はじめに
Follow this guide to replace the left joystick in your Nintendo Switch Lite. Replacing the joystick will fix the notorious “Joy-Con drift” issue.
Note: This procedure requires disconnecting the battery for safety. In order to do this, the shield plate must be removed. The shield plate is bonded to the heat sink with thermal paste, which will need to be cleaned off and reapplied before reinstalling the shield plate.
必要な工具と部品
この手順で使用する道具:Magnetic Project Mat$19.95
Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
Two 3.6 mm-long screws on the top of the device
Two 3.6 mm-long screws on the bottom of the device
Insert an opening tool into the left speaker grille on the bottom of the device.
Twist the opening tool to release the clips securing the back panel.
Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
Insert an opening tool into the right speaker grille on the bottom of the device.
Twist the opening tool to release the clips.
Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
Lift the bottom edge of the back panel, opening it like a book.
Remove the back panel.
Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
Three 3.1 mm screws
One 4.5 mm screw
Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
Use a pair of tweezers or your fingers to pull the left speaker cable straight up and out of its socket on the daughterboard.
Use an opening tool or your fingernail to flip up the small, hinged locking flaps on the two ribbon cable ZIF connectors.
Use a pair of tweezers or your fingers to remove the volume buttons.
Use an opening tool or your fingernail to flip up the small, hinged locking flap on the left joystick cable's ZIF connector.
Use a Phillips screwdriver to remove the two 4.5 mm screws securing the left trigger button assembly.
Use a Phillips screwdriver to remove the following four screws:
Two 4.5 mm screws
Two 6 mm screws
Use a Phillips screwdriver to remove the two 3.5 mm screws securing the left joystick.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
95 の人々がこのガイドを完成させました。
35 件のコメント
Really appreciate the detailed pictures.
This was great, I love how every step was so simply broken down and had pictures. Thank you, my son is very happy to have his switch back in action.
I followed this guide, bought the tools and replacement part, after successfully doing the replacement, my switch light now won’t power on at all, how can I fix this? any help please…
Hi Iczleal I had the same issue when I first did it and then I went back step by step. Turns out I didn’t plug the battery back in correctly, I recommend just repeating the steps and checking to see if everything is connected properly. Hope this helps :)
