はじめに
Not sure what to do with all the adhesive strips in your fix kit? You’ve come to the right place! This guide shows how to use the adhesives in your kit for Samsung phones with glass backs (S7 and newer). It also includes instructions on how to transfer and install various back cover components, such as the rear bezel and fingerprint sensor.
You may not need to use all the adhesive strips included in the kit. If you are transferring the fingerprint sensor, you may need some double-sided tape such as Tesa tape.
For a list of adhesive strips for the Galaxy S phone, [[ 無効なパーツのリンク ]].
When applying adhesive strips like these, here are some general tips:
- Generally, adhesives strips have a colored side and a non-colored (paper or clear plastic) side. The non-colored side determines which surface the strip should be applied to first.
- To make adhesive application easier, you can align an unexposed strip to its intended position on the phone, then tape one edge down to hold the strip in place. This will allow you to peel away the plastic liners and expose the adhesive without losing alignment.
必要な工具と部品
To install the battery adhesive, follow this guide.
To transfer and install the fingerprint sensor and gasket, start with the next step.
To transfer and install the rear bezel, skip to step 5.
To install the back cover support adhesive, skip to step 9.
To install the back cover perimeter adhesive, skip to step 13.
Heat an iOpener and apply it to the fingerprint sensor for one minute.
Use an opening tool to gently pry the fingerprint sensor at the lower seam, where it contacts the back cover.
Do not pry at the upper seam, which is the fingerprint gasket seam.
Use an opening tool to pry the fingerprint sensor off of the gasket.
Remove the colored plastic liner on the replacement gasket to expose the adhesive.
Carefully align and lay the fingerprint sensor onto the sticky side of the gasket.
Once aligned, press down firmly with your finger to bond the adhesive.
この手順で使用する道具:Tesa 61395 Tape$5.99
To affix the fingerprint sensor to the new back cover, use a custom cut adhesive, or line the perimeter of the sensor with double-sided tape such as Tesa tape.
Align the fingerprint sensor in the back cover cutout and press down firmly with your finger to bond the adhesive.
Heat an iOpener and apply it to the rear bezel for a minute.
Starting from the outward-facing side of the back cover, push the bezel inwards with a finger to loosen the bezel from its cutout.
Alternatively, you can pry around the bezel with an opening tool to loosen it from the back cover.
Figure out how the support strip aligns with the surfaces by matching the adhesive strip's contours with the adhesive residue and the phone frame.
Use an opening tool and high concentration isopropyl alcohol to remove all adhesive residue from the phone frame.
If you're re-using the back cover, remove all adhesive residue from the back cover.
Peel the clear liner off of the support adhesive strip to expose the adhesive.
Carefully lay the strip sticky side up on top of the phone frame, being careful not to touch the sticky surface.
Align the adhesive strip on the phone frame so that the adhesive contours matches the frame's.
If you have two small support strips, repeat the process for both strips.
Peel away the clear liner from the perimeter adhesive strip to expose the adhesive.
Hold the strip by its tabs and carefully line up a long edge of the adhesive to the edge of the back cover.
Set the adhesive onto the back cover and press it onto the cover with your fingers.
Peel away the colored liner from the perimeter adhesive strip to expose the adhesive.
124 の人々がこのガイドを完成させました。
14 件のコメント
The flex cable for the fingerprint sensor is so short and delicate that it’s fiendishly difficult to locate and snap in. You only have a very narrow gap between the back cover and the phone, it wants to jump out of position if you misalign at all, and you can’t reach under there with normal size fingers. Not only that, it’s done with the rear cover adhesive in place so if that touches, it sticks.
I got it snapped on, and the flex cable broke at the same moment. So, no fingerprint sensor for me. Also, the new back cover arrived broken. If it was usable, the way to do it IMHO is to attach the flex cable first, then push the fingerprint sensor assembly on to the new back cover adhesive (it goes on from behind), then close the back cover.
Hey William,
If you bought the back cover from iFixit, please contact our support team here and we will get a replacement sorted out for you!
P.S. I got the battery and cover because the old cover was warped and separated, figured may as well replace the battery in a 2-year-old phone. Turns out, the battery was swollen and huge and it had pushed the back cover open. Not a good situation. So if your back cover is coming off, suspect that battery.
P.P.S. The fingerprint sensor flex cable connector probably could be manipulated into position with the tweezers from the tool kit and pressed down into place with the plastic screwdriver thingy, Just hover the back cover over it with your third hand (or a helper).
Will the phone still be water-resistant after this repair?
