メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC Touch Camera Lens Replacement
必要な工具と部品
  1. HTC Touch Camera Lens Replacement, Camera Lens: 手順 1、 1の画像 1
    • Slide the back panel upward using the grip at the bottom until it releases.
    • Lift and remove the panel.
    FixBotに聞いてみる
    コメントを追加
  2. HTC Touch Camera Lens Replacement: 手順 2、 1の画像 1
    • Use your fingers to grip the battery and remove it from its compartment.
    • Set it aside in a safe place.
    FixBotに聞いてみる
    コメントを追加
  3. HTC Touch Camera Lens Replacement: 手順 3、 1の画像 1
    • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
    • Keep the screws in a safe place so you don’t lose them.
    FixBotに聞いてみる
    コメントを追加
  4. HTC Touch Camera Lens Replacement: 手順 4、 2の画像 1 HTC Touch Camera Lens Replacement: 手順 4、 2の画像 2
    • Use the plastic opening tool to remove the front panel from the phone.
    • Place a spudger or an opening tool under the edge of the press connector and pry straight up to disconnect it.
    • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
    • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    FixBotに聞いてみる
    コメントを追加
  5. HTC Touch Camera Lens Replacement: 手順 5、 1の画像 1
    • Unscrew the torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
    FixBotに聞いてみる
    コメントを追加
  6. HTC Touch Camera Lens Replacement: 手順 6、 2の画像 1 HTC Touch Camera Lens Replacement: 手順 6、 2の画像 2
    • Seperate the motherboard from the black plastic casing.
    • Unplug the black and red wire from the motherboard.
    • Unplug the black and red wire from the black plastic casing.
    FixBotに聞いてみる
    コメントを追加
  7. HTC Touch Camera Lens Replacement: 手順 7、 1の画像 1
    • Use a spudger to lift the black flap lock next to the orange ribbon cable and slide the cable from the socket.
    • Remove the LCD screen.
    FixBotに聞いてみる
    コメントを追加
  8. HTC Touch Camera Lens Replacement: 手順 8、 1の画像 1
    • Remove the camera lens from the motherboard using the plastic opening tool.
    • Align and insert the new camera lens into the opening. Press it into place until it is secure.
    FixBotに聞いてみる
    コメントを追加
終わりに
You've successfully replaced your HTC Touch's camera lens! Test your camera to ensure the new lens works properly and your images are clear. To reassemble your device, follow these instructions in reverse order.
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Sehyun
メンバー登録日: 03/31/11
69 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-12, Regan Spring 2011 Cal Poly, Team 15-12, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S15G12
4 メンバー
15のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 21
今までの合計 3,001
