メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Fortune Motherboard Replacement
必要な工具と部品
  1. LG Fortune Motherboard Replacement, Battery: 手順 1、 2の画像 1 LG Fortune Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Use the slit on the bottom right side of the phone to open the back cover of your phone.
    • It will be the bottom left of the phone if looking at it from the back.
    • Slowly pry the back cover off the phone starting from the bottom up to the top.
    FixBotに聞いてみる
    コメントを追加
  2. LG Fortune Motherboard Replacement: 手順 2、 2の画像 1 LG Fortune Motherboard Replacement: 手順 2、 2の画像 2
    • Use the slot in the middle of the bottom edge of the battery to pry it up and out of the case.
    FixBotに聞いてみる
    コメントを追加
  3. LG Fortune Motherboard Replacement, Motherboard: 手順 3、 3の画像 1 LG Fortune Motherboard Replacement, Motherboard: 手順 3、 3の画像 2 LG Fortune Motherboard Replacement, Motherboard: 手順 3、 3の画像 3
    • Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
    • Remove the back panelling from the device with your fingers or a spudger.
    • Work slowly side to side to release this back casing and expose the motherboard.
    FixBotに聞いてみる
    コメントを追加
  4. LG Fortune Motherboard Replacement: 手順 4、 1の画像 1
    • Place a spudger or an opening tool under the edge of the video card press connector and pry straight up to disconnect it from the motherboard.
    • Using the metal spudger as shown in the photos has the potential to damage your device.
    FixBotに聞いてみる
    コメントを追加
  5. LG Fortune Motherboard Replacement: 手順 5、 1の画像 1
    • Unplug the front facing camera press fit connector from the motherboard by prying upwards with a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photos could potentially damage your device.
    FixBotに聞いてみる
    コメントを追加
  6. LG Fortune Motherboard Replacement: 手順 6、 1の画像 1
    • Unplug the rear facing camera ribbon cable from the motherboard by prying up the press fit connector with a spudger.
    • Using a metal spudger as shown in the photos has the potential to damage your device. Choose an ESD safe tool instead.
    FixBotに聞いてみる
    コメントを追加
  7. LG Fortune Motherboard Replacement: 手順 7、 1の画像 1
    • Use the spudger to pry off the motherboard from the rest of the device on the top left corner down to the bottom right corner
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
キャンセル: このガイドを終了できませんでした。
作成者
6人の作成者と共同で作成されました。
Cori Johnson
メンバー登録日: 04/08/19
537 ポイント
5のガイドは作成済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 39
今までの合計 988
