メインコンテンツにスキップ
Meta Quest 2 Power Button and LED Board Replacement
必要な工具と部品
  1. Meta Quest 2 Power Button and LED Board Replacement, Power off your Meta Quest 2: 手順 1、 1の画像 1
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Power Button and LED Board Replacement, Remove the facial interface: 手順 2、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Remove the facial interface: 手順 2、 2の画像 2
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Power Button and LED Board Replacement: 手順 3、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 3、 2の画像 2
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Power Button and LED Board Replacement: 手順 4、 1の画像 1
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Power Button and LED Board Replacement, Unclip the side straps: 手順 5、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Unclip the side straps: 手順 5、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement, Unclip the side straps: 手順 5、 3の画像 3
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Power Button and LED Board Replacement: 手順 6、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 6、 2の画像 2
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Power Button and LED Board Replacement, Remove the top strap: 手順 7、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Remove the top strap: 手順 7、 2の画像 2
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Power Button and LED Board Replacement, Remove the head strap: 手順 8、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Remove the head strap: 手順 8、 2の画像 2
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Power Button and LED Board Replacement, Remove the eyepiece trim screws: 手順 9、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Remove the eyepiece trim screws: 手順 9、 2の画像 2
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Power Button and LED Board Replacement, Release the eyepiece trim clips: 手順 10、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Release the eyepiece trim clips: 手順 10、 2の画像 2
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Power Button and LED Board Replacement: 手順 11、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 11、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement: 手順 11、 3の画像 3
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Power Button and LED Board Replacement: 手順 12、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 12、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement: 手順 12、 3の画像 3
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Power Button and LED Board Replacement, Reposition the eyepiece trim: 手順 13、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Reposition the eyepiece trim: 手順 13、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement, Reposition the eyepiece trim: 手順 13、 3の画像 3
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Power Button and LED Board Replacement, Disconnect the face sensor: 手順 14、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the face sensor: 手順 14、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the face sensor: 手順 14、 3の画像 3
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Power Button and LED Board Replacement: 手順 15、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 15、 2の画像 2
    この手順で使用する道具:
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Power Button and LED Board Replacement, Remove the eyepiece trim: 手順 16、 1の画像 1
    • Remove the eyepiece trim.
  17. Meta Quest 2 Power Button and LED Board Replacement, Reassembly note: 手順 17、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Reassembly note: 手順 17、 2の画像 2
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Power Button and LED Board Replacement, Reassembly note: 手順 18、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Reassembly note: 手順 18、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement, Reassembly note: 手順 18、 3の画像 3
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
  19. Meta Quest 2 Power Button and LED Board Replacement, Remove the front cover screws: 手順 19、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Remove the front cover screws: 手順 19、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement, Remove the front cover screws: 手順 19、 3の画像 3
    • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
    • One recessed in the top-left corner
    • One recessed in the top-right corner
    • Three along the lower edge
  20. Meta Quest 2 Power Button and LED Board Replacement, Release the front cover clips: 手順 20、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Release the front cover clips: 手順 20、 2の画像 2
    • The front cover is still held in place by clips along the bottom and side edges.
    • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
    • Pry with the opening pick to release the front cover clips.
  21. Meta Quest 2 Power Button and LED Board Replacement: 手順 21、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 21、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement: 手順 21、 3の画像 3
    • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
  22. Meta Quest 2 Power Button and LED Board Replacement, Remove the front cover: 手順 22、 1の画像 1
    • Remove the front cover.
  23. Meta Quest 2 Power Button and LED Board Replacement, Disconnect the top right antenna: 手順 23、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the top right antenna: 手順 23、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the top right antenna: 手順 23、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
    • Lift the antenna connector straight up to disconnect it.
    • Guide the antenna cable out of its metal clip holding it in place.
  24. Meta Quest 2 Power Button and LED Board Replacement, Remove the battery cable bracket: 手順 24、 1の画像 1
    • Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
    • One 4.4 mm‑long screw
    • Two 2.3 mm‑long screws
  25. Meta Quest 2 Power Button and LED Board Replacement: 手順 25、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 25、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement: 手順 25、 3の画像 3
    • Use tweezers or your fingers to grasp the battery cable bracket.
    • Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
    • Remove the battery cable bracket.
  26. Meta Quest 2 Power Button and LED Board Replacement, Disconnect the battery: 手順 26、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the battery: 手順 26、 2の画像 2
    • Use a spudger to pry up and disconnect the battery press connector from the motherboard.
    • The battery press connector can disconnect accidentally during reassembly. Check this connector before you attach the bracket.
  27. Meta Quest 2 Power Button and LED Board Replacement, Disconnect the antenna: 手順 27、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the antenna: 手順 27、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the antenna: 手順 27、 3の画像 3
    この手順で使用する道具:
    • Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
  28. Meta Quest 2 Power Button and LED Board Replacement, Loosen the front antenna assembly: 手順 28、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Loosen the front antenna assembly: 手順 28、 2の画像 2
    • Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
    • Four 4.4 mm‑long screws
    • Two 4.8 mm‑long screws
    • Two 10.7 mm‑long screws
  29. Meta Quest 2 Power Button and LED Board Replacement: 手順 29、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 29、 2の画像 2
    • Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
  30. Meta Quest 2 Power Button and LED Board Replacement: 手順 30、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 30、 2の画像 2
    • Use tweezers to unclip the antenna cable from its metal clip.
  31. Meta Quest 2 Power Button and LED Board Replacement, Remove the front antenna assembly: 手順 31、 1の画像 1
    • Remove the front antenna assembly.
  32. Meta Quest 2 Power Button and LED Board Replacement, Disconnect the fan: 手順 32、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the fan: 手順 32、 2の画像 2
    この手順で使用する道具:
    • Use tweezers to grab the fan connector and carefully slide it out of its socket.
  33. Meta Quest 2 Power Button and LED Board Replacement, Loosen the LED flex cable: 手順 33、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Loosen the LED flex cable: 手順 33、 2の画像 2
    • Use the point of an opening pick to loosen the adhesive securing the LED flex cable from the top of the fan assembly.
  34. Meta Quest 2 Power Button and LED Board Replacement, Remove the fan assembly: 手順 34、 1の画像 1
    • Remove the two screws securing the fan assembly to the headset:
    • One 4.4 mm‑long Phillips screw
    • One 3.6 mm‑long Torx T2 screw
  35. Meta Quest 2 Power Button and LED Board Replacement: 手順 35、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 35、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement: 手順 35、 3の画像 3
    • Lift the fan assembly and remove it.
  36. Meta Quest 2 Power Button and LED Board Replacement, Remove the heat sink: 手順 36、 1の画像 1
    • Use a Phillips screwdriver to remove the four 2.3 mm‑long screws securing the heat sink to the motherboard.
  37. Meta Quest 2 Power Button and LED Board Replacement: 手順 37、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 37、 2の画像 2
    この手順で使用する道具:
    iFixit Thermal Putty
    $9.95
    • Use your fingers to lift the heat sink and remove it.
    • You may feel a bit of resistance. This is normal since the midframe is slightly bonded to the heat sink with thermal paste.
    • You can reuse the thermal paste if you keep it clean. Otherwise, use a spudger to scrape off the old paste and apply a small amount of thermal putty or viscous thermal compound (such as K5 Pro) to the processor.
  38. Meta Quest 2 Power Button and LED Board Replacement, Reassembly note: 手順 38、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Reassembly note: 手順 38、 2の画像 2
    • During reassembly, stop here and check if these twelve connectors are properly connected to the motherboard:
    • Two speaker connectors
    • Seven ZIF connectors
    • Two press connectors
    • One antenna connector
    • There are additional connectors on the motherboard, but they shouldn't be connected at this point.
  39. Meta Quest 2 Power Button and LED Board Replacement, Disconnect the speaker connectors: 手順 39、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the speaker connectors: 手順 39、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the speaker connectors: 手順 39、 3の画像 3
    この手順で使用する道具:
    • Use tweezers to grip the left speaker cables at the base of their motherboard connector.
    • Lift the connector gently straight up to disconnect it.
    • During reassembly, use the flat end of a spudger to press the speaker cable into the rubber holding clip.
  40. Meta Quest 2 Power Button and LED Board Replacement: 手順 40、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 40、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement: 手順 40、 3の画像 3
    • Repeat the disconnection procedure for the right speaker connector.
  41. Meta Quest 2 Power Button and LED Board Replacement, Disconnect the ZIF socket flex cables: 手順 41、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the ZIF socket flex cables: 手順 41、 2の画像 2
    • Use tweezers to gently peel the black tape covering the two top flex cables.
    • Set the tape aside to be reused during reassembly.
  42. Meta Quest 2 Power Button and LED Board Replacement: 手順 42、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 42、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement: 手順 42、 3の画像 3
    • Use a clean fingernail or a spudger to pry up the lock tab securing the top left camera cable.
  43. Meta Quest 2 Power Button and LED Board Replacement: 手順 43、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 43、 2の画像 2
    • Grasp the top left camera cable with tweezers and slide it out of its ZIF connector.
  44. Meta Quest 2 Power Button and LED Board Replacement: 手順 44、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 44、 2の画像 2
    • Move counter-clockwise around the motherboard and disconnect the remaining six ZIF connectors:
    • Power button and LED board
    • Bottom left camera
    • Bottom right camera
    • Top right camera
    • Face sensor interconnect cable
    • Indicator LED cable
  45. Meta Quest 2 Power Button and LED Board Replacement, Disconnect the press connectors: 手順 45、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the press connectors: 手順 45、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement, Disconnect the press connectors: 手順 45、 3の画像 3
    • Use a spudger to pry up and disconnect the display cable.
  46. Meta Quest 2 Power Button and LED Board Replacement: 手順 46、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 46、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement: 手順 46、 3の画像 3
    • Use a spudger to pry up and disconnect the USB‑C and headphone jack cable.
  47. Meta Quest 2 Power Button and LED Board Replacement: 手順 47、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 47、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement: 手順 47、 3の画像 3
    • Insert one arm of a pair of tweezers under the metal neck of the side antenna cable.
  48. Meta Quest 2 Power Button and LED Board Replacement, Remove the motherboard: 手順 48、 1の画像 1
    • Remove the five screws securing the motherboard to the headset:
    • Four 3.8 mm‑long Phillips screws
    • One 6 mm‑long 3.5 mm hex standoff screw
  49. Meta Quest 2 Power Button and LED Board Replacement: 手順 49、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 49、 2の画像 2
    • At this point, the motherboard should be loose, with some thermal paste sticking it to the headset.
    • Use a spudger to pry up and separate the motherboard from the headset.
    • If it feels like the motherboard is caught on something, check that all the cables are disconnected from it.
  50. Meta Quest 2 Power Button and LED Board Replacement: 手順 50、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 50、 2の画像 2
    この手順で使用する道具:
    $9.95
    • Remove the motherboard.
  51. Meta Quest 2 Power Button and LED Board Replacement, Remove the camera covers: 手順 51、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Remove the camera covers: 手順 51、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement, Remove the camera covers: 手順 51、 3の画像 3
    この手順で使用する道具:
    • Use your fingers or tweezers to peel and remove the two camera covers from the top cameras.
    • During reassembly, align the cutouts on the camera covers to their respective pegs on the headset.
    • The camera covers have different alignment cutouts and aren't interchangeable.
  52. Meta Quest 2 Power Button and LED Board Replacement, Loosen the screen and lens assembly: 手順 52、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Loosen the screen and lens assembly: 手順 52、 2の画像 2
    • Peel and remove the black tape covering the antenna cable.
    • Set this tape aside to be reused during reassembly.
  53. Meta Quest 2 Power Button and LED Board Replacement: 手順 53、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 53、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement: 手順 53、 3の画像 3
    • Use tweezers to lift and unclip the black antenna cable from the metal grounding clips.
  54. Meta Quest 2 Power Button and LED Board Replacement: 手順 54、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 54、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement: 手順 54、 3の画像 3
    • Use a spudger to pry up the black lock tab securing the left microphone flex cable to the left interconnect cable.
    • Use your fingers or tweezers to slide the microphone cable out of the ZIF connector.
  55. Meta Quest 2 Power Button and LED Board Replacement: 手順 55、 1の画像 1
    • Repeat the procedure to disconnect the right microphone cable.
  56. Meta Quest 2 Power Button and LED Board Replacement: 手順 56、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 56、 2の画像 2
    • Slide the point of an opening pick underneath the battery flex cable to loosen the adhesive securing it from the headset.
  57. Meta Quest 2 Power Button and LED Board Replacement: 手順 57、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement: 手順 57、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement: 手順 57、 3の画像 3
    • Some interconnect cables have been removed in the following images for clarity purposes. You don't have to remove them as part of the procedure.
    • Use a Phillips screwdriver to remove the four screws securing the screen and lens assembly to the frame:
    • Two 6.5 mm‑long screws
    • Two 7.7 mm‑long screws
  58. Meta Quest 2 Power Button and LED Board Replacement, Remove the screen and frame assembly: 手順 58、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Remove the screen and frame assembly: 手順 58、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement, Remove the screen and frame assembly: 手順 58、 3の画像 3
    • Grasp the screen and lens assembly with your fingers.
    • Slowly lift and separate the assembly from the outer shell, taking care to reposition any cables that get in the way.
    • Remove the screen and lens assembly.
  59. Meta Quest 2 Power Button and LED Board Replacement, Reassembly note: 手順 59、 3の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Reassembly note: 手順 59、 3の画像 2 Meta Quest 2 Power Button and LED Board Replacement, Reassembly note: 手順 59、 3の画像 3
    • During reassembly, be careful not to trap the twelve cables as you insert the lens assembly into the outer shell:
    • Three cables along the top edge—two flex cables and one LED flex cable
    • Two cables in the top right corner—the battery connector and an antenna cable
    • Two cables along the right edge—an antenna cable and a wide flex cable
    • Two flex cables along the bottom edge
    • Three cables along the left edge—one antenna cable, one flex cable, and one speaker cable
    • You can use a rubber band to help secure the cables out of the way.
  60. Meta Quest 2 Power Button and LED Board Replacement, Remove the power button and LED board screws: 手順 60、 1の画像 1
    • Use a Phillips screwdriver to remove the two 4.5 mm‑long screws securing the power button and LED board to the outer shell.
  61. Meta Quest 2 Power Button and LED Board Replacement, Remove the power button and LED board: 手順 61、 2の画像 1 Meta Quest 2 Power Button and LED Board Replacement, Remove the power button and LED board: 手順 61、 2の画像 2
    この手順で使用する道具:
    • Use your fingers or tweezers to remove the power button and LED board.
    • During reassembly, align the board using the two alignment pegs. The pegs have different diameters, so the board will align in only one orientation.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Arthur Shi
メンバー登録日: 01/03/18
310,253 ポイント
701のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,648のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 48
過去 30 日: 113
今までの合計 1,408
