メインコンテンツにスキップ
Motorola Edge Telephoto Camera Replacement
必要な工具と部品
  1. Motorola Edge Telephoto Camera Replacement, Heat the bottom edge: 手順 1、 1の画像 1
    • Completely power off your phone before you begin.
    • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge Telephoto Camera Replacement, Separate the bottom adhesive: 手順 2、 3の画像 1 Motorola Edge Telephoto Camera Replacement, Separate the bottom adhesive: 手順 2、 3の画像 2 Motorola Edge Telephoto Camera Replacement, Separate the bottom adhesive: 手順 2、 3の画像 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge Telephoto Camera Replacement, Slice the bottom adhesive: 手順 3、 3の画像 1 Motorola Edge Telephoto Camera Replacement, Slice the bottom adhesive: 手順 3、 3の画像 2 Motorola Edge Telephoto Camera Replacement, Slice the bottom adhesive: 手順 3、 3の画像 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Motorola Edge Telephoto Camera Replacement, Heat the right edge: 手順 4、 1の画像 1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  5. Motorola Edge Telephoto Camera Replacement, Separate the corner adhesive: 手順 5、 3の画像 1 Motorola Edge Telephoto Camera Replacement, Separate the corner adhesive: 手順 5、 3の画像 2 Motorola Edge Telephoto Camera Replacement, Separate the corner adhesive: 手順 5、 3の画像 3
    • Rotate the opening pick around the bottom-right corner of the phone.
  6. Motorola Edge Telephoto Camera Replacement, Separate the right adhesive: 手順 6、 3の画像 1 Motorola Edge Telephoto Camera Replacement, Separate the right adhesive: 手順 6、 3の画像 2 Motorola Edge Telephoto Camera Replacement, Separate the right adhesive: 手順 6、 3の画像 3
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the right edge of the phone to separate the adhesive.
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
  7. Motorola Edge Telephoto Camera Replacement, Remove the back cover: 手順 7、 3の画像 1 Motorola Edge Telephoto Camera Replacement, Remove the back cover: 手順 7、 3の画像 2 Motorola Edge Telephoto Camera Replacement, Remove the back cover: 手順 7、 3の画像 3
    • Remove the back cover, taking care not to damage the components inside the phone.
  8. Motorola Edge Telephoto Camera Replacement, Remove the motherboard's screws: 手順 8、 1の画像 1
    • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
  9. Motorola Edge Telephoto Camera Replacement, Remove the motherboard cover: 手順 9、 3の画像 1 Motorola Edge Telephoto Camera Replacement, Remove the motherboard cover: 手順 9、 3の画像 2 Motorola Edge Telephoto Camera Replacement, Remove the motherboard cover: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
    • The motherboard cover also contains the phone's flash.
  10. Motorola Edge Telephoto Camera Replacement, Disconnect the battery cable's press connector: 手順 10、 2の画像 1 Motorola Edge Telephoto Camera Replacement, Disconnect the battery cable's press connector: 手順 10、 2の画像 2
    • Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  11. Motorola Edge Telephoto Camera Replacement, Remove the telephoto camera's press connector: 手順 11、 3の画像 1 Motorola Edge Telephoto Camera Replacement, Remove the telephoto camera's press connector: 手順 11、 3の画像 2 Motorola Edge Telephoto Camera Replacement, Remove the telephoto camera's press connector: 手順 11、 3の画像 3
    • Use a spudger to pry up and disconnect the telephoto camera cable's press connector from the motherboard.
    • Remove the telephoto camera.
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
作成者
2人の作成者と共同で作成されました。
Jennifer Berg
メンバー登録日: 03/21/22
2,751 ポイント
24のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 141
