はじめに
消耗したバッテリーを交換するにはこのガイドを使用してください。
ご注意:もし交換用のバッテリー上に薄いプラスチックのフィルムが付いている場合は、これを外さないでください。MacBookも内側につけられている間、バッテリーパックを保護する役割があります。
必要な工具と部品
この手順で使用する道具:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
P5ペンタローブドライバーを使って、下部ケースをはずしてください。ネジは次の長さに分かれます。
9mm ネジー 2本
2.6mm ネジー 8本
ディスプレイと下部ケースの間に指を入れ、上に引っ張って下部ケースを本体から外します。
下部ケースを取り外して脇に置きます。
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
To add - the slim 1cm tab “nub” is on the centre of the back cover & fits into a hole in the battery frame. I ran my fingers around the whole of the cover to eventually here it click out.
nijafe -
So this is a legit back cover for MacBook Air?
I bought the part and tools from iFixit and followed the directions. The mechanical part went smoothly - maybe 10 minutes to disassemble/replace/reassemble.
Getting Catalina (the current MacOS) to install was not working until I used Cmd-Opt-R (as noted in the OWC paper sheet that came in the box) which brought up the proper installer - I believe from a pre-prepared bootable SD card but it’s hard to say. From there the install succeeded taking ~1.5 hours.
Beware that (a) the install requires a working internet connection for verification and updates, and (b) the system must have been running at least macOs 10.13 (High Sierra) before the install in order to have an EFI BIOS that recognizes the SSD.
Lance Berc - 返信
Thanks for the detailed photos. When repairing equipment, I don’t really like to disassemble plastic parts, they can be damaged, but your screenshots help a lot. For my studies, I am writing an essay comparing the reliability of laptops from various manufacturers and the complexity of their repair, maybe it will be useful for someone to check the essay for plagiarism here essay checker, when comparing different manufacturers, I understood why people love Apple so much. The minimum number of failures. Of course, repairing it in an official service is not cheap, but with the help of such detailed instructions, you can do it yourself and save a lot.
The screwdriver bit to use on these case screws is not named, but I found that my "CR-V 1.2" did the job nicely.
The driver for the screws inside the case are named, as "T5".
バッテリーコネクターに付けられている透明なプラスチックのプルタブを掴みAir本体の前側に向かって引き基盤からバッテリーを切り離します。
新しいバッテリーを再装着する際、バッテリーをフレームに入れる前に一時的に接続し直すと便利な場合があります。コネクターが基板に対して平らになっていることを確認してください。
The guide says: "Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board", but the battery model that I was replacing did not have a clear plastic pull tab at all...
The battery model shown in this guide is: A1405
I was installing battery model: A1406
A1406 has the following connector:
Top:
http://www.directupload.net/file/d/4122/...
Bottom:
By looking at the bottom of the new battery I saw how it could be removed. Simply by a gentle upward movement. I very, very carefully nudged it a bit upwards using a screwdriver on the left and right side, as shown here:
It came out fairly easy, luckily!
(And yes, I also cleaned up this MacBook before closing it again. It was a bit hairy in a literal way. Electronics and pets is not the best combination. ;-) )
This was a great guide!
I think you may have been reading the wrong guide by mistake.
Looking at the various MacBook Air battery replacement guides, all of the 13" models show the connector depicted in this guide. All of the 11" models (e.g. MacBook Air 11インチ Mid 2012バッテリー交換) show a connector like the one in your photos.
shamino -
The 13 inch's tab is a bit more difficult to reinstall than uninstall. Delicate care is needed.
I agree with Andrew and Joes. I also found that the trickiest part was to pull the tap back when reinstalling the new battery. A special hint at this point in the guide would be nice.
This is the tricky part if there is one. Just pull back towards the battery and not up.
Joe Wasser - 返信
hello there, My macbook air does not recognize a battery connected, anymore.
It looks like I damaged the connectors while trying to connect the battery back, although it does not look damaged. I must say, I tried a little force to squeeze the connector in the middle instead of the edge. May have damaged the connector ?
Once, after this, the MBA recognized my battery when pressed the connectors edge to the pins on the board. However, this did not last long and my MBA does not recognize the battery anymore. Any solutions on how I can fix this ? Please help.
Had the same issue where my Macbook did not recognize the battery on the first try. I opened it back up and re-seated the connector and that fixed the problem. That particular connector does not seem to have a positive engagement. It does not appear to seat all the way down. It’s charging now and I hope it will remain stable and connected as I travel.
When we were putting the new battery in, it was easier to fit the tab back on and then fit the battery in place. I had someone helping me and they held the new battery up whilst I pushed the tab in. It was quite tight, and I ended up easing it in with the tip of a screwdriver on each edge in turn.
The plastic pull tab broke off with the tiny tug I gave it (Mid-2011 Air). I just unscrewed the battery and carefully pulled out the connector when I had the extra room.
Sam Kernot - 返信
for my 11inch mac air [mid 2011] the connecter is connected vertically and not horizontally - so you need to pull up, not back. thanks to Will for the links to the illustrations that made that clear. Getting the connecter to release was the hardest part of the job - otherwise, it was just removing screws.
Jim Kemper - 返信
I had same as above you have to be very sure on your screen size as the battery disconnect looks a little different and I used the 11 inch steps on the link provided which worked perfectly! thanks
Jim Lukens - 返信
Successful battery change on Macbook Air 13 mid-2012.
After screwing in the new battery, I couldn't connect it to the motherboard. I was afraid of damaging the connection and the rest of the components.
So it seemed easier to me to unscrew the new battery, then plug it in and finally screw it back in one last time. I think that this step lacks a point of precision in terms of reassembly.
Otherwise, it's a good tutorial, thank you very much!
**Note during this step how the cable flexes. With the new battery you will need to carefully bend your new connector to be able to flex in the same way, which is easier to do before you install the battery. in fact, i agree with other comments that for re-install it is easier carefully hold the battery up a bit (to keep it off the trackpad components), and install the plug as you are moving the battery up into place. This will limit the amount the cable needs to flex and take that pressure off the connector to the logic board.
In line with some other comments, I found it helpful to connect the cable before putting the new battery into place. That way I could aim the cable straight into the receptacle, and the wires folded appropriately into their small space when I put the battery in position and screwed it down.
バッテリを上部ケースに固定している以下の5本のネジを外します:
6.3 mm T5トルクスねじ 3本
2.4 mm T5トルクスねじ 2本
The screw heads are made of a soft butter like chinese metal and will easily get f*cked up. take care when reinstalling to not mess them up.
Ich habe ein Problem die Schrauben von dem Akku mit dem gelieferten Schraubenzieher-Set rauszudrehen. Nur die Schraube in der Mitte konnte ich rausdrehen. Brauche ich einen anderen Schraubenzieher? Sollen die beiden Schraubenzieher aus dem mitgelieferten Set zu den Akku-Schrauben passen? Danke für eure Hilfe im Voraus! Alex
6.3mm T5 x 1
2.4mm T5 x 4
My Air is
6.3 mm T5 x 1
2.4 mm T5 x 4
バッテリーをロジックボードに近い上端から持ち上げ、上部ケースから取り外します。
100%になるまで充電します。充電後も最低2時間はプラグを繋げたままにします。それからプラグを外して、通常通り使用しながら、自然に放電させます。バッテリー残量小のサインが表示されたら、これまでの作業を保存して、スリープ状態になるまで放置してください。スリープ状態に入ったら、少なくとも5時間置きます。それから一気に100%まで充電します。
新しいバッテリーを装着後、通常通り作動しない場合は、MacBook ProのSMCをリセットしなければならない可能性があります。
Quick note about the replacement battery, if you bought from iFixit and the battery sections have a thin film over them, peel them off. They're to protect the battery during transit, and if you leave them on they might cause heating issues.
Here is a link to my question about it: Replacement battery has thin film on each section do I need to remove? plus, I just got an email from iFixit customer support that it needs to be removed.
thank you for the help! I installed the proper batt properly following the advice from here;-) Mahalo from Hawaii-
Does replacement battery for Macbook Air 13" Mid 2012 works with Mac OS Sierra 10.12.3 and up?
Replaced it in no time! Thank you and cheers from Slovenia (that’s the one who beat you in hockey few days ago
Mark Ogner - 返信
iFixit should really clarify whether the film covering each of the battery packs should or should not be removed. Based on dpchoung’s comment I removed this film. It was not obvious or easy to remove and as I was doing it I realized that maybe this was not a good idea as I was concerned the packs might be damaged in the removal process. I suspect most people don’t bother with this film. Later, clicking on the forum exchange I see conflicting advice. My guess is that the film provides added protection and has minimal impact on thermal issues. I am sorry I went through the bother of removing the film and hope no damage was done.
Mark Young - 返信
Ich hab’ gelesen, dass neu eingebaute Batterien kalibriert werden müssen: https://www.newertech.com/batteries/powe...
Great here. Replacement was a breeze. Thanks guys.
It’s part of the calibration process—leaving it dead for awhile ensures that the battery drains low enough to reset the full discharge flag in the battery management system. If you skip that part, your battery may not calibrate properly. (It’ll still work fine, but the battery’s % charge status in macOS may be unreliable and/or behave in odd ways.) If you had to skip it for some reason, you can recalibrate at any time.
After I replaced the battery, I plugged the charger in to start calibration and the computer started by itself. As soon as this happened I turned it off. Can this be an issue?
How do I know the battery is 100% charged?
Thank you
tobias.a94 - 返信
It might be obvious to most people, but no mention of plugging in the battery connector when installing the new battery. I missed that part at first. Overall great instructions and finished quickly.
It went well, thank you. One comment though, I prefer to put the connector back before installing the new battery since the cable is not flexible enough.
Replaced my new battery for a mid 2011 MacBook Air but now the battery icon says it’s not charging
how do i dispose of the old battery responsibly?
+1 curious about this. Should be added to the guide
Why shouldn’t I touch the lithium polymer cells? Is that on removal, too? Is it dangerous for me or just the battery (like getting finger oils on a halogen bulb)? Would it be beneficial to wear thin latex gloves?
After Installation my MacBook does not start, but there are peep tones 3x in a row and this repeats until I press power for few seconds. Any clue what this could be?
Installation was very easy. Works perfect for me and battery is now fully charged and running.
Installation was a breeze thanks to your tips.
When placing the new battery in, reconnect it first before screwing into place.
The battery film issue. The film pictured in the guide covers each individual battery. The guide also states it is glued on. My iFixit replacement battery had a different kind of film that covered the whole battery module. It was not precise fit and was loosely stuck on rather than permanently glued. It was obviously the kind that is used to protect from scratches in packaging/shipping. It peeled off easily with no residue. My conclusion is the warning is meant for film on individual batteries. For the iFixit one I received, the film was meant to be peeled.
I have installed the battery replacement for a MBA Mid 2012 and it’s working, but the battery temperature is somehow stuck at around 26 degree Celsius. Even if you do a stresstest with 27 Watt the temperature is falling from 26.25 to 26,15. So it ssems to me that the temperature measurement isn’t correct. In other MBA Mid 2012 with original Battery the temperature range is from ambient to 41 degree.
Don’t know if the wrong temperature has an impact on the lifetime of the battery, as the battery controller should limit currents according to temperature.
very easy - was gifted MBA but battery life was 'r/s' - vacuumed out fluff etc from machine & fan while back was off (was a technician in a previous life) .. now performing calibration. I'll write down the settings, then set energy saver to 'never' for both battery & power adaptor when it comes time to discharge the battery, then reset to original values after final charge. Fingers crossed (it's a helluva lot easier than 'Blackberry trackballs')
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
e-wasteを処理する場合は、認可済みリサイクルセンターR2を通じて廃棄してください。
修理が上手く進みませんか?トラブルシュートのヘルプには、アンサーコミュニティを参照してください。
502 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
73 件のコメント
Done! Now my Macbook Air has a new lease on life! I travel a lot and need good battery life on my Macbook so that I can work on flights, work throughout the day in meetings, do presentations etc.,
I ordered the battery and a pentelobe screwdriver from iFixit - they arrived quickly and as as promised in South Africa. The replacement took just a few minutes. The guide was very helpful and easy to follow. Now I have 6 hours of battery life again (or maybe a few minutes less ;-)
Thanks guys. I am very happy!
@digitaldion, Could you share what is time on a single charge now, after almost a year of active(?) use?
I had spilled Iced Tea all over my new laptop. Soaked it in rice, but it only would work when it was plugged in. I read replacing the battery would fix it. Ordered the battery...came in 2 days, and I used the repair guide. Worked with 100% success and now my laptop runs like it's brand new.
I changed the battery. It was very esay. However the MBA has now become very very slow. Can anyone explain this?
It's because incompatible battery model. It requires A1405.
Replaced the new battery with my old one. Now everything works as normal again. What is this about. Please notice that the new battey is an original Apple battey - not a copy product.
How can you be sure it is original?
I suspect they just re-use the original apple battery trays and put third party battery packs in them. The two batteries I ordered had Apple trays, but one was in a sealed box and the other box had no seal with a hand-written sticker on the battery tray. Plus, there was wear on the battery tray screw holes which tells me they have been used before.
Munky -
The replacement itself was easy enough, but it did not solve my problem - any advice would be greatly appreciated!
I have a Macbook Air 13" mid 2011, the battery only got to 121 cycles before it stopped holding a charge at all and I could only use the laptop when plugged into the power adapter. The battery status says "Not Charging" and the adapter status light does not glow when connected (it does function normally when plugged into any other computer, so the adapter is not the issue). The second it becomes disconnected the computer shuts down.
I just replaced the battery, one I ordered from iFixIt and the computer recognizes it, but it says cycle count: 0 and condition: replace now.
Charge Information:
Charge Remaining (mAh): 2545
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 6620
Health Information:
Cycle Count: 0
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 7575
I'm at a total loss for what to do next to solve this problem. Any ideas?
Check if the MagSafe port on your MacBook is intact — the small middle prong which is responsible for detecting and identifying the charger might be damaged. If it can't identify the charger, it will resort to only powering your laptop (as long as the other prongs work), but not charging it. As soon as you disconnect it, it shuts down because the battery is drained.
rale09 -
Don't forget the Torx T5!
I already had a Torx set, so only bought the P5 driver, but turns out my set only went down to T6 :-(
The first battery I received was faulty - it kept suddenly cutting out while in use - but iFixit were brilliant in sending a replacement immediately.
Hint: if after changing the battery your Macbook doesn't "bong" when it powers on (and you'd like to to!) then you can fix this by resetting the PRAM. See https://discussions.apple.com/docs/DOC-3...
Very great guide... coupled with the purchase of screwdriver / batter... phenomenal!
Thank you iFixIt!
Worked suberb! Thumbs up for the guide and the new battery!
Delivery and replacement were fast and easy. After booting up I checked the new battery with Coconut Battery and found the load cycles at 1 which was what I expected. The age of the battery was indicated as 37 months old and thus older than my MacBook Air. That's not what I expected.
Don't batteries get old from just lying around?
Am I the only one having trouble getting the screws out?
My battery screws are the 6 pointed star ones, not the 5 pointed. Maybe you have the same?
effie -
The Ifixit P5 Pentalobe screw driver worked great to remove the Loctite cemented 51 PR case screws. The 5 battery screws are T5 Torx 6 pointed screws.
I just did this repair, and it went very smoothly. The only problem I had with the instructions were that the screws on the battery were not the same 5-pointed stars as the one on the case. My battery has 6 pointed star screws. Luckily, I have both screwdrivers so this wasn't an issue. My connector also looked a bit different than the one in the photo, so maybe my laptop came from a different batch...?
Maybe they edited the instructions, but as they are written today, the interior battery screws are torx and different from the case screws.
Apple says these batteries need to be calibrated by an Apple technician and that's why replacement should be entrusted to Apple only. Does anyone know what Apple's pre-calibration process entails?
I'm not saying that I know this for a fact concerning the Apple batteries, but often with Lithium (and this applies to the iPhone as well), draining the battery to 0, then giving it a full charge is basically the calibration.
john -
Calibration is very simple to do, and instructions are given in the final step of this guide. If you can do the physical repair, you are more than capable of calibrating the battery.
Well that was easy. Ordered the kit from ifixit. Took about 20 mins to take apart and change the battery. All good.
Lee
lee19apgar - 返信
Just completed my battery replacement and everything is working perfectly (with currently several hours of use). When removing the screws, I found it a little difficult using the iFixit brand "P5 Pentalobe Screwdriver". This is the screwdriver with the yellow handle. It felt as though it didn't actually enter the screw holes and was just barely fitting into it. I haven't used it, but I recommend the $11-12 one, especially if you plan on performing this procedure on other macbooks.
Success!
Battery Guard details before->after http://fs2.directupload.net/images/15082...
Thank you iFixit
Ordered the battery and two screwdrivers linked from this page. The screws weren't laid out exactly as in the guide, but I did end up needing both screwdrivers. The replacement went pretty quick, but afterwards the battery status was being shown as "Condition: Replace Now" and was not charging. I did an SMC reset, which did not help. I then opened it back up and pressed on the parts mentioned in MacBook Air 13インチ Mid 2011 I/Oボードの交換 to make sure they were seated correctly, in addition to plugging and unplugging the battery. Afterwards, seems to be working correctly, thankfully.
Super easy agree - the only thing that i was a bit tenuous on was the Pentalobe screws because the screw driver i bought from you barely fit into the screw recess - sketchy can not tell if it was a poor tool or that was the way it was suppose to be.
andy
Did anyone had the following problem: after changing the battery, closing the MacBook Air, it's switching on when the charger is plugged, but the keyboard (including the on/off key) is not working any more and the fans are turning high speed?
Then, it's impossible to switch it off (as keyboard seems not to be recognised), neither to reboot or reinitiate SMC, etc...
Thanks by advance
Thank You, I did it!!!
Super easy. Took me < 10 mins.
Thanks so much for the excellent guide.
Simple, easy, 5 minutes, but what a great outcome! Same battery since 2012. Now my Air feels new again!
Thanks for the tutorial.
cheers
ekoh
Easy repair...thanks!
Easy install. Took me less than 10 minutes with the right tools I ordered in a kit separately from Ifixit.
Super erklärt, es war wirklich einfach! Danke an den Autor! Und Danke an ifixit!
hello ifixit
I need a little help
I am living in middle east I have MacBook air 13" A1370 I need to change the battery but I cant find it here it is available for mac book Air 11"
so can I fit 11"s battery to 13" mac?
please help
Do we remove the plastic cover the 4 lithium batteries?
Kevin Jose - 返信
Are we supposed to remove the plastic off the batteries??
I did remove it, as the original battery didn't had these plastic sheets over the li-ion cells. I figured it serves as an additional safeguard against accidental punctures in the cells during transit.
My advice: be extra careful while peeling the plastic sheets, as the adhesive is super-strong, and you definitely don't want to bend the battery cells!
Fabricio -
This is easy! I have no idea why they marked it moderate. Buy the tools they sell. Buy the battery from them and do it yourself. Much cheaper and much easier than anywhere else. Did I mention it is easy? Just make sure you follow the instruction on pulling the battery cable and it will be EASY.
Joe Wasser - 返信
I was looking for this project for a long time. Finally all parts were available in EU iFixit store, I was impressed delivery only took 2 days, thanks for Haribo candies ;). Replacement took no longer than 15 mins and now my Macbook Air is like it was just put out of the box which was 5 years ago. I measured average time use, with old batter (1144 cycle count) it was around 1:45 at max, now I am running for 2:22 hours at 50% while installing apps, listening music and so on (did High Sierra install while during this time). My expectation that it will be around 5hrs heavy-medium use and perhaps even close to 6hrs doing light work.
Battery before after, http://www.directupload.net/file/d/4883/...
I had so much fun! Thank you ifixit, for empowering me to do this job cheaper than my local Mac store (who would have probably lost a couple more screws like they did last time, anyway). Shipping was fast and allowed me to hit a work deadline. Next time I get in a bind, I know exactly where to go! <3
10 outta 10 !
J ai du réinitialisé le mac pour qu il reconnaisse la batterie ouf cela marche simple défaire le contact de la batterie appuyer dix secondes sur le on off ou suppr sur un clavier US rebrancher et cela marche ouf !
I’ve replaced the battery and it powers up fine but the track pad now feels kinda “loose” does anyone else have the same problem? When hitting the very bottom of the track pad it now react to slight touch where before it was stiffer.
Same problem here. After replacing the battery the touchpad lifts up on the lower end (towards the user) and has a higher level than the case. It stands out about 0.5 to 1mm. Any solution for that @ifixit?
After comparison to the original battery, the new one is a little bit thicker than the original one at the area underneath the touchpad. Any chance to get a better one that fits?
@biasx Yeah that doesn’t sound right at all! Sorry for the frustration. If you bought your battery from iFixit, give the customer support team a shout and they’ll get you squared away.
I have the same issue. It’s becoming annoying. Any updates?
I did replace the battery following all instructions above. It was easy. I connected the computer to power adaptor and the newly battery was charged to 100% without trouble. Then, I disconnected computer from power adaptor (battery was 100%) and left computer working to see how long it would take to empty battery (i.e, doing the first cycle). After 10-15 minutes, the computer crashed and lost power. I had to connect the power adaptor again (green light is on) but now the computer starts and crashes after a short while. It says that battery is not charging (is at 91%) but then crashes.
Please, any help will be welcome. What should I do?
D
Took 5 minutes and my Macbook air now has full capacity. It’s 7 years old so I really should have replaced it sooner. Thanks iFixIt!
Wow, that was easy! I agree with everyone before me that said that the only “difficult” part is disconnecting the battery (pull towards you, not up on the tab!). Reconnecting it can be challenging too if you’re not patient. Also, screwing in all the tiny screws can drive you nuts. Patience! Anyhow, I’m glad that I did this myself. Oh, and yeah, my mid-2011 MacBook Air is still chugging along in 2019! Thanks for the guide and iFixit for the replacement battery and screwdrivers!
Did it! In about 5 minutes, it was quite easy. Thanks!
Jan Krüger - 返信
ifixit! Easy to follow the guide and reading some of the comments also helped…except for the unhooking the battery with the clear plastic…it should be ‘just pull the clear plastic towards the battery to unhook it’, not ‘pull it up’. Overall, still so easy. Now my MacBook Air 13” Mid 2011 is as good as new! The replacement battery is compatible with my Mac version 10.13.6 with the Mac OS High Sierra in it! Also, it kinda slowed down when the battery is not working (just plugged in), now it’s fast again. Thanks fixit.com! Thanks also for the Apple staff who told me about fixit.com! And ofcourse thanks for the guide!
Thank you for everything you do for us.
You gave back life to my ‘old’ mid-2011 MacBook Air with a fully matching battery (with even better specs than the original in terms of power and capacity).
Super easy to fix! it took me 15 mins tops!!!
Seamless process from order to self-installation. I made the mistake of purchasing a replacement battery on Amazon and within a week had to return it due to issues with the battery. The iFixit product has been perfect since installing it last week. Have already recommended their services to my friends!
Worked perfectly well. Thanks!
My local Mac repair shop wouldn’t even do a diagnostic on the machine for me telling me that it was considered obsolete. My MacBook Air 2011 wouldn’t hold a charge, but would run just fine on the power cord.
This replacement battery took a few days to arrive and less than ten minutes to install.
My “obsolete” MacBook Air works perfectly fine now and its back to work with it!
Thanks iFixit for the tools, the battery and the know-how. 2011 Mac Air now running again with only a short time needed during lunch break to switch out the old Li ion block. Very keen to repair more tech now!
Guys, my original old battery had 7.3V and 6700mha. The new one has 7.6V and 8000mha. Can this cause any damage on the parts or chips, for having higher voltage or capacity?
battery is now ok, but trackpad is erratic. HELP
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - 返信
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - 返信
I thought I could replace my 256 Gb SSD with 512? regards
ola m - 返信
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - 返信
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - 返信
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - 返信
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - 返信
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - 返信
P5 pentalobe screwdrivers are too big! The correct size for these screws are p4 pentalobe. P5 pentalobe was just able, with difficulty, to turn some of the screws. If the screws were at all tight, my p5 was unable to get them out, and started to strip the screws. A p4 screwdriver fit better and removed the screws with ease. (I was using high quality Wiha brand screwdrivers.)
William Skinner - 返信
I had same experience (with MacBook Air 13-inch Mid-2012) … had to get P4, which worked swimmingly
eric -
Very simple installation. The screwdriver heads were exactly what we’re needed, one head for the outside case screws, the other for the screws holding the battery in place. The computer started right up. Now to see how the battery holds up, but I have a good feeling about this!
Dennis Eaton - 返信
My P5 and the T5 worked perfectly with my early 2015 Air 13”! And it is super fast! Thank you iFixit!
Pennny Beach - 返信
The supplied kit and instructions worked perfectly!
Nikolay Andreev - 返信
Comments that the P5 pentalobe are too large are absolutely spot-on. There is no way the P5 pentalobe bit I have will work with the MacBook Air without destroying the screws. Hard target search for P4 pentalobe bit in progress…..
joemoog - 返信
Bonjour j’aimerais changer mon SSD de 128 Go pour en mettre un de 512 Go. Je ne sais pas ce qu’il faut prendre car il faut qu’il soit compatible avec le macbook air A1466. J’aurais vu un Samsung Evo 970 500 Go mais si je ne me trompe pas, il faut un adaptateur.
Merci pour votre aide.
chicco33 - 返信
oui, vous aurez besoin d’un adaptateur, pour completez le changement.
Dan -
The tool kit should include tweezers for re-inserting the battery connector.
Andre Clement - 返信
P5 pentalobe worked perfectly for me. Instructions were spot-on. Antenna connections were a bit fiddly to refit but got them in ok.
michaelquinnell - 返信
Maybe the problem some are experiencing is that the designations are confusing (blame Apple rather than iFixit). the P2 is also known as PL1. The P5 is also known as PL4. The P6 is also known as PL5. So it is possible to mistake the P6 (PL5) for the P5 (PL4), meaning it (P6-PL5) will be too big, while the P5 (PL4) will be just right. Sort of a 3 Bears explanation, but it is very confusing.
Thomas Lewis - 返信
To add to this. In searching for the P5 screwdriver to buy in UK, as far as I can tell, it is also known as
Pentalobe 1.2(mm)
also
P4 = 0.8
P6 = 1.5
Just unscrewed the back case of MacBook Air 13” mid 2011, with no problems using Pentalobe 1.2
nijafe -
I have not replaced a display on the A1369 but have done many A1466 which is a newer 13” model. They seem really similar and its not clear why one needs to remove the logic board to remove the display. The antenna cables on the A1466 dont have to rest under the logic board but can be tucked in the hinge crevice. Cant this same thing be done with the A1369?
Sean Love - 返信
Did mine today - but new battery wasnt charging. Went back in and noticed the battery connector cable was not quite 100% “seated. It was sticking out by less than a millimetre! - you need to give it quite a firm push in to get it seated properly. Otherwise - all ok .
John Brennand - 返信
Just installed on a MacBookAir6,2 (13-inch, Early 2014).
Was very easy.
New iFixit battery looks great so far:
Jonathan Cross - 返信
can you tell me which size of screwdrivers you’ve used to crack it up, please? I have the same model and size,
hawk_lpc -
Screw P5 Pentalobe 1.2
Mario Verlent - 返信
Install went flawlessly. Only challange was reattaching blue tooth antennas. Those sockets are so tiny.
Joel Sebastian - 返信
Installation was a little challenging at first because the instructions on this site did not perfectly match my model (late 2013 to early 2015).
Found this video on YouTube which described the procedure perfectly https://www.youtube.com/watch?v=Lue6lVWh...
Also the Ifixit kit I received was well put together with everything I needed and more. The calibration went perfectly and I am very pleased. Will buy again!!
Donald Niamath - 返信
Gently pulled out connector of old battery, then pressed and held the power switch for 1 minute. Unscrewed and removed the old battery. Pressed and held power switch for 1 minute again. I know from previous work that this helps drain charge from spontaneous recharging as the dielectric recovers. Gently “fine tuned” leads from new battery to connector till connector stuck out at right angle to the edge of battery. Held the battery by the edges and let the connector slide into the socket. Set the battery down and put the screws in all the way. Then checked that the connector was completely seated before tightening the screws. The laptop come on immediately and showed 98% charge and registered normal (checked in “About this Mac”. Very happy to this point. Now for calibration.
Amir Zaidi - 返信
Thank you very much for the guilde. My MBA2011 had reborn !
Billy Wong - 返信
Allow for electrostatics, otherwise you may cook components on the logicboard /motherboard (like I did with one of these!)
See great advice: Electrostatic Discharge
Fletcher Cole - 返信
… und wenn du eines von diesen wirklich kleinen Schräubchen vermisst: bevor du den Boden aufkehrst oder mit einem starken Magneten absuchst, schau mal am seitlichen (magnetischen) Ladekabelanschluss nach … ?
... and if you miss one of these really small screws: before you sweep the floor or search it with a strong magnet, take a look at the (magnetic) charging cable connection on the side … ?
Blatt - 返信
Fot All People ha ing trouble finding their SSD
DONT PRESS CMD +R + POWER
instead press
OPTION+CMD+R +POWER
I just installed Monterrey with WD black sn 770 SSD in m'y macbook air 2015
Albert - 返信
IFixit just had me submit "my story" re. fixing my MacBook Air 2013.
This repair was NOT difficult. The battery is enclosed in a plastic frame. It is NOT glued in like the newer models of Apple laptops. And unlike older laptops, the battery is not totally enclosed in a plastic housing. So once you remove the screws holding the batterie's frame, you can remove the battery.
Follow the instructions. Read the comments. Also read the comments re. installing a new battery.
Good luck. - Eric J.
ECJohansen - 返信
On the back of the laptop, notice that each screw is angled a little bit inward, aiming toward the middle of the laptop. Keep your screwdriver lined up with the screw (angled a bit outward as seen at 01:23 in the video: https://youtu.be/tToAwO6f-SY&t=83). This will help you get a good bite on the screw to get it out and avoid stripping the head of the screw.
Use the same angle when putting each screw back in. If the screw is in line with its hole it should not feel like you are fighting to screw it in. If it does, check your angle and back up a little; you should feel the screw fall into line.
Rich Garella - 返信
shrhh - 返信
