メインコンテンツにスキップ
Huawei P9 Battery Replacement
必要な工具と部品
  1. Huawei P9 Battery Replacement, Back Cover: 手順 1、 3の画像 1 Huawei P9 Battery Replacement, Back Cover: 手順 1、 3の画像 2 Huawei P9 Battery Replacement, Back Cover: 手順 1、 3の画像 3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Battery Replacement: 手順 2、 2の画像 1 Huawei P9 Battery Replacement: 手順 2、 2の画像 2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Battery Replacement, Fingerprint sensor: 手順 3、 2の画像 1 Huawei P9 Battery Replacement, Fingerprint sensor: 手順 3、 2の画像 2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Battery Replacement, Battery: 手順 4、 3の画像 1 Huawei P9 Battery Replacement, Battery: 手順 4、 3の画像 2 Huawei P9 Battery Replacement, Battery: 手順 4、 3の画像 3
    • Unplug the antenna cable.
    • Remove the sticker that sits on top of the screw.
  5. Huawei P9 Battery Replacement: 手順 5、 3の画像 1 Huawei P9 Battery Replacement: 手順 5、 3の画像 2 Huawei P9 Battery Replacement: 手順 5、 3の画像 3
    • Unscrew the two Phillips #00 screws that hold the metal plate in place.
    • The plate, which is covering the battery connector, has two little hooks on each side. Use a tweezer to free them and unhinge the plate by carefully moving it upwards.
  6. Huawei P9 Battery Replacement: 手順 6、 2の画像 1 Huawei P9 Battery Replacement: 手順 6、 2の画像 2
    • Now you can unplug the battery connector and bend it aside.
    • The EVA-L09 model has an NFC antenna adhered onto the battery.
    • If you are just removing the battery to get to the display, you can leave the NFC on the battery.
    • Mark its place on the battery with a felt pen for reassembly. Carefully peel it off and make sure not to rip or crease the antenna.
    • For reassembly, place the NFC antenna on the battery where it was before so its contacts align with their counterparts.
  7. Huawei P9 Battery Replacement: 手順 7、 2の画像 1 Huawei P9 Battery Replacement: 手順 7、 2の画像 2
    • Free the ends of the adhesive pull tabs to get a good grip on them.
  8. Huawei P9 Battery Replacement: 手順 8、 3の画像 1 Huawei P9 Battery Replacement: 手順 8、 3の画像 2 Huawei P9 Battery Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    Tesa 61395 Tape
    $5.99
    購入する
    • The battery is secured with three pieces of adhesive, a removable pull-tab in the center, and on the SIM tray side. A third piece of adhesive on the button side has no pull-tab.
    • Pull the adhesive tabs in a slow constant movement to free the battery.
    • Should those adhesive tabs snap, you might want to use an iOpener to heat and soften them a little bit so you can pry out the battery with a spudger.
    • There are two cables running directly underneath the battery. Take care not to damage them when prying with a spudger! You can see their position in the last picture.
    • Slowly lift the battery toward the button side and free it from the remaining hidden piece of adhesive.
    • When reassembling your phone, replace old adhesive with stretch release adhesive strips, double-sided tape, or pre-cut adhesive strips.
終わりに
90 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Tobias Isakeit
メンバー登録日: 03/31/14
117,729 ポイント
188のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,541のガイドは作成済み
28 件のコメント
Just FYI, My replacement battery from Huawei doesn’t fit. The cable doesn’t reach the connector. Soldering Required!
https://imgur.com/gallery/vTsX8
dallebull - 返信
Bonjour j es effectué cette opération.J es changé le connecteur de chargeur complet suite à un dysfonctionnement. Et la batterie aussi.Et mon soucis reste le même. Le téléphone s allumé mais pas de voyant de charge.merci de me renseigner.
Berhault - 返信
Bonjour,
J’ai le même problème , avez-vous trouvé une solution ?
Amenis -
Bonjour suite à une panne avec mon huawei p9 j es changé le connecteur de chargeur et la batterie et mon problèmereste toujours le même. Il charge toujours pas.merci de me
Berhault - 返信
Dalebull what the !&&* have you done to the batteries in the pictures
Justinas Vaiciunas - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 45
過去 30 日: 182
今までの合計 125,298
