 1の画像 1
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2018) Hard Drive Replacement, Insert an opening pick: 手順 3、 3の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Insert an opening pick: 手順 3、 3の画像 2 Razer Blade 15" (2018) Hard Drive Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2018) Hard Drive Replacement, Angle the opening pick: 手順 4、 3の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Angle the opening pick: 手順 4、 3の画像 2 Razer Blade 15" (2018) Hard Drive Replacement, Angle the opening pick: 手順 4、 3の画像 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2018) Hard Drive Replacement, Free the bottom right corner: 手順 5、 3の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Free the bottom right corner: 手順 5、 3の画像 2 Razer Blade 15" (2018) Hard Drive Replacement, Free the bottom right corner: 手順 5、 3の画像 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2018) Hard Drive Replacement, Free the front edge: 手順 6、 3の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Free the front edge: 手順 6、 3の画像 2 Razer Blade 15" (2018) Hard Drive Replacement, Free the front edge: 手順 6、 3の画像 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2018) Hard Drive Replacement, Remove the back cover: 手順 7、 3の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Remove the back cover: 手順 7、 3の画像 2 Razer Blade 15" (2018) Hard Drive Replacement, Remove the back cover: 手順 7、 3の画像 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2018) Hard Drive Replacement, Soften the battery cable tape adhesive: 手順 8、 2の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Soften the battery cable tape adhesive: 手順 8、 2の画像 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2018) Hard Drive Replacement, Peel up the battery cable tape: 手順 9、 3の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Peel up the battery cable tape: 手順 9、 3の画像 2 Razer Blade 15" (2018) Hard Drive Replacement, Peel up the battery cable tape: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2018) Hard Drive Replacement, Disconnect the battery: 手順 10、 3の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Disconnect the battery: 手順 10、 3の画像 2 Razer Blade 15" (2018) Hard Drive Replacement, Disconnect the battery: 手順 10、 3の画像 3
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
  11. Razer Blade 15" (2018) Hard Drive Replacement, Disconnect the hard drive: 手順 11、 2の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Disconnect the hard drive: 手順 11、 2の画像 2
    • Grab the pull tab on the hard drive press connector, just below the right fan.
    • Pull up and disconnect the connector from its socket.
    • During reassembly, align the press connector over its socket and press down until it clicks into place. If it doesn't connect, re-align it and try again.
    Que referencia es el cable conector de el disco duro
    Diego Agredo - 返信
  12. Razer Blade 15" (2018) Hard Drive Replacement, Unfasten the hard drive mounts: 手順 12、 2の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Unfasten the hard drive mounts: 手順 12、 2の画像 2
    • Use your Phillips screwdriver to remove the four screws securing the hard drive mounts:
    • Three 3.2 mm screws
    • One 5.2 mm screw
  13. Razer Blade 15" (2018) Hard Drive Replacement, Remove the hard drive: 手順 13、 2の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Remove the hard drive: 手順 13、 2の画像 2
    • Lift the hard drive straight up to remove it.
  14. Razer Blade 15" (2018) Hard Drive Replacement, Hard Drive: 手順 14、 1の画像 1
    • Flip the hard drive over.
  15. Razer Blade 15" (2018) Hard Drive Replacement, Unfasten the mounts: 手順 15、 2の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Unfasten the mounts: 手順 15、 2の画像 2
    • Use your Phillips screwdriver to remove the four 3.9 mm screws securing the two mounts to the hard drive.
  16. Razer Blade 15" (2018) Hard Drive Replacement, Remove the mounts: 手順 16、 3の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Remove the mounts: 手順 16、 3の画像 2 Razer Blade 15" (2018) Hard Drive Replacement, Remove the mounts: 手順 16、 3の画像 3
    • Remove both mounts from the hard drive.
  17. Razer Blade 15" (2018) Hard Drive Replacement, Remove the cable: 手順 17、 2の画像 1 Razer Blade 15" (2018) Hard Drive Replacement, Remove the cable: 手順 17、 2の画像 2
    • Remove the SATA cable adapter from the hard drive.
終わりに
Clay Eickemeyer
メンバー登録日: 09/19/22
82,165 ポイント
455のガイドは作成済み
チーム
Guide Team Guide Team人のメンバー
Staff
9 メンバー
11,483のガイドは作成済み
2 Guide Comments
Would you mind to spill the name/part number of the flex SATA cable for the HDD/SSD? For my flex SATA is gone and it's hard to find the replacement for my Razer Blade Base 2018, Thanks for advance
Isai Isai - 返信
Is it a SATA or NVMe slot? I want to install a 2.5" NVMe SSD.
Jerry Li - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 24
今までの合計 918
