はじめに
If the microphone of your Petcube Play 2 (identified by model number PP2OUS) is malfunctioning, use this guide to replace it.
The Petcube Play 2 comes with a built-in microphone that relays your pet's sounds to you while using the Petcube App. Repeated use or a defective microphone might lead to improper sound output or no output at all.
Before using this guide, ensure that there are no connection issues between the Petcube, your Wi-Fi router, and your phone. The Troubleshooting Page covers connection related issues and how to address them.
In step 11 of this guide, you will need to remove the solder holding the microphones to the board. Be sure to carefully follow the IFixit soldering instructions to avoid burning yourself or damaging the device. Ensure the Petcube Play 2 is turned off before beginning the replacement process.
必要な工具と部品
Flip over the Petcube so the rubber bottom faces you.
Use an iFixit opening pick to pull up the rubber layer and expose the screws underneath.
The next step is to remove the front plates from each other. This is located behind the motherboard and is shown in the pictures.
To do this, you will need to remove the screws using a #1 Phillips head screwdriver.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
ある他の人がこのガイドを完成しました。
