メインコンテンツにスキップ
Razer Blade 15 Advanced Model (Early 2020) Battery Replacement
必要な工具と部品
  1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 1 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Unfasten the back cover: 手順 2、 2の画像 1 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Unfasten the back cover: 手順 2、 2の画像 2
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  3. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Insert an opening pick: 手順 3、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Insert an opening pick: 手順 3、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Angle the opening pick: 手順 4、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Angle the opening pick: 手順 4、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Angle the opening pick: 手順 4、 3の画像 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Free the bottom right corner: 手順 5、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Free the bottom right corner: 手順 5、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Free the bottom right corner: 手順 5、 3の画像 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Free the front edge: 手順 6、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Free the front edge: 手順 6、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Free the front edge: 手順 6、 3の画像 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  7. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the back cover: 手順 7、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the back cover: 手順 7、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the back cover: 手順 7、 3の画像 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
  8. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Disconnect the battery: 手順 8、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Disconnect the battery: 手順 8、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Disconnect the battery: 手順 8、 3の画像 3
    • Insert the point of a spudger under the middle of the battery connector's long edge.
    • Lift and disconnect the battery press connector from its socket on the motherboard.
    • This will require some force. Don't pry against any resistors or chips.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  9. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Unfasten the battery: 手順 9、 2の画像 1 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Unfasten the battery: 手順 9、 2の画像 2
    この手順で使用する道具:
    • Use a Phillips screwdriver to remove the five 4.6 mm‑long screws securing the battery.
    • Some battery screws may have stickers on them. Pierce through them with your screwdriver or use tweezers to remove them.
  10. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the stretch‑release adhesive: 手順 10、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the stretch‑release adhesive: 手順 10、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the stretch‑release adhesive: 手順 10、 3の画像 3
    • Be very careful not to puncture or bend the battery with your tool—it can leak dangerous chemicals and/or catch fire.
    • An adhesive strip under the battery's top left corner secures it to the frame.
    • Use tweezers to carefully peel up the stretch‑release adhesive's pull tab near the top left corner of the battery, enough that you can grip it with your fingers.
    • Use your fingers to slowly pull the strip out slowly and at a low angle to the frame. Give the adhesive plenty of time to stretch and un‑stick.
    • If the strip breaks, don't worry! Skip to the next step for an alternate way to separate the adhesive.
  11. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Separate the adhesive: 手順 11、 2の画像 1 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Separate the adhesive: 手順 11、 2の画像 2
    • If you successfully remove the stretch‑release adhesive, skip to the next step.
    • Insert an opening pick between the frame and the bottom left edge of the battery.
    • Slowly pry the battery up until the adhesive separates.
    • Don't apply significant force. All that's needed is constant pressure.
    • Leave the pick inserted between the battery and frame to prevent the battery from readhering.
  12. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the battery: 手順 12、 3の画像 1 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the battery: 手順 12、 3の画像 2 Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the battery: 手順 12、 3の画像 3
    この手順で使用する道具:
    Tesa 61395 Tape
    $2.99
    • Grab the middle of the battery and lift the left edge.
    • Slide the battery's right edge out from its recess in the frame and remove the battery.
    • During reassembly, if your battery comes with a strip of adhesive pre‑installed under the top left corner, remove the plastic liner. If it doesn't, apply a strip of thin, double‑sided tape to the frame where the old strip of adhesive was.
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
9 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Spencer Day
メンバー登録日: 09/14/22
150,064 ポイント
995のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,648のガイドは作成済み
2件のガイドコメント
Hi, the battery from ifixit is just slightly too wide by the vertical edge, i think due to the protrustions that hold the battery to the laptop. is there a fix for this?
Calvin Leung - 返信
Hi, Just a quick point- I got it to work but the battery ribbon cable is slightly too high for the connector once inside. i had to squeeze it in and it works.
G Murphy - 返信
コメントを追加
統計データ:
過去 24時間: 20
過去 7 日: 72
過去 30 日: 327
今までの合計 12,373
