はじめに
Use this guide to replace a dead, worn-out, or malfunctioning battery in your Razer Blade 15 Advanced Model (Early 2020) laptop.
If your battery is swollen, take appropriate precautions.
必要な工具と部品
Unplug all cables, fully shut down your laptop, and close the lid.
Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
Pull up on the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap.
Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
Remove the back cover.
Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
Insert the point of a spudger under the middle of the battery connector's long edge.
Lift and disconnect the battery press connector from its socket on the motherboard.
この手順で使用する道具:Tweezers$4.99
Use a Phillips screwdriver to remove the six 4.6 mm‑long screws securing the battery.
An adhesive pad under the battery's top left corner secures it to the frame.
Insert an opening pick between the frame and the bottom left edge of the battery.
Slowly pry the battery up until the adhesive separates.
Leave the pick inserted between the battery and frame to prevent the battery from readhering.
Grab the middle of the battery and lift the left edge.
Slide the battery's right edge out from its recess in the frame and remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
4 の人々がこのガイドを完成させました。
