メインコンテンツにスキップ
Mac Studio 2023 Back Thunderbolt 4 Ports Replacement
必要な工具と部品
  1. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Prepare your Mac Studio for disassembly: 手順 1、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Prepare your Mac Studio for disassembly: 手順 1、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Prepare your Mac Studio for disassembly: 手順 1、 3の画像 3
    • Completely shut down your Mac Studio.
    • Unplug all cables from your device.
  2. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Flip your Mac Studio over: 手順 2、 1の画像 1
    • Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
  3. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Heat the bottom cover screw pad: 手順 3、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Heat the bottom cover screw pad: 手順 3、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Heat the bottom cover screw pad: 手順 3、 3の画像 3
    • Adhesive strips secure the bottom cover screw pad.
    • Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
    • You can also use a hair dryer or heat gun, but be careful as extreme heat will warp the pad.
  4. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Lift a section of bottom cover screw pad: 手順 4、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Lift a section of bottom cover screw pad: 手順 4、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Lift a section of bottom cover screw pad: 手順 4、 3の画像 3
    • Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
    • This may take some force. If you're having trouble, apply more heat and try again.
    • Use the spudger to lift the pad and separate the adhesive.
  5. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Separate the remaining adhesive: 手順 5、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Separate the remaining adhesive: 手順 5、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Separate the remaining adhesive: 手順 5、 3の画像 3
    • Insert the flat end of a spudger under the pad.
    • Slide the spudger under the entire pad to separate the remaining adhesive.
  6. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the bottom cover screw pad: 手順 6、 1の画像 1
    • Remove the bottom cover screw pad.
  7. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Reassembly information: 手順 7、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Reassembly information: 手順 7、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Reassembly information: 手順 7、 3の画像 3
    この手順で使用する道具:
    Tesa 61395 Tape
    $2.99
    • During reassembly:
    • If the adhesive strips are still sticky, you can reuse them.
    • If you're applying new adhesive:
    • Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
    • Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
    • If you don't have replacement adhesive, you can use strips of thin, double-sided tape 2–3 mm wide.
    • Apply the new adhesive strips to the bottom cover and remove their liners.
    • Firmly press the bottom cover screw pad into its recess to secure it.
  8. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the bottom cover screws: 手順 8、 2の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the bottom cover screws: 手順 8、 2の画像 2
    この手順で使用する道具:
    FixMat
    $31.41
    • While the Mac Studio uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came.
  9. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the bottom cover: 手順 9、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the bottom cover: 手順 9、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the bottom cover: 手順 9、 3の画像 3
    • Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
    • Remove the bottom cover.
    • To orient the bottom cover, align the Kensington lock cutout in the top left corner with the corresponding one on the internal frame.
  10. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the power supply screws: 手順 10、 2の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the power supply screws: 手順 10、 2の画像 2
    • Use a T10 Torx screwdriver to remove the six screws securing the power supply:
    • Four 6 mm‑long screws
    • Two 7 mm‑long screws with washers
    • You may need to remove a sticker to access these screws. If you do, save it for reassembly.
  11. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Reposition your Mac Studio: 手順 11、 1の画像 1
    • Flip your Mac Studio around so the rear ports are facing you.
  12. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Disconnect the power cord port cable: 手順 12、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Disconnect the power cord port cable: 手順 12、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Disconnect the power cord port cable: 手順 12、 3の画像 3
    • A tight plastic latch secures the power cord port cable.
    • Firmly hold the power supply with one hand and lift up the edge near the power cord port.
    • With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
  13. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Tilt up the power supply: 手順 13、 1の画像 1
    • Only grab the power supply by its edges. Various power components and capacitors are left exposed.
    • Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
    • Be careful not to strain the cable that's still connected to the power supply.
    • Keep the power supply tilted up for the next step.
  14. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Disconnect the power supply signal cable: 手順 14、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Disconnect the power supply signal cable: 手順 14、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Disconnect the power supply signal cable: 手順 14、 3の画像 3
    • A delicate plastic clip secures the power supply signal cable.
    • With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
  15. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the power supply: 手順 15、 1の画像 1
    • Remove the power supply.
  16. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Reposition your Mac Studio: 手順 16、 1の画像 1
    • Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
  17. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the internal frame screws: 手順 17、 2の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the internal frame screws: 手順 17、 2の画像 2
    • Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
    • Seven 5 mm‑long screws
    • One 4 mm‑long screw
  18. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the internal frame: 手順 18、 2の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the internal frame: 手順 18、 2の画像 2
  19. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ethernet board cable cover: 手順 19、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ethernet board cable cover: 手順 19、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ethernet board cable cover: 手順 19、 3の画像 3
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the ethernet board cable cover.
    • Use tweezers or your fingers to remove the cover.
  20. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Disconnect the ethernet board: 手順 20、 2の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Disconnect the ethernet board: 手順 20、 2の画像 2
    • Be very careful not to scrape off or damage any surface mounted components during this step.
    • Use a spudger to pry up and disconnect the ethernet board cable press connector from the logic board.
    • To reconnect press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  21. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Reposition your Mac Studio: 手順 21、 1の画像 1
    • Carefully stand up your Mac Studio so the SD card reader and two front USB-C ports are facing up.
  22. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ethernet board cable: 手順 22、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ethernet board cable: 手順 22、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ethernet board cable: 手順 22、 3の画像 3
    この手順で使用する道具:
    Flexible Extension
    $6.99
    • Use a T4 Torx screwdriver to remove the two 11 mm‑long screws securing the right side of the ethernet board and its cover.
    • These screws may be hard to access. If you can't insert your screwdriver properly, use a flexible extension to avoid stripping screws or damaging the logic board.
  23. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement: 手順 23、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement: 手順 23、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement: 手順 23、 3の画像 3
    • Insert the point of a spudger under the bottom right corner of the ethernet board press connector and lift up to disconnect it.
    • Don't pry against any surface mounted components.
    • Remove the cable.
  24. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ethernet board screws: 手順 24、 2の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ethernet board screws: 手順 24、 2の画像 2
    この手順で使用する道具:
    Flexible Extension
    $6.99
    • Use a T6 Torx screwdriver to remove the two 20 mm‑long screws (with washers) securing the ethernet board.
    • Be careful not to lose the washers, as they can fall off easily.
  25. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ethernet board: 手順 25、 2の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ethernet board: 手順 25、 2の画像 2
    • Lift the ethernet board out of its recess and remove it.
  26. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Reposition your Mac Studio: 手順 26、 1の画像 1
    • Reposition your Mac Studio so the SD card reader and two front USB‑C ports are facing you.
  27. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the cable cover: 手順 27、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the cable cover: 手順 27、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the cable cover: 手順 27、 3の画像 3
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the back Thunderbolt 4 port cable cover.
  28. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Disconnect the ports: 手順 28、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Disconnect the ports: 手順 28、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Disconnect the ports: 手順 28、 3の画像 3
    • Use a spudger to pry up and disconnect both Thunderbolt 4 cable press connectors from the logic board.
  29. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Reposition your Mac Studio: 手順 29、 1の画像 1
    • Carefully stand up your Mac Studio so the SD card reader and front two USB-C ports face up.
  30. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ports screws: 手順 30、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ports screws: 手順 30、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ports screws: 手順 30、 3の画像 3
    この手順で使用する道具:
    Flexible Extension
    $6.99
    • Use a T5 Torx screwdriver to remove the six 5 mm‑long screws securing three of the ports.
    • Use a T7 Torx screwdriver to remove the two 8 mm‑long standoff screws securing the remaining port.
    • To align and install a set of ports during reassembly:
    • Partially tighten all four screws on a set of ports.
    • Lay your Mac Studio down and plug a cable into each port to ensure proper fit and alignment, adjusting the ports as necessary—the cable should be easy to insert and remove.
    • With both cables plugged in and the port in position, fully tighten the screws.
    • Unplug all cables before continuing with reassembly.
  31. Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ports: 手順 31、 3の画像 1 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ports: 手順 31、 3の画像 2 Mac Studio 2023 Back Thunderbolt 4 Ports Replacement, Remove the ports: 手順 31、 3の画像 3
    • Flex cables connect the two inner and two outer port pairs. Don't try to remove individual ports—you can easily damage the cables that connect them.
    • Use your fingers to lift the two inner or outer ports out of their recesses and remove them.
    • Repeat the process to remove the two other ports.
    • During reassembly, put the ports into their recesses, making sure the press connectors stay above the logic board.
終わりに
作成者
1人の作成者と共同作成されました。
Spencer Day
メンバー登録日: 09/14/22
149,052 ポイント
995のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,603のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 9
過去 30 日: 34
今までの合計 302
