はじめに
If the speaker of your Petcube Play 2 (identified by model number PP2OUS) is malfunctioning, use this guide to replace it.
A defective speaker might lead to distorted sound output or no output at all.
Before using this guide, ensure that there are no connection issues between the Petcube, your Wi-Fi router, and your phone. The Troubleshooting Page covers connection related issues and how to address them.
In step 4 of this guide, you will need to remove the soldering from wires to detach the speaker. Be sure to carefully follow the IFixit soldering instructions to avoid burning yourself or damaging the device. Ensure the Petcube Play 2 is turned off before beginning the replacement process.
必要な工具と部品
Flip over the Petcube so the rubber bottom faces you.
Use an iFixit opening pick to pull up the rubber layer and expose the screws underneath.
Take the half of the device that doesn't contain the motherboard and place it down so that the top screws are visible.
Use a Phillips #1 screwdriver to remove the seven screws.
Use a Phillips #1 screwdriver to remove the two screws securing the speaker.
Use a soldering iron to desolder the wires connecting the speaker to the device.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
