はじめに
Use this guide to replace the mirror box and viewfinder.
Note: You'll need JIS screwdrivers for this repair. Regular Phillips screwdrivers have a cross pattern with rounded inner edges and won't fully fit the slots in the JIS screws. JIS screwdrivers instead have a straight cross pattern which makes much better contact with the screw head and is made for the high torque you will need to loosen the screws.
必要な工具と部品
Remove the following 5 screws securing the bottom cover to the camera body:
Four 6 mm J000 screws.
One 8 mm J000 screw (under lens mount).
Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
Pull out ribbon cable from circuit asembly near front left of device.
5 の人々がこのガイドを完成させました。
