はじめに
If you need to remove or replace the sensor in your Olympus C-765 camera, this guide may help.
Instead of film, digital cameras use image sensors to capture images. The sensor works by converting the light captured by the camera into a digital image. If the image sensor is damaged or has stopped working, it may need to be replaced.
The image sensor is located deep inside the camera and requires multiple specialized steps to remove.
Step 4 of this guide requires disconnecting ribbon cables.
Steps 6 and 7 of this guide require removing the motherboard from the camera. Removing the motherboard from the camera involves desoldering components from the camera's motherboard.
Before beginning, make sure to power off your camera and disconnect any external power source.
必要な工具と部品
Use a Phillips #00 screwdriver to remove the single 4mm screw located directly to the right of the viewfinder on the back of the camera.
Remove the two 2mm screws from the left side panel.
Remove the single 3mm screw from the right side panel.
Remove the five 3mm screws from the bottom of the camera.
Remove the ribbon cable directly below the viewfinder.
Detach the white plastic clip from its socket with a pair of tweezers.
Disconnect the ribbon cable from the center of the board, near the central hole.
Disconnect the three ribbon cables from the top right of the motherboard, near the selector wheel. One is on the top of the board, and the other two are on the underside.
