メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech G705 Battery Replacement
必要な工具と部品
  1. Logitech G705 Battery Replacement, Battery: 手順 1、 2の画像 1 Logitech G705 Battery Replacement, Battery: 手順 1、 2の画像 2
    • Remove the skate pads from the bottom of the mouse by peeling them off to access the screws.
    • If you plan on reusing these skates, you can use a hair dryer or heat gun to soften the adhesive and gently remove the skates.
    FixBotに聞いてみる
    コメントを追加
  2. Logitech G705 Battery Replacement: 手順 2、 3の画像 1 Logitech G705 Battery Replacement: 手順 2、 3の画像 2 Logitech G705 Battery Replacement: 手順 2、 3の画像 3
    • Use a Phillips #000 screwdriver to remove the four 5.0 mm screws securing the bottom of the mouse shell.
    • It's recommended to use a parts tray to store these small screws, so you do not lose them.
    FixBotに聞いてみる
    コメントを追加
  3. Logitech G705 Battery Replacement: 手順 3、 3の画像 1 Logitech G705 Battery Replacement: 手順 3、 3の画像 2 Logitech G705 Battery Replacement: 手順 3、 3の画像 3
    • Carefully pry the two halves of the mouse shell apart.
    • Be careful, as ribbon cables run along the edges.
    • Use a plastic pry tool if needed.
    FixBotに聞いてみる
    コメントを追加
  4. Logitech G705 Battery Replacement: 手順 4、 2の画像 1 Logitech G705 Battery Replacement: 手順 4、 2の画像 2
    • Use the point of a plastic spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the battery connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • This step requires some force and may damage the plastic on the connector.
    FixBotに聞いてみる
    コメントを追加
  5. Logitech G705 Battery Replacement: 手順 5、 2の画像 1 Logitech G705 Battery Replacement: 手順 5、 2の画像 2
    • Remove the 3.0 mm PH000 screw from the black plastic bracket that secures the battery.
    • Remove the bracket.
    • The battery may come loose during this step, depending on the strength and amount of adhesive used during assembly. This is perfectly normal, and you may skip step 6 if this occurs.
    FixBotに聞いてみる
    コメントを追加
  6. Logitech G705 Battery Replacement: 手順 6、 2の画像 1 Logitech G705 Battery Replacement: 手順 6、 2の画像 2
    • If the battery did not come out, it may be easier to remove if the top and bottom of the mouse are separated first.
    • To separate the top and bottom of the mouse, use a spudger or a clean fingernail to flip up the locking flaps on the two ZIF connectors.
    • Use tweezers or your fingers to gently pull the ribbon cables straight out of their sockets.
    FixBotに聞いてみる
    コメントを追加
  7. Logitech G705 Battery Replacement: 手順 7、 1の画像 1
    • Remove the battery from the shell.
    • If the battery doesn't come out easily, use adhesive remover to loosen the adhesive and then safely remove the battery from the shell.
    • Do not use a metal pry tool or pry the battery, as doing so may damage or puncture it and cause injury.
    FixBotに聞いてみる
    コメントを追加
  8. Logitech G705 Battery Replacement: 手順 8、 1の画像 1
    • Place the new battery with the adhesive back in the shell.
    • If the new battery does not have adhesive already, you may use double sided tape to hold it in place.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Carmen Chavez
メンバー登録日: 02/23/26
81 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team A-4, Serna Spring 2026 Austin Community College, Team A-4, Serna Spring 2026人のメンバー
AUSTINCC-SERNA-S26SAG4
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 95
今までの合計 128
