メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Opening Procedure
必要な工具と部品
    1. Opening Procedure, Power down your watch: 手順 1、 2の画像 1 Opening Procedure, Power down your watch: 手順 1、 2の画像 2
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the watch band.
      FixBotに聞いてみる
      コメントを追加
    2. Opening Procedure, Loosen the adhesive: 手順 2、 1の画像 1
      • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      FixBotに聞いてみる
      コメントを追加
    3. Opening Procedure, Insert an opening pick: 手順 3、 3の画像 1 Opening Procedure, Insert an opening pick: 手順 3、 3の画像 2 Opening Procedure, Insert an opening pick: 手順 3、 3の画像 3
      • Insert an opening pick into the recess between the watch frame and the top edge of the back cover.
      • Push the opening pick to create a gap between the back cover and the watch frame.
      FixBotに聞いてみる
      コメントを追加
    4. Opening Procedure, Pry up the back cover assembly: 手順 4、 3の画像 1 Opening Procedure, Pry up the back cover assembly: 手順 4、 3の画像 2 Opening Procedure, Pry up the back cover assembly: 手順 4、 3の画像 3
      • Twist the opening pick to widen the gap between the back cover assembly and the watch frame.
      • Pry upward to loosen the back cover assembly.
      • Don't try to remove the back cover assembly all the way yet. It's still connected to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    5. Opening Procedure, Free the back cover assembly: 手順 5、 2の画像 1 Opening Procedure, Free the back cover assembly: 手順 5、 2の画像 2
      • Carefully lift up the bottom edge of the back cover assembly to make sure it isn't adhered to the watch frame anymore.
      • Avoid straining or tearing the sensor or battery cables.
      FixBotに聞いてみる
      コメントを追加
    6. Opening Procedure, Open the watch: 手順 6、 2の画像 1 Opening Procedure, Open the watch: 手順 6、 2の画像 2
      • Grab the back cover assembly and carefully bring it into an upright position next to the watch housing.
      FixBotに聞いてみる
      コメントを追加
    7. Opening Procedure, Disconnect the battery cable: 手順 7、 2の画像 1 Opening Procedure, Disconnect the battery cable: 手順 7、 2の画像 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      FixBotに聞いてみる
      コメントを追加
    8. Opening Procedure, Disconnect the sensor cable: 手順 8、 2の画像 1 Opening Procedure, Disconnect the sensor cable: 手順 8、 2の画像 2
      • Use a spudger to disconnect the sensor cable by prying the connector straight up from its socket.
      FixBotに聞いてみる
      コメントを追加
    9. Opening Procedure, Remove the back cover assembly: 手順 9、 2の画像 1 Opening Procedure, Remove the back cover assembly: 手順 9、 2の画像 2
      • Remove the back cover assembly.
      FixBotに聞いてみる
      コメントを追加
終わりに
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch E3 answers community for help.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
262,273 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
40,886のガイドは作成済み
1件のガイドコメント
I appreciate the details and sequence of photos. I hope I won't need this guide, but it's comforting to know you put this together!
BruceG - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 32
今までの合計 755
