メインコンテンツにスキップ
Logitech MX Vertical Battery Replacement
必要な工具と部品
  1. Logitech MX Vertical Battery Replacement, Turn off the mouse: 手順 1、 1の画像 1
    • Before you begin, flip the mouse's power switch into the OFF position.
  2. Logitech MX Vertical Battery Replacement, Lay the mouse buttons-side down: 手順 2、 1の画像 1
    • The mouse's unique shape prevents it from laying flat. If you need to, lay it button-side down onto a soft towel to prevent wobble.
  3. Logitech MX Vertical Battery Replacement, Heat the feet adhesive: 手順 3、 2の画像 1 Logitech MX Vertical Battery Replacement, Heat the feet adhesive: 手順 3、 2の画像 2
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the feet on the mouse's underside for about two minutes.
    • Alternatively, a hair dryer or a heat gun may also be used, but be careful not to overheat the mouse.
  4. Logitech MX Vertical Battery Replacement, Remove the mouse feet: 手順 4、 3の画像 1 Logitech MX Vertical Battery Replacement, Remove the mouse feet: 手順 4、 3の画像 2 Logitech MX Vertical Battery Replacement, Remove the mouse feet: 手順 4、 3の画像 3
    この手順で使用する道具:
    • Insert one arm of a pair of sharp tweezers underneath the end of one foot.
    • Grip the foot and begin to peel it away from the bottom of the mouse.
    • Peel slowly, making sure the foot and its adhesive are removed in one piece.
    • The foot should come away from the mouse without the need for much force. If it feels stuck, apply more heat and try again.
  5. Logitech MX Vertical Battery Replacement: 手順 5、 3の画像 1 Logitech MX Vertical Battery Replacement: 手順 5、 3の画像 2 Logitech MX Vertical Battery Replacement: 手順 5、 3の画像 3
    • Use a pair of tweezers to peel the foot away from the mouse to completely remove it.
    • Place the foot adhesive-side up on a clean surface.
  6. Logitech MX Vertical Battery Replacement: 手順 6、 3の画像 1 Logitech MX Vertical Battery Replacement: 手順 6、 3の画像 2 Logitech MX Vertical Battery Replacement: 手順 6、 3の画像 3
    • Insert a tweezer arm underneath the end of the second foot.
    • Peel the foot away from the mouse to completely remove it.
    • The foot should come away from the mouse without much force. If it feels stuck, apply more heat and try again.
    • During reassembly, remove any leftover adhesive before installing new feet.
  7. Logitech MX Vertical Battery Replacement, Remove the case screws: 手順 7、 1の画像 1
    • Use a Phillips screwdriver to remove the five 6.5 mm recessed screws securing the two halves of the mouse casing together.
  8. Logitech MX Vertical Battery Replacement, Separate the two halves: 手順 8、 3の画像 1 Logitech MX Vertical Battery Replacement, Separate the two halves: 手順 8、 3の画像 2 Logitech MX Vertical Battery Replacement, Separate the two halves: 手順 8、 3の画像 3
    • Don't try to completely remove the upper half, as both halves are connected with a fragile ribbon cable.
    • Lift the top half of the mouse away from the bottom half.
    • Lay the top half of the mouse, buttons down, onto your work surface.
    • Take care to not strain the ribbon cable connecting the two halves.
  9. Logitech MX Vertical Battery Replacement, Disconnect the battery: 手順 9、 2の画像 1 Logitech MX Vertical Battery Replacement, Disconnect the battery: 手順 9、 2の画像 2
    この手順で使用する道具:
    • Use a pair of blunt tweezers to grip the edges of the battery cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  10. Logitech MX Vertical Battery Replacement, Remove the battery: 手順 10、 2の画像 1 Logitech MX Vertical Battery Replacement, Remove the battery: 手順 10、 2の画像 2
    • Peel the battery away from its shelf.
    • The battery is secured with some light adhesive.
    • Remove the battery.
    • To install a replacement battery:
    • Remove any leftover adhesive from the battery shelf.
    • Apply double sided tape or pre-cut adhesive to secure the new battery.
終わりに
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Carsten Frauenheim
メンバー登録日: 03/10/20
135,551 ポイント
371のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,418のガイドは作成済み
8 件のコメント
¡Excelente guia! ¡Parece haber sido hecha por el fabricante! ¡Muchas gracias!
Erick Caliz Morales - 返信
Where can I purchase a known good new battery (OEM preferred)?
Frank - 返信
Is it actually important to replace with the same mAh value?
Or can I go with something bigger as long as the voltage is 3.7V, the connector is the same and the battery actually fits inside the mouse?
Gunnar Arneby - 返信
Looking for the same info as the other commenters, where can I find the replacement battery for sale and are the other ones you sell for similar logitech models good enough to replace for this one?
Dylan - 返信
You can find the replacment battery here: https://www.cutratebatteries.com
Just search AHB521630PJT-04
You're welcome!
Kilowatt - 返信
コメントを追加
統計データ:
過去 24時間: 19
過去 7 日: 201
過去 30 日: 649
今までの合計 24,558
