メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
OnePlus 7T Screen Replacement
必要な工具と部品
    1. OnePlus 7T Screen Replacement, Heat the rear glass: 手順 1、 1の画像 1
      • Be sure to power off your phone before you begin.
      • Apply a heated iOpener to the rear glass for two minutes to loosen the adhesive beneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
      FixBotに聞いてみる
      コメントを追加
    2. OnePlus 7T Screen Replacement, Insert an opening pick: 手順 2、 3の画像 1 OnePlus 7T Screen Replacement, Insert an opening pick: 手順 2、 3の画像 2 OnePlus 7T Screen Replacement, Insert an opening pick: 手順 2、 3の画像 3
      • Apply a suction handle to the right edge of the rear glass.
      • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Pull on the suction handle to create a gap between the rear glass and the frame.
      • Insert an opening pick into the gap.
      FixBotに聞いてみる
      コメントを追加
    3. OnePlus 7T Screen Replacement, Slice the adhesive: 手順 3、 3の画像 1 OnePlus 7T Screen Replacement, Slice the adhesive: 手順 3、 3の画像 2 OnePlus 7T Screen Replacement, Slice the adhesive: 手順 3、 3の画像 3
      • Slide the opening pick along the edge to the bottom right corner.
      • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
      • Once you have inserted an opening pick, feel free to remove the suction handle or continue to use it for a better grip during this process.
      FixBotに聞いてみる
      コメントを追加
    4. OnePlus 7T Screen Replacement: 手順 4、 3の画像 1 OnePlus 7T Screen Replacement: 手順 4、 3の画像 2 OnePlus 7T Screen Replacement: 手順 4、 3の画像 3
      • Insert a second opening pick in the gap you just created.
      • Slide the opening pick along the edge to the top right corner.
      • If you have trouble with slicing, you can use the iOpener again to soften the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      FixBotに聞いてみる
      コメントを追加
    5. OnePlus 7T Screen Replacement: 手順 5、 3の画像 1 OnePlus 7T Screen Replacement: 手順 5、 3の画像 2 OnePlus 7T Screen Replacement: 手順 5、 3の画像 3
      • When you slice near the camera assembly, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
      • Insert a third opening pick under the top right corner of the rear glass.
      • Slide the opening pick along the edge of the phone to the top left corner to cut the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      FixBotに聞いてみる
      コメントを追加
    6. OnePlus 7T Screen Replacement: 手順 6、 3の画像 1 OnePlus 7T Screen Replacement: 手順 6、 3の画像 2 OnePlus 7T Screen Replacement: 手順 6、 3の画像 3
      • Insert a fourth opening pick under the top left corner.
      • Slide the opening pick along the edge to the bottom left corner to cut the adhesive.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      FixBotに聞いてみる
      コメントを追加
    7. OnePlus 7T Screen Replacement: 手順 7、 2の画像 1 OnePlus 7T Screen Replacement: 手順 7、 2の画像 2
      • Insert a fifth opening pick under the bottom left corner.
      • Slide it along the the edge to the bottom right corner to cut the remaining adhesive.
      FixBotに聞いてみる
      コメントを追加
    8. OnePlus 7T Screen Replacement, Remove the rear glass: 手順 8、 1の画像 1
      • Remove the rear glass.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      FixBotに聞いてみる
      コメントを追加
    1. OnePlus 7T Screen Replacement, Unscrew the motherboard cover: 手順 9、 1の画像 1
      • Use a Phillips screwdriver to remove the eleven 3.6 mm-long screws securing motherboard cover.
      • One of the screws is hidden beneath a white water damage sticker.
      FixBotに聞いてみる
      コメントを追加
    2. OnePlus 7T Screen Replacement, Remove motherboard cover: 手順 10、 3の画像 1 OnePlus 7T Screen Replacement, Remove motherboard cover: 手順 10、 3の画像 2 OnePlus 7T Screen Replacement, Remove motherboard cover: 手順 10、 3の画像 3
      • Insert the tip of an opening pick under the right bottom of the motherboard cover.
      • Slide the opening pick along the motherboard cover to release the plastic clips that hold it in its place.
      • Remove the motherboard cover.
      FixBotに聞いてみる
      コメントを追加
    3. OnePlus 7T Screen Replacement, Disconnect the battery: 手順 11、 2の画像 1 OnePlus 7T Screen Replacement, Disconnect the battery: 手順 11、 2の画像 2
      • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
      FixBotに聞いてみる
      コメントを追加
    1. OnePlus 7T Screen Replacement, Disconnect the flex cables: 手順 12、 3の画像 1 OnePlus 7T Screen Replacement, Disconnect the flex cables: 手順 12、 3の画像 2 OnePlus 7T Screen Replacement, Disconnect the flex cables: 手順 12、 3の画像 3
      • Use the flat end of a spudger to disconnect the two flex cables.
      FixBotに聞いてみる
      コメントを追加
    2. OnePlus 7T Screen Replacement, Reposition the flex cables: 手順 13、 3の画像 1 OnePlus 7T Screen Replacement, Reposition the flex cables: 手順 13、 3の画像 2 OnePlus 7T Screen Replacement, Reposition the flex cables: 手順 13、 3の画像 3
      • Bend the two flex cables toward the bottom of the phone and out of the way of the battery.
      • Avoid folding or sharply bending the cables as you reposition them. Doing so could damage the cables.
      FixBotに聞いてみる
      コメントを追加
    3. OnePlus 7T Screen Replacement, Remove the adhesive tape: 手順 14、 2の画像 1 OnePlus 7T Screen Replacement, Remove the adhesive tape: 手順 14、 2の画像 2
      • Use a spudger to carefully remove the adhesive tape on the left edge from the battery.
      FixBotに聞いてみる
      コメントを追加
    4. OnePlus 7T Screen Replacement, Remove the battery: 手順 15、 3の画像 1 OnePlus 7T Screen Replacement, Remove the battery: 手順 15、 3の画像 2 OnePlus 7T Screen Replacement, Remove the battery: 手順 15、 3の画像 3
      • Peel back the red pull tab.
      • Pull up on the red pull tab to lift the battery out of its recess and swing it up to an upright position.
      • If you're having trouble removing the battery, you can apply an iOpener to loosen the adhesive underneath the battery.
      FixBotに聞いてみる
      コメントを追加
    5. OnePlus 7T Screen Replacement, Remove the battery: 手順 16、 1の画像 1
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
      • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it's seated.
      FixBotに聞いてみる
      コメントを追加
    1. OnePlus 7T Screen Replacement, Remove the plastic film: 手順 17、 3の画像 1 OnePlus 7T Screen Replacement, Remove the plastic film: 手順 17、 3の画像 2 OnePlus 7T Screen Replacement, Remove the plastic film: 手順 17、 3の画像 3
      • Grab the edge of the film sticking out on the right side of the phone.
      • Pull the film towards the left side of the phone with steady force.
      • Remove the plastic film.
      FixBotに聞いてみる
      コメントを追加
    2. OnePlus 7T Screen Replacement, Disconnect the screen: 手順 18、 2の画像 1 OnePlus 7T Screen Replacement, Disconnect the screen: 手順 18、 2の画像 2
      • Use a spudger to disconnect the screen by prying the connector straight up from its socket.
      FixBotに聞いてみる
      コメントを追加
    3. OnePlus 7T Screen Replacement, Separate the display cable: 手順 19、 3の画像 1 OnePlus 7T Screen Replacement, Separate the display cable: 手順 19、 3の画像 2 OnePlus 7T Screen Replacement, Separate the display cable: 手順 19、 3の画像 3
      • The display cable is lightly adhered to the frame.
      • Grab the display cable with your fingers.
      • Pull the display cable toward the bottom of the phone.
      • Avoid folding or sharply bending the cable. Doing so could damage the cable.
      FixBotに聞いてみる
      コメントを追加
    4. OnePlus 7T Screen Replacement, Heat the screen: 手順 20、 1の画像 1
      • Heat an iOpener and apply it to the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      FixBotに聞いてみる
      コメントを追加
    5. OnePlus 7T Screen Replacement, Insert an opening pick: 手順 21、 3の画像 1 OnePlus 7T Screen Replacement, Insert an opening pick: 手順 21、 3の画像 2 OnePlus 7T Screen Replacement, Insert an opening pick: 手順 21、 3の画像 3
      • Apply a suction handle to the bottom of the screen.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Pull the suction cup up with strong, steady force to create a gap.
      FixBotに聞いてみる
      コメントを追加
    6. OnePlus 7T Screen Replacement, Slice the adhesive: 手順 22、 3の画像 1 OnePlus 7T Screen Replacement, Slice the adhesive: 手順 22、 3の画像 2 OnePlus 7T Screen Replacement, Slice the adhesive: 手順 22、 3の画像 3
      • Slide the opening pick along the bottom edge to separate the adhesive.
      FixBotに聞いてみる
      コメントを追加
    7. OnePlus 7T Screen Replacement: 手順 23、 3の画像 1 OnePlus 7T Screen Replacement: 手順 23、 3の画像 2 OnePlus 7T Screen Replacement: 手順 23、 3の画像 3
      • Insert a second opening pick at the bottom left corner.
      • Slide the opening pick along the left edge to the top left corner.
      FixBotに聞いてみる
      コメントを追加
    8. OnePlus 7T Screen Replacement: 手順 24、 3の画像 1 OnePlus 7T Screen Replacement: 手順 24、 3の画像 2 OnePlus 7T Screen Replacement: 手順 24、 3の画像 3
      • When you slice near the front camera, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
      • Insert a third opening pick at the top left corner.
      • Slide the opening pick along the top edge to the bottom right corner to slice the adhesive.
      • Leave the pick in the top right corner to prevent the adhesive from resealing.
      FixBotに聞いてみる
      コメントを追加
    9. OnePlus 7T Screen Replacement: 手順 25、 3の画像 1 OnePlus 7T Screen Replacement: 手順 25、 3の画像 2 OnePlus 7T Screen Replacement: 手順 25、 3の画像 3
      • Insert a fourth opening pick at the top right corner.
      • Slide the opening pick along the right edge to the bottom right corner to slice the adhesive.
      • Leave the pick in the bottom right corner to prevent the adhesive from resealing.
      FixBotに聞いてみる
      コメントを追加
    10. OnePlus 7T Screen Replacement, Remove the screen: 手順 26、 3の画像 1 OnePlus 7T Screen Replacement, Remove the screen: 手順 26、 3の画像 2 OnePlus 7T Screen Replacement, Remove the screen: 手順 26、 3の画像 3
      • Grab the display on the top and slowly pull the screen away from the frame.
      • If your screen is still sticking to the frame, slide the pick around the edges of the phone until the screen completely separates.
      • Thread the display flex cable through the gap in the frame.
      • Remove the screen.
      FixBotに聞いてみる
      コメントを追加
終わりに
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
キャンセル: このガイドを終了できませんでした。
7 の人々がこのガイドを完成させました。
Manuel Haeussermann
メンバー登録日: 07/13/22
26,461 ポイント
72のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
56,284のガイドは作成済み
8件のガイドコメント
A heat gun & I caused some heat damage to a small corner of my "NEW" replacement screen. Would this make the display not turn on at all? After putting everything back together, the only sign of life is a vibration when I plug in the charger. I didn't have USB debugging on before my screen initially broke so I can't tell if it's working minus the screen. Is there anything else that could be causing this? thanks
jasen king - 返信 共有
Hi jasen king, it sounds like it could be an issue with either the display cable or connector. You could try reseating the display connector, if that's not changing anything, you should check the connector socket for dust or bent pins or the display cable for any signs of damage. If your broken screen did still turn on, you could try reconnecting the old part to check whether there is an issue with your replacement part in general. You can find additional troubleshooting tips here. Hope this helps!
Manuel Haeussermann - 返信 共有
put 2 screens on mine and now 3 backs. Dont ever buy them from ali express or if they are less than at least £90 as they are just standard glass...wont even survive some pocket coins.
D G - 返信 共有
Just a note. Replacement transparent back rear glass looks so sick. You can get an original and remove the foil colour, but ive found them already to go with logo on ebay. They look soooo good. Enjoy... Easy fixes
D G - 返信 共有
really? I always thought it would look sick with a clear panel, but i didn't know you could just remove the film off the stock back. Is there a video/instructions for this anywhere?
Manny Singh - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 72
今までの合計 6,843
